jeep control arms suspension #1394600
02/28/13 01:48 AM
02/28/13 01:48 AM
waynesboro va
jonesboys Offline OP
waynesboro va
new to jeeps i bought 1998 wrangler the suspension ht wise looks stock control arms are round and look as if they slide grease fittings as if aftermarket all joints what do i have i dont know
Re: jeep control arms suspension [Re: jonesboys] #1394601
02/28/13 04:33 AM
02/28/13 04:33 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
I believe stock is stamped but I could be wrong but that's all I ever see or stock
Re: jeep control arms suspension [Re: 76dodgeboy] #1394602
02/28/13 07:24 AM
02/28/13 07:24 AM
enfield, CT
ViperDave Offline
ViperDave  Offline
enfield, CT
stock was stamped. round bars are definitely aftermarket. round lowers? or round upper and lowers?
67 Dart GT Vert 273/904
72 Town & Country 440/727
90 D350 reg cab dually cummins
15 Scat Pack Challenger
Re: jeep control arms suspension [Re: ViperDave] #1394603
02/28/13 10:11 AM
02/28/13 10:11 AM
scratchnfotraction Offline
can you post a pic
the radius arms are stamped channel steel. after market are fabricated steel tube/bar stock. should be 4 arms 2on top 2 on bottom coil springs for lift. basic 4 link suspension up front with panhard rod.
rear should be axle under leaf spring or it went to 4 link coil springs on the rear as well.
does it have a lift kit installed?
2x or 4x4?
will be the same with 2x but a stright tube axle with 4x4 knuckles/spindles.
