Let's talk ProCharging
#1393611
02/25/13 11:30 PM
02/25/13 11:30 PM
Posts: 2,412 Weatherford, Texas
RapidusMaximus
Weatherford, Texas
I am considering installing a ProCharger on my stock cast crank, stock rod 1978 360. It has .030 over KB flat tops installed .005 in the hole, a Comp .526/275 hyd cam with 1.6 rockers. It also has IMM built 68cc RHS X heads, an Edelbrock Air Gap intake and MSD ignition. Don't know the head gasket thickness, got them from IMM and didn't measure the thinkness, compression should be approx. 10.3? I think. So, here's my questions and request for feedback...I know I will need a blow through carb and an upgrade to my fuel system...what am I missing? Is my compression ration too high? What say ye? Approx. Cost? Thanks in advance. BTW the way, the engine is already running and it runs good but it's just not fast enough... It's installed in this:
1968 Plymouth GTX 1974 Dodge P/U Long Bed Stepside 318 2019 Ram 2500 6.4, auto, 4WD
Re: Let's talk ProCharging
[Re: RapidusMaximus]
#1393612
02/25/13 11:46 PM
02/25/13 11:46 PM
Posts: 52,972 Romeo MI
MR_P_BODY
This is just my opinion... with the compression you you limit the boost you can run.... a inner cooler will help some... the cast crank isnt the best BUT can work with limited boost... the pistons wont like boost... these are just my opinions with the limited boost engines I have built.... I will tell you something that is FACT... you will NEVER be happy with a few pounds of boost... you might get away with 10# for a period of time BUT then you will say.... how about 14#...... JMO
#1393613
02/25/13 11:58 PM
02/25/13 11:58 PM
Posts: 7,506 Az
Crizila
Az
Suggest you start out by asking yourself how much HP you wanna make and then go from there. If you wanna use your existing block ( in stock configuration ), crank and rods, you will probably want to stay around 500HP max. Your CR should be in the 8.0 to 8.8 range, so the pistons you have won't work - nor will the cam ( you will need a cam with a minimum of 113 LSA. Blower, kit, fuel upgrades, carb, and engine changes I mentioned will put you in the 6 to $6500 range ( conservatively speaking ). The problem (IMO), it's too much $ for 500 HP. If you are gonna spend the $ to blow it, you will wanna make 700 HP or more. You can make 500HP cheaper by just making some changes to your existing NA motor. Just went through this whole scenerio recently. I started with 700HP as my goal and worked backwords - using a stock 79 360 block as my base. If you decide to go for 700HP, you can add and additional 3 -4K to the $6500 to try and make the block live at 700HP.
Fastest 300
[Re: Crizila]
#1393615
02/26/13 12:19 AM
02/26/13 12:19 AM
Posts: 6,146 Melbourne , Australia
LA360
Years ago a friend bought a Pro Charger kit from the Supercharger Store. It included everything he needed to install the system (Carb, fuel pump, fuel lines, meth injection, Blower, pulleys etc). He had a 360 that was factory except for the hydraulic camshaft, Weiland Xcellerator intake, headers and HEI ignition. The short lasted around 3 months. He wasn't keeping an eye on the boost at all. Only problem we had with installing the kit was the factory water pump pulley wouldn't clear the crank pulley. I had to make him a new billet pulley. I think also the blower crapped itself in the first week, which the Supercharger Store replaced no questions asked.
Alan Jones
#1393617
02/26/13 12:57 AM
02/26/13 12:57 AM
MR_P_BODY
Awesome ride BTW!
Thanks, BTW the engine should be making somewhere between 400-450 now and I would like to be around 600.
With about 5# you could make 600hp easy... sort of a waste of a blower
#1393618
02/26/13 08:51 AM
02/26/13 08:51 AM
Posts: 12,396 Taxes & Virus's R-US, NY
Dragula
I have some thick Flatout copper head gaskets you can use to lower your compression with your existing motor. You will just need taller alignment pins. Never used them, and was going to about the same thing. Perfect for this sort of thing.
[Re: Crizila]
#1393622
02/26/13 12:47 PM
02/26/13 12:47 PM
Posts: 7,506 Az
Crizila
Az
nuther pic - fuel system.
Fastest 300
[Re: Dragula]
#1393625
02/26/13 05:41 PM
02/26/13 05:41 PM
Posts: 833 MN
hemidup
MN
Looks like a Snow Performance water/meth controller. Above it looks like an anti syphone solenoid which is crutial part and good insurance when using w/m. I've know more than one person who has hydro locked there engine cause they didn't have the solenoid installed.
Jerry Williams.
[Re: hemidup]
#1393626
02/26/13 06:20 PM
02/26/13 06:20 PM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
Do you have E85 in your area? If so 10.3:1 isn't horrible if you keep the boost/timing in check. My iron headed 360 is about 9.2:1. It's been to 15psi on the street a few times (on accident when I was screwing around with the boost controller). If you keep the timing in check with E85 it can take quite a bit of boost/compression. For reference, mine has been 10.99@123mph on 8psi/22deg of timing with a 2.76 gear in a 3700lb car. Stock block, stock crank (didn't even turn it), stock rods (with good bolts), off the shelf forged pistons, home ported '308 castings, 224/218 hydraulic roller (.500"/.500", 114 lsa), with a swap meet POS single plane intake. Shift it at 5500, smoothest 10 sec. pass I've ever made. Boost is your friend...
[Re: dezduster]
#1393629
02/27/13 12:12 AM
02/27/13 12:12 AM
RapidusMaximus
Weatherford, Texas
Interesting thoughts, don't know if E-85 is available in my area or not...but its worth the thought. Thanks for all of the input guys...lots to think about, really makes you rethink your position when you realize you didnt build as much engine as you REALLY wanted...lol
