alternator field wire size #1395363
03/01/13 12:20 AM
03/01/13 12:20 AM
central IL reg Nov 18, 1999
Stroker Offline OP
Stroker  Offline OP
What ga. wire is used on 72 era B bodies for the field wires?
Would it be beneficial to use a slightly bigger wire on a 75 amp alt, or are they just for sensing?
Re: alternator field wire size [Re: Stroker] #1395364
03/01/13 12:52 AM
03/01/13 12:52 AM
I don't have a 1972 FSM but I'm alomst sure the pre 1971 and earliers cars used either a 16 or 14 gauge field wires I don't know what you call a sense wire, the early mechanical alternators fed the feild side of the alternators off of the distributor ballast resitor, the later cars with electronic voltage regulators use one wire from the ignition switch and the other one from the ignition circiut off of the ignition ballat resitor
Re: alternator field wire size [Re: Stroker] #1395365
03/01/13 01:33 AM
03/01/13 01:33 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Sensing is done by the voltage regulator which is not internal on vintage Mopars.. But the field wire is a low current circuit & 16 ga is what was originally used... The Battery wire however carries the load & should be larger...
Re: alternator field wire size [Re: 1_WILD_RT] #1395366
03/01/13 11:10 AM
03/01/13 11:10 AM
COLLINGWOOD, ONT
71_deputy Offline
71_deputy  Offline
COLLINGWOOD, ONT
correct above as field shouldn't be more than 3 amps total!
Re: alternator field wire size [Re: Stroker] #1395367
03/01/13 04:09 PM
03/01/13 04:09 PM
Stroker Offline OP
Stroker  Offline OP
So what's the consensus?
14? 16?
If I didn't have MSD ignition, etc, etc, I'd just have an Evans harness made.
But-I'd have to hack it all up to get my other stuff wired.
I wonder if they could do a bulkhead to regulator plug with field wires...
I just want to drive the car this year.
It's been off the road too long.
Re: alternator field wire size [Re: Stroker] #1395368
03/01/13 04:42 PM
03/01/13 04:42 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
18 ga is all you need. Even newer vehicles with 140 amp alternators only use 18 ga for the field wires.
Re: alternator field wire size [Re: John_Kunkel] #1395369
03/01/13 07:43 PM
03/01/13 07:43 PM
Valencia, España
NachoRT74 Online content
NachoRT74  Online Content
Valencia, España
18ga was used from factory
Re: alternator field wire size [Re: NachoRT74] #1395370
03/01/13 11:47 PM
03/01/13 11:47 PM
Stroker Offline OP
Stroker  Offline OP
Thanks, guys.
And by "sensing," isn't this what they basically do?
Sense voltage to tell the alt what to do?
Electricity=voodoo
Re: alternator field wire size [Re: Stroker] #1395371
03/02/13 12:09 AM
03/02/13 12:09 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Thanks, guys.
Electricity=voodoo
;-) [/quote
Yes which as I pointed out earlier is done by the voltage regulator...
Re: alternator field wire size [Re: 1_WILD_RT] #1395372
03/02/13 01:31 AM
03/02/13 01:31 AM
western pennsylvania
b1dartsport Offline
b1dartsport  Offline
I have a 150 Amp Powermaster Denso that is internally regulated and the sensing wires for it on the plug are 18 gauge.
Re: alternator field wire size [Re: Stroker] #1395373
03/02/13 07:04 PM
03/02/13 07:04 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Thanks, guys.
Electricity=voodoo
There is current flowing through the field wires, the "sensing" is done by the regulator via the blue IGN1 wire.
Re: alternator field wire size [Re: Stroker] #1395374
03/03/13 11:04 AM
03/03/13 11:04 AM
Valencia, España
Valencia, España
is not a SENSING wires, its a FIELD SOURCE wire
these wires feed both poles to the rotor coil and when spining creates the magnetic field what outer stator captures.
Re: alternator field wire size [Re: NachoRT74] #1395375
03/28/13 10:54 AM
03/28/13 10:54 AM
Stroker Offline OP
Stroker  Offline OP
"The sense is sensin' that the juice keeps pumpin' and I know why..."
-Keith Richards, 1981.
Really, isn't it all just semantics?
Is the large wire on the alternator for charging?
NO! The alternator charges.
Etc, ad nauseum.
Re: alternator field wire size [Re: Stroker] #1395376
03/28/13 04:48 PM
03/28/13 04:48 PM
Valencia, España
Valencia, España
not really semantic. The GM speelling is what give us the "SENSING" therm, where actually switches on the regulator and gives the signal to cluster light. Beside the "sensing" wire on GM, they get the SOURCE wire for reg/rotor in a diff wire
the field wires on Mopars actually FEED the alt rotor to be able to produce the output power. No sensing at all
Is not just semantics, is a diff way to work.
Re: alternator field wire size [Re: NachoRT74] #1395377
03/28/13 05:12 PM
03/28/13 05:12 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
The sense wire on the GM was an output to let the idiot light know when to turn on. The field wires on Mopars regulate the output on the big wire by varying the voltage on the field. That was done internally on the GM alternators and because of the heat were a frequent source of failure.
Re: alternator field wire size [Re: John_Kunkel] #1395378
03/28/13 05:24 PM
03/28/13 05:24 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
This is correct. All voltage reg need to know battery voltage and it dont matter if its internal or an external reg. They all need a 12 volt sense wire so the reg can control the alt output by the field circuit. And as was said the blue ign1 wire at the voltage reg is where the Mopar electronic reg picks up battery voltage. The other wire on the reg is the field ground wire as it uses that to control alt output. The ign1 wire also feeds the battery side of the ballast res and the factory ign module. Ron
Re: alternator field wire size [Re: John_Kunkel] #1395379
03/28/13 05:37 PM
03/28/13 05:37 PM
Valencia, España
Valencia, España
Thanks, guys.
Electricity=voodoo
DEPENDING on year setup
on electronic systems that's it. the blue wire section going to reg is the sensing one to make work the regulator and FEED NEGATIVE, sourced by chassis, but not the blue one going to fields... both shares same source but for diff purpouses
on mechanical systems, this blue wire senses ( allong with chassis ground ) AND feeds at the same time to get same kind of positive signal on reg output
