Poly 318 intake question
#1394442
02/27/13 05:45 PM
02/27/13 05:45 PM
dogdays
Okay, I'm one of the lucky ones, got my Weiand 7503 for less than $200. But something inside keeps telling me there has to be a better intake.
A while back I bought a bunch of gaskets hoping that the two LA head gaskets that the guy said were steel really were (they weren't). In that mix were a few intake gaskets for ford 351W. Holding them up to a 318P intake gasket, I can move them around so the ports almost exactly overlay each other. The 351W has a 9.5" deck height vs the Poly 9.6, so they should be in the same ballpark. The water routing is different and going to require some major surgery, but there are really nice intakes, not to mention MPFI intakes, for the 351W.
Anyone out there ever look into this?
Thanks, R.
Re: Poly 318 intake question
[Re: WO23Coronet]
#1394444
02/27/13 10:24 PM
02/27/13 10:24 PM
Posts: 4,872 connecticut
pnypwr
connecticut
right bank is forward on a sbf cyl 1 is right front...the opposite of mopar. also the front of a ford is curved for the distributor the mopar is flat. to make a good intake you will prob have to have one fabricated. Or change to a LA or magnum engine, your really limited with the poly.
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd 74 gremlin x 360 65 mustang 347 70 coronet R/T 440 03 Mach 1
