5/6-speeds.
#1395404
03/01/13 03:26 AM
03/01/13 03:26 AM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
Curious, which one holds up the best in a fairly heavy duty truck? NV 4500? Getrag? 5600? Was looking at doing a 5-speed conversion behind a 440 in an '85 1-ton years ago, so I haven't kept up with updates lately. Or trans technology. Anyone do the swap these days or just buy a newer truck?
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
Re: 5/6-speeds.
[Re: Rhinodart]
#1395408
03/01/13 11:07 AM
03/01/13 11:07 AM
OhioMopar
Mt.Gilead, Ohio
If anyone would know, it would be you!
Re: 5/6-speeds.
[Re: Rhinodart]
#1395413
03/04/13 11:45 PM
03/04/13 11:45 PM
Posts: 1,294 Under the big sky
stateline
Under the big sky
I would never own an NV4500 truck again, stranded too many times with the 5th gear issue and the last two times the trans had the "fix". Also had bad luck with a G56 Mercedes 6-speed, so the only manual I would own is an NV5600 6-speed. [/quote
Does the NV4500 have the 5th gear issue when used behind the V10 or just with the Cummins, or is it mostly driver related
