5/6-speeds. #1395404
03/01/13 03:26 AM
03/01/13 03:26 AM
Mt.Gilead, Ohio
OhioMopar Offline OP
Mt.Gilead, Ohio
Curious, which one holds up the best in a fairly heavy duty truck?
NV 4500? Getrag? 5600?
Was looking at doing a 5-speed conversion behind a 440 in an '85 1-ton years ago, so I haven't kept up with updates lately. Or trans technology. Anyone do the swap these days or just buy a newer truck?
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: 5/6-speeds. [Re: OhioMopar] #1395405
03/01/13 04:46 AM
03/01/13 04:46 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
The 4500 is leaps and bounds better shifting than the getrag. I've been told the 5600 is the best of the bunch.
Re: 5/6-speeds. [Re: DaytonaTurbo] #1395406
03/01/13 06:41 AM
03/01/13 06:41 AM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
Thank you.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: 5/6-speeds. [Re: OhioMopar] #1395407
03/01/13 09:44 AM
03/01/13 09:44 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I would never own an NV4500 truck again, stranded too many times with the 5th gear issue and the last two times the trans had the "fix". Also had bad luck with a G56 Mercedes 6-speed, so the only manual I would own is an NV5600 6-speed.
JB Rhinehart, Realist
A-Body's RULE!
Re: 5/6-speeds. [Re: Rhinodart] #1395408
03/01/13 11:07 AM
03/01/13 11:07 AM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
If anyone would know, it would be you!
1969 Dart GTS 340
2015 Dodge Dart GT
Re: 5/6-speeds. [Re: OhioMopar] #1395409
03/01/13 02:27 PM
03/01/13 02:27 PM
dogdays Offline
dogdays  Offline
Any reports on the big ford's ZF?
R.
Re: 5/6-speeds. [Re: dogdays] #1395410
03/02/13 02:57 PM
03/02/13 02:57 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
The NV5600 and G56 6 speeds have the bellhousing integrated onto them making them only able to bolt up to a cummins or v-10. So they would be out of the question for a swap. A NV4500 would be your best choice. I think you would have no issues with one behind a 440.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: 5/6-speeds. [Re: 71yelladustr] #1395411
03/04/13 10:38 PM
03/04/13 10:38 PM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
The 5600 bellhousing is separate from the main case like the 4500.
Re: 5/6-speeds. [Re: 135sohc] #1395412
03/04/13 11:35 PM
03/04/13 11:35 PM
Missouri U.S.A.
Missouri U.S.A.
No it is not like the NV4500. The bell on the 5600 contains the input and countershaft bearing races and cannot be separated from the main case without total trans diassembly.
10.02@134
Re: 5/6-speeds. [Re: Rhinodart] #1395413
03/04/13 11:45 PM
03/04/13 11:45 PM
Under the big sky
stateline Offline
stateline  Offline
Under the big sky
I would never own an NV4500 truck again, stranded too many times with the 5th gear issue and the last two times the trans had the "fix". Also had bad luck with a G56 Mercedes 6-speed, so the only manual I would own is an NV5600 6-speed. [/quote
Does the NV4500 have the 5th gear issue when used behind the V10 or just with the Cummins, or is it mostly driver related
Re: 5/6-speeds. [Re: stateline] #1395414
03/05/13 12:09 AM
03/05/13 12:09 AM
South Coast of Oregon
dweller Offline
dweller  Offline
