cylinder head chamber polishing #1394121
02/26/13 11:03 PM
02/26/13 11:03 PM
BigFish69 Offline OP
Is there any advantage to polishing the chamber or is it best left alone.
Re: cylinder head chamber polishing [Re: BigFish69] #1394122
02/26/13 11:19 PM
02/26/13 11:19 PM
It depends on several things, which type of head, iron or aluminum,probally the type of fuel, alcholol ,E85 or gasoline, is it a closed chamber or open chamber head and do you mind increasing the CC of the chambers? I've seen stock cast Iron 426 Street Hemi head vary 4 CC between chambers Same thing on a set of stock 906 iron heads
Re: cylinder head chamber polishing [Re: Cab_Burge] #1394123
02/26/13 11:41 PM
02/26/13 11:41 PM
Cab its Edelbrock RPM 84 cc
thanks
Re: cylinder head chamber polishing [Re: BigFish69] #1394124
02/27/13 12:11 AM
02/27/13 12:11 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I was always told it helps reduce detonation. I did my Hemi heads that are aluminum. Polished up real nice...Don't know how true it is, but its cheaper than the Swain Tech coatings I was looking into.
