Oil pan gasket to pan & engine: use any sealer? #1394510
02/27/13 09:42 PM
02/27/13 09:42 PM
Louisiana
rnch Offline OP
rnch  Offline OP
Louisiana
Great stuff, RTV sealer, high temp orange sealer..or just torque it up tight & dry?
All over the gasket or just in the corners??
wadduathunk?
Re: Oil pan gasket to pan & engine: use any sealer? [Re: rnch] #1394511
02/27/13 11:01 PM
02/27/13 11:01 PM
scratchnfotraction Offline
I do the 4 corners and a thin film of rtv down the pan rail to hold gasket in place.
none under or on the rubber end gaskets.
Re: Oil pan gasket to pan & engine: use any sealer? [Re: scratchnfotraction] #1394512
02/28/13 03:06 AM
02/28/13 03:06 AM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
a tractor trailer mechanic I worked with used weather striping glue. a [Edited by Moparts - Family Friendly Site - Keep it clean] to get off, but he never had a gasket leak.
1981 Dodge D150 360 auto
