Re: To screw or not to screw?
[Re: gregsdart]
#1393670
02/26/13 01:49 AM
02/26/13 01:49 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Definately.
your going with still side walls so you will be running less pressure in the tires... the higher the pressure you run the less likelihood you would need the screws.... pressure holds the tire to the rim
[Re: rebel]
#1393672
02/26/13 02:02 PM
02/26/13 02:02 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
I had always run tubes & screws till I put my 1st Big engine in my dragster,nothing I could do would stop it from shaking the tires.I posted on every race site I could find asking for advice,a man up North told me on their dragster they had the same problem as mine. He said take the tubes & screws out and your problem will go away!I run 34.5x17-17 tires and I really did not want to try it,but it worked! NO TUBES,NO SCREWS,= NO SHAKE!
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: rebel]
#1393673
02/26/13 02:49 PM
02/26/13 02:49 PM
MR_P_BODY
my junk, 2950 with me, 1.29 60', 32x14 stiff sidewall, no tubes, no screws, worked ok for me for the past 4 seasons. mark the tire valve & watch for slippage, first day out they move a bit but by the 3rd meeting they've stopped & you're good to go full abuse.
I never worried about the slippage on the wheel(it did some) but being I run 6 3/4 - 7 psi max it doesnt like to hold real well to the rim... the first year I build my car I got sideways off the line and it pushed the sidewall off the rim.. trashed the tire and rim... that was no tubes or screws... now that I run tubes(better life of the tire) I screw them
[Re: MRMOPAR622]
#1393675
02/26/13 04:35 PM
02/26/13 04:35 PM
Guitar Jones
You probably could have just taken the tubes out and had the same result, I can't believe screws alone would do that. All the screws are doing is making sure the bead doesn't come off the wheel.
Beadlocks=expensive
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: 10.90 Racer]
#1393676
02/26/13 05:46 PM
02/26/13 05:46 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
No screws....... If you feel you need screws, then just go right to bead locks.......
No beadlocks, too many $$$ for a car that's only raced six or eight times a year. That's why I went with steel wheels instead of another pair of Welds, that and the fact that I'm a cheapskate too .
Thanks guys
[Re: dennismopar73]
#1393678
02/27/13 10:20 AM
02/27/13 10:20 AM
Posts: 9,996 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I have never run screws, all of my friends cars do not run screws, But if you decide to run them make sure they are in the rims before you have them balanced,, if you balance them,,I have never balanced my rears
Do you guys running without screws use a trans brake, and what weight car? After having seen a tire slip years ago I never gave it a second thought, especially with the brake and three speed plus the weight.
[Re: MRMOPAR622]
#1393679
02/27/13 11:41 AM
02/27/13 11:41 AM
Posts: 430 Michigan
HR3128
What air pressure are you running?
