Re: Protecting Wires from headers
[Re: ADakotaRTGuy]
#1394064
02/26/13 09:41 PM
02/26/13 09:41 PM
Posts: 1,443 Maryland
Dads426
Maryland
I don' think the cermanic coating is going to help. Do you have a straight boot? If so, you may be able to bend the insert inside the boot to clear the header. Firecore will likely fix the wire or put a different boot on it if you send it back to him.
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
[Re: ADakotaRTGuy]
#1394065
02/26/13 10:49 PM
02/26/13 10:49 PM
Posts: 1,255 Columbus, GA
Michael Ecks
Columbus, GA
Buy a short roll of header wrap, wrap three or four times, or as many as you can around the tube in that area depending on the thickness. Metal zip ties on the end. Should do the trick.
First set of headers I had on my challenger literally had my Taylor wires sitting on the tube. Did something similar using a welders pad (ceramic wool material I think) and never had an issue.
"The happiness of your life depends upon the quality of your thoughts" ~ Roman Emperor Marcus Aurelius
[Re: ADakotaRTGuy]
#1394069
02/27/13 09:07 PM
02/27/13 09:07 PM
Posts: 12,129 Cleveland
sunroofgtx
Cleveland
Hello. If course we can fix the wire/boot. Can you please take a pic of the problem boot on the spark plug? I may have something else as far as boots to help. Thank you.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
