Big block intake pan gasket #139462
10/20/08 11:58 PM
10/20/08 11:58 PM
Canada
CrAzYMoPaRGuY Offline OP
Canada
Has anybody ever had the valley pan on a big block "balloon" if the fiberglassish material pad isn't installed- plugged PCV or?
I've seen quite a few back in the day, I just wonder if it was excess blowby, a plugged PCV, or? Was it common, or did I just see a few more than most...?
CrAzYMoPaRGuY
Re: Big block intake pan gasket [Re: CrAzYMoPaRGuY] #139463
10/21/08 12:56 AM
10/21/08 12:56 AM
Erda, UT
67Charger Offline
67Charger  Offline
Erda, UT
I had that happen when I had a clogged breather...
11.33 @ 118.46 on motor
10.75 @ 125.35 w/ a little spray
Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race
Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
Re: Big block intake pan gasket [Re: CrAzYMoPaRGuY] #139464
10/21/08 06:13 AM
10/21/08 06:13 AM
North Carolina
cjskotni Offline
cjskotni  Offline
North Carolina
It has nothing to do with the pad under the intake. The valley van will ballon if you don't have some type of breather/PCV valve.
I had this happen the first day I broke my engine in. In my excitement, I forgot to install a PCV, and with all the blowby of a newly-rebuilt motor, it popped that valley pan like a piece of popcorn!
When, it happened, I'd thought I thrown a pushrod or something ...sounded like a gunshot!
Re: Big block intake pan gasket [Re: CrAzYMoPaRGuY] #139465
10/21/08 09:09 AM
10/21/08 09:09 AM
Florida STAYcation
BeEtLeJuIcE ! Offline
The village idiot's idiot
Florida STAYcation
To BALLOON up a valley pan ..... is way WAY more than just a plugged-up PCV ..... there are MAJOR piston or piston ring probs going on. The last one I saw was a MH 440 that a guy had gotten out of a JY. The VP was almost "molded" to the bottom of the intake. There was a hole in one of the pistons the size of a quarter !
A plugged-up PCV ? ... you CrAzY CaNaDiAnS !
Re: Big block intake pan gasket [Re: BeEtLeJuIcE !] #139466
10/21/08 10:28 AM
10/21/08 10:28 AM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
A nonfunctioning PCV system will cause the valley pan to bow up. There is always pressure in the crankcase because pistons are cupped underneath. When they move up and down this causes the air to be cupped in them and forced down which builds pressure. That is one of the reasons there are breathers and tubes on older cars and a breather and PCV in newer cars.
Re: Big block intake pan gasket [Re: CrAzYMoPaRGuY] #139467
10/21/08 12:48 PM
10/21/08 12:48 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
If enough gas gets into the oil pan and you try and start it, then that will happen. had it happen twice. Once from a stuck float in the carb and the other time there was a hole in the piston from detonation!! How are the valve covers?
Re: Big block intake pan gasket [Re: R/T1968R/T] #139468
10/21/08 04:14 PM
10/21/08 04:14 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I dont know we run no PCVs on 3 motors 1 SB and 2 BBs.My 12.5 440 has 2 breathers and is new under 5K miles but is street and strip.The kids almost 50 year old 413 ses tons of satreet miles and has never been apart.2 breathers on it too.He runs the snot out of it and has for 9 years.If you balloon a valley pan you need a rebuild period.If its a new motor and does it you have problems.Rocky
Chrysler Firepower
Re: Big block intake pan gasket [Re: CrAzYMoPaRGuY] #139469
10/21/08 04:54 PM
10/21/08 04:54 PM
Pittsburgh, PA
1970440RT Offline
1970440RT  Offline
Pittsburgh, PA
My motor did it when new. I forgot the pcv and breather when breaking it in. Not only ballooned valley, also leaking gaskets. I replaced the pan and added a breather. 6 years later the same motor is still running strong.
Re: Big block intake pan gasket [Re: 1970440RT] #139470
10/21/08 05:56 PM
10/21/08 05:56 PM
Florida STAYcation
Florida STAYcation
Well - how you define "running strong" is way diff than mine. If you have enough pressure to "inflate" the VP gasket ..... your motor is a leaker- big-time. And piston-ring-seal is probably the most important factor of a good running internal combustion engine.
To the guy who had the stuck-floats and the oil was diluted with gas .... you probably hurt the rings badly. It is a well-known-fact that you can damage the rings with an excessively rich A/F mixture. What happens is that rich-mixture "washes" the oil off the rings and cyl walls. NOT good.
Re: Big block intake pan gasket [Re: BeEtLeJuIcE !] #139471
10/21/08 06:56 PM
10/21/08 06:56 PM
Canada
Canada
I think you would be surprised how a good running engine WITHOUT a breather or PCV valve can pop a valley pan gasket.
Regular blowby running at highway speeds, I've seen it.
I'm not sure your motorhome could make it up to such speeds, being fiberglass and all.
Mind you- MY motorhome was a STEEL shell, and could SUSTAIN "highway speeds"....
CrAzYMoPaRGuY
Re: Big block intake pan gasket [Re: CrAzYMoPaRGuY] #139472
10/21/08 06:56 PM
10/21/08 06:56 PM
Canada
Canada
CrAzYMoPaRGuY
Re: Big block intake pan gasket [Re: CrAzYMoPaRGuY] #139473
10/21/08 10:36 PM
10/21/08 10:36 PM
Florida STAYcation
Florida STAYcation
You CrAzY cAnAdIaNs ! ...
BLOWby equals lost power ! ....and fuel econ.
And as far as fiberglass vs steel ? ....with your AERO equal to a barn-door ...and mine same-same to the Space-Shuttle ...we will see who will do what .... at a 100 mph "roll" !
Re: Big block intake pan gasket [Re: BeEtLeJuIcE !] #139474
10/21/08 10:39 PM
10/21/08 10:39 PM
Grand Prairie,Texas
Grand Prairie,Texas
It hasn't been proven to be blowby yet. That's just your opinion. There are other equally as valid opinons brought up in this post.
Re: Big block intake pan gasket [Re: stumpy] #139475
10/21/08 10:53 PM
10/21/08 10:53 PM
Florida STAYcation
Florida STAYcation
Well -- why don't you list here(in your opinion) what the probs might be. Or are you suggesting that this is "normal" ?
IMO ... it is either severe and way-excessive blow-by, a heavy gas mix in the oil that has mildly "exploded" .... OR it is just the way CrAzY cAnAdIaNs build their engines !
Re: Big block intake pan gasket [Re: BeEtLeJuIcE !] #139476
10/21/08 10:56 PM
10/21/08 10:56 PM
Grand Prairie,Texas
Grand Prairie,Texas
Please read the above posts and you will find the other opinions on different causes.
Re: Big block intake pan gasket [Re: stumpy] #139477
10/21/08 10:57 PM
10/21/08 10:57 PM
N
NITROUSN Offline
NITROUSN  Offline
N
The motor needs to be vented or where else does the pressure go? Seems like the dipstick should lift up. I wonder how much pressure it takes to belly a pan? Maybe some pans are thinner and belly easier.
Re: Big block intake pan gasket [Re: BeEtLeJuIcE !] #139478
10/21/08 10:58 PM
10/21/08 10:58 PM
Canada
Canada
ALL engines have blowby.
Fiberglass vs steel? STEEL WINS!
Here's MY 100 mph "roll on"... let's see yours!
CrAzYMoPaRGuY
Re: Big block intake pan gasket [Re: stumpy] #139479
10/21/08 11:02 PM
10/21/08 11:02 PM
Florida STAYcation
Florida STAYcation
I was asking YOU your opinion.
Re: Big block intake pan gasket [Re: NITROUSN] #139480
10/21/08 11:14 PM
10/21/08 11:14 PM
Florida STAYcation
Florida STAYcation
Good points ..... and all engines have some degree of less than 100% ring-seal.
How much pressure would it take? ...I would think it would be EVERY BIT of the compression and ignition process of one cylinder !!
Re: Big block intake pan gasket [Re: BeEtLeJuIcE !] #139481
10/21/08 11:19 PM
10/21/08 11:19 PM
Canada
Canada
I think the accumulation of pressure while running at high rpms with no pressure relief (read- plugged PCV/no breather) would do it.
I am every bit an iron based steel kinda guy though.
CrAzYMoPaRGuY
