Heavy Duty or High Volume oil pump: which is "better"? #1394133
02/26/13 11:19 PM
02/26/13 11:19 PM
Louisiana
rnch Offline OP
rnch  Offline OP
Louisiana
for my street driven '85 ram 150, 318 engine, torqueflite tranny?
I'm looking for the most oil pressure I can have below 2500 rpm.
Re: Heavy Duty or High Volume oil pump: which is "better"? [Re: rnch] #1394134
02/27/13 03:24 AM
02/27/13 03:24 AM
Elk Grove, Calif.
bigblock340power Offline
Elk Grove, Calif.
I've always used Melling high volume, high pressure pumps. I've used them in my 416 stroker, and in more subdued builds. Never disappointed me yet!
Just my
Re: Heavy Duty or High Volume oil pump: which is "better"? [Re: rnch] #1394135
02/27/13 03:30 AM
02/27/13 03:30 AM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
What kind of pressure #'s are you looking for ?...and WHY high pressure at lower rpms ?
Re: Heavy Duty or High Volume oil pump: which is "better"? [Re: dOrk !] #1394136
02/27/13 08:08 AM
02/27/13 08:08 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
standard only pumps for me. Iv learned my lesson with hi volume/hi pressure pumps.. They are not needed....
I am truckless..
Re: Heavy Duty or High Volume oil pump: which is "better"? [Re: rnch] #1394137
02/27/13 08:47 AM
02/27/13 08:47 AM
Pyeongtaek, South Korea
69HemiGTX Offline
69HemiGTX  Offline
High pressure and/or volume aren't really necessary for 2500 RPM. The factory pump is more than adequate.
OIF V and OEF X veteran and proud of it!
Re: Heavy Duty or High Volume oil pump: which is "better"? [Re: 69HemiGTX] #1394138
02/27/13 10:35 AM
02/27/13 10:35 AM
scratchnfotraction Offline
just replace it with a stock over the counter oil pump from napa.
I have used a lot of the melling M72 pumps on new engine builds as well as high milage engines.
if I use a HV/HP pump on a new build I drill the oil pump/main cap/block to 1/2" add 4 more holes in the oil filter adaptor, drill the feeds to lifter galleys to 9/32,matching/blending all mating surfaces and rounding any turns i can reach.
other wize it uses a stock pump with stock engine specs.
Re: Heavy Duty or High Volume oil pump: which is "better"? [Re: dOrk !] #1394139
02/27/13 12:49 PM
02/27/13 12:49 PM
Louisiana
rnch Offline OP
rnch  Offline OP
Louisiana
I recently bought a higher mileage 318 powered ram, looks like oil hasn't been changed in a L O N G time due to a rounded off, stuck oil pan drain filler plug.
The oil pressure gauge still reads slightly below half scale all the time, no engine noise that I would associate with low oil pressure.
I'm going to be swapping oil pans soon, thought it might be a good prevenative measure to change the pump out with the pan off?
Perhaps I will just clean the pick up screen and let it go.
Re: Heavy Duty or High Volume oil pump: which is "better"? [Re: rnch] #1394140
02/27/13 01:09 PM
02/27/13 01:09 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Wouldnt hurt to put a new pump in if you have the pan off. Oil pump and timing chain always get changed if I have that area open enough to do so
Re: Heavy Duty or High Volume oil pump: which is "better"? [Re: 69HemiGTX] #1394141
02/27/13 02:12 PM
02/27/13 02:12 PM
Louisiana
rnch Offline OP
rnch  Offline OP
Louisiana
Good to know! This truck ('85 ram 150, 318 & torqueflite) will be my back up vehicle; used mainly for trips to home depot or lowes to get stuff that I feel guilty about putting in the carpeted trunk of my new car; will seldom experience more than 65 mph on the occassional interstate run to work....slowly trying to fix what the previous owner deferred doing.
Re: Heavy Duty or High Volume oil pump: which is "better"? [Re: rnch] #1394142
02/27/13 02:17 PM
02/27/13 02:17 PM
dogdays Offline
dogdays  Offline
A stock pump is the best for your application. Yes, this advice has changed from years ago.
The horsepower that it takes to drive the pump varies DIRECTLY with either flow or pressure. Increase both and it varies by the product of the two. Having 50psi at idle for example, just twists your camshaft and puts more load on the oil pump drive.
R.
Re: Heavy Duty or High Volume oil pump: which is "better"? [Re: rnch] #1394143
02/27/13 09:38 PM
02/27/13 09:38 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
Don't go by the gauge, it just serves in an advisory capacity.
Merely something to give you something to look at.
My '85 is VERY slow to start any reading, even with a new sender unit to replace the leaker. And I think there is also a light? Seem to remember one ...
It is probably about as accurate as the temp gauge.
It takes gasoline to interest me.
Re: Heavy Duty or High Volume oil pump: which is "better"? [Re: VL21] #1394144
03/01/13 01:01 AM
03/01/13 01:01 AM
IN
ahy Offline
ahy  Offline
IN
The high pressure pump has a stiffer release spring. At low RPM if you are dealing with low OP that won't help. The relief valve is already closed. The high volume pump will move more oil at low RPM and may help oil pressure.
The only application I can think of where a high pressure/std volume pump may help is a super high RPM race engine (>7,000 RPM).
Otherwise the HV/std pressure may help a low OP situation at low RPM... and as many have posted the std volume/std pressure setup is usually fine with a stock or near stock engine.
Re: Heavy Duty or High Volume oil pump: which is "better"? [Re: 340SHORTY] #1394145
03/01/13 11:37 AM
03/01/13 11:37 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
You nailed it!!!
Re: Heavy Duty or High Volume oil pump: which is "better"? [Re: rnch] #1394146
03/01/13 07:25 PM
03/01/13 07:25 PM
VA
AtomicDog Offline
AtomicDog  Offline
VA
I use the high volume Melling oil pump in my small block motors, along with the Mopar Performance oil pump drive, which has a hardened tip and the shaft pinned to the gear. Also, usually used with a deep oil pan and windage tray, too.
Works great for my needs.
Re: Heavy Duty or High Volume oil pump: which is "better"? [Re: rnch] #1394147
03/19/13 09:40 PM
03/19/13 09:40 PM
Louisiana
rnch Offline OP
rnch  Offline OP
Louisiana
I replaced the oil pump (and oil pan and gasket) this weekend with a standard pressure Melling oil pump. The oil pressure gauge reads somewhat higher, a bit more than half scale, but does build up pressure quicker than before.
Re: Heavy Duty or High Volume oil pump: which is "better"? [Re: rnch] #1394148
03/19/13 10:20 PM
03/19/13 10:20 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
As mentioned before, Dont go off of the p.o.s. factory gauge in the dash for any precise oil pressure readings. They are generally way off. Put you a MECHANICAL gauge under the dash if you are that concerned about it. FWIW, mopars usually carry very good oil pressure, even at lower speeds with the STOCK pump. They ain't a SB chebby that can just barely muster 30 psi cold.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
