440 6 Pack Electric Choke Thermostat #1394107
02/26/13 10:53 PM
02/26/13 10:53 PM
Riyadh, Saudi Arabia
Merlin45 Offline OP
Merlin45  Offline OP
My engine is finally coming together and I want to install a new electric choke thermostat. I'm a little new to this engine component and need to get inputs to what works well, where to locate, and what issues others have run into when installing/using this part. I want to be sure I have good choke control on the engine to ensure proper running and performance. Thanks!
Re: 440 6 Pack Electric Choke Thermostat [Re: Merlin45] #1394108
02/26/13 11:27 PM
02/26/13 11:27 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
there is a thread by a member that did this , maybe in the best of section ?
Re: 440 6 Pack Electric Choke Thermostat [Re: JohnRR] #1394109
02/26/13 11:33 PM
02/26/13 11:33 PM
Merlin45 Offline OP
Merlin45  Offline OP
I've done more reading on this issue and it seems there are no manufactured electric chokes for 6 pack setups, that some members have built electric chokes from piece parts or have adjusted the standard mechanical choke spring to get better operating limits. Hopefully others will chime in on what works or is available or just stay with a mechanical choke and adjust the spring tension to work the choke better.
Re: 440 6 Pack Electric Choke Thermostat [Re: Merlin45] #1394110
02/26/13 11:39 PM
02/26/13 11:39 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You are correct there is no manufactured electric choke for it , the member adapted a a heater element to make the stock choke thermostat work.
Is your heat crossover blocked ? Are you after a 100% OEM appearance?
The alternative is to change the choke to a manual pull cable or do as the meber outlined.
I don't know if anyone has tried to install a holley electric choke to the side of the center carb , do not know if there is room. the crneter carb is half a 4bbl so I would think it could be done.
Re: 440 6 Pack Electric Choke Thermostat [Re: JohnRR] #1394111
02/26/13 11:45 PM
02/26/13 11:45 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: 440 6 Pack Electric Choke Thermostat [Re: hemi71x] #1394112
02/27/13 12:12 AM
02/27/13 12:12 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
https://board.moparts.org/ubbthreads/showflat.php?Cat=&Board=best&Number=5006831&Searchp
Is this the old posting your guys might be thinking about?
That's it .
Re: 440 6 Pack Electric Choke Thermostat [Re: hemi71x] #1394113
02/27/13 12:19 AM
02/27/13 12:19 AM
Shoreline, Washington
72roadrunnergtx Offline
Follow up on that thread; 4-years later, cold intake and a fully functional 6-pack automatic choke. Still starts up perfectly every time regardless of ambient temperature.
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
Re: 440 6 Pack Electric Choke Thermostat [Re: hemi71x] #1394114
02/27/13 05:51 PM
02/27/13 05:51 PM
Merlin45 Offline OP
Merlin45  Offline OP
Great information. If I do go with the standard mechanical choke assembly mounted to the intake what is the best part to go with? Are all mechanical choke assemblies the same? Do they adjust (spring tension) differently?
Re: 440 6 Pack Electric Choke Thermostat [Re: Merlin45] #1394115
02/27/13 07:00 PM
02/27/13 07:00 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The 6pk uses a specific thermo choke assembly , it has adjustment under the plate in the well.
Re: 440 6 Pack Electric Choke Thermostat [Re: Merlin45] #1394116
02/27/13 08:50 PM
02/27/13 08:50 PM
Some of the original divorced choke spring assemblies had adjustable spring tension, pivot shaft rotated on its mounting, locked down with a nut and having an indexed scale for reference, primarily for fine tuning cold running mixture adjustments. The reissue/repo, Holley logo stamped into it, choke spring assembly that came with the MP 6-pack hardware kit I purchased was not meant to be adjustable, pivot shaft staked in a fixed position to its mounting bracket. Shaft can be forced to adjust if necessary then staked again.
Re: 440 6 Pack Electric Choke Thermostat [Re: JohnRR] #1394117
02/27/13 10:30 PM
02/27/13 10:30 PM
Merlin45 Offline OP
Merlin45  Offline OP
Where is the best place to buy this part? Do you have a part number? Just want to get the best and correct part to do this right the first time.
Re: 440 6 Pack Electric Choke Thermostat [Re: Merlin45] #1394118
02/27/13 11:16 PM
02/27/13 11:16 PM
Mopar Performance P4529185, looks like you can get at several places, Jegs has the best pictures of it.
Re: 440 6 Pack Electric Choke Thermostat [Re: 72roadrunnergtx] #1394119
02/27/13 11:35 PM
02/27/13 11:35 PM
People's Republic of Kali
70runner Offline
70runner  Offline
I did the mod designed by 72, very ingenious. Will be installing it shortly. I used an Airtex 2C1112 choke for the heating element parts, grafted onto the MP repro choke. I'm still playing around with the trigger circuit.
Re: 440 6 Pack Electric Choke Thermostat [Re: 70runner] #1394120
02/28/13 12:19 AM
02/28/13 12:19 AM
here is the circuit I used for the LM555 timer.
Re: 440 6 Pack Electric Choke Thermostat [Re: 72roadrunnergtx] #3213025
02/12/24 01:43 PM
02/12/24 01:43 PM
An update, still working as designed. More details here
https://youtu.be/uPoL9DZWsI8
