NOS 318: What to do? #1393555
02/25/13 10:18 PM
02/25/13 10:18 PM
Seattle, WA
W
waguy Offline OP
waguy  Offline OP
W
Seattle, WA
I just bought a military surplus 318 in a crate. It is date coded as built in 1977 and has the ho hum 4027163 heads. I am planning to drop it into my 64 Valiant 4 speed using the original (read restrictive) exhaust manifolds and 2.25 single pipe. I am on a tight budget so given those restrictions, tell me what would be the wisest upgrades to perform before installation? I don't want to spend money and time on upgrades that will never fully realize their potential. Thanks!!
PS It is a very cool motor with all of its peripherals attached (even the torque converter!)
Re: NOS 318: What to do? [Re: waguy] #1393556
02/25/13 10:22 PM
02/25/13 10:22 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
I would say first find out if that is an industrial motor or one that went in a car or truck. There might be differences that would keep some things from working with it. We used 318s to tow F-4 Phantoms with.
Re: NOS 318: What to do? [Re: 71birdJ68] #1393557
02/25/13 10:32 PM
02/25/13 10:32 PM
Columbus, GA
Michael Ecks Offline
Columbus, GA
I am completely unfamiliar with industrial 318s, but that is a possibility there could be differences. If it turns out to be a normal car/truck engine I would plan on replacing the valve springs since some have been sitting in a closed/compressed position for 26 years or so. An edelbrock performer 4 barrel intake and carter afb or tquad (AFB is easier to rebuild IMHO) can both be picked up cheap on ebay. Combined with an edelbrock performer cam (match springs to cam) or summit racing equivalent would be a great motor in a light car for not a lot of money.
Just noted you said four speed. You'll need to check out the pilot bushing bore in the end of the crank to make sure it will work with your 4 speed input shaft. It may not be finish machined for one, or in the case of my 360 it was drilled too far off center, in that case you'll have to pull the crank and take it to a machine shop. Or cut a small amount off the input shaft and use a conversion pilot bushing that sits in the torque converter bore area.
Re: NOS 318: What to do? [Re: Michael Ecks] #1393558
02/25/13 10:45 PM
02/25/13 10:45 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
I'd throw a mild cam in it (stock 340 cam comes to mind) and new springs.
Re: NOS 318: What to do? [Re: 71birdJ68] #1393559
02/25/13 10:45 PM
02/25/13 10:45 PM
Seattle, WA
W
waguy Offline OP
waguy  Offline OP
W
Seattle, WA
I am fairly certain that it is a truck motor - it came with truck motor mount brackets in the crate. The casting number is:
4006730 - 318 - 2
The front of the block is stamped:
7m318 03305566
I like the idea of a simple intake and cam swap. But the idea of swapping heads and pistons starts to make the "new" engine look like a rebuild.
Re: NOS 318: What to do? [Re: waguy] #1393560
02/25/13 10:58 PM
02/25/13 10:58 PM
Columbus, GA
Columbus, GA
An intake and cam will go a long way for you. No need to go overboard on either since a stock valve 318 won't move that much air. A common performer intake should be fine instead of a pricier Air-Gap or RPM manifolds. Do those couple of things without having to get majorly into the internals and enjoy the heck out of it.
One more thing, check out the oil pan style. If it is a truck motor it will require changing to a passenger car pan, also cheap to pick up at a junkyard or ebay.
Not to disrespect the 318 crowd, but if you reach a point where you want bigger valves and higher compression pistons etc, sell off the 318 and start with a LA or Magnum 360 as a core since originality isn't a concern.
Re: NOS 318: What to do? [Re: waguy] #1393561
02/25/13 11:08 PM
02/25/13 11:08 PM
Cam change & thermoquad. I'd mod the dist subsystems initial/total(35)/springs/vac adv IN ORDER but that would come when it's up & running
Re: NOS 318: What to do? [Re: RapidRobert] #1393562
02/26/13 12:00 AM
02/26/13 12:00 AM
Seattle, WA
W
waguy Offline OP
waguy  Offline OP
W
Seattle, WA
Thanks for all the responses!
Re: NOS 318: What to do? [Re: waguy] #1393563
02/26/13 09:44 AM
02/26/13 09:44 AM
Chicago illinois
ChinooK440 Offline
ChinooK440  Offline
Chicago illinois
A complete teardown/inspection for internal rust,dust and critters. etc. would be the first thing i would do.
37 years is a loooong time to be sitting around.
Re: NOS 318: What to do? [Re: ChinooK440] #1393564
02/26/13 10:38 AM
02/26/13 10:38 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
budget? used performer intake and 600 cfm carb....
this cam kit
http://www.summitracing.com/parts/sum-k50052/overview/make/dodge
comp #901 springs
2017 Grand Cherokee Overland
Re: NOS 318: What to do? [Re: patrick] #1393565
02/26/13 01:34 PM
02/26/13 01:34 PM
Seattle, WA
W
waguy Offline OP
waguy  Offline OP
W
Seattle, WA
I am really encouraged by all the input! The motor was kept in a pallet sized injection molded crate for it's life up 'till yesterday. All of its' openings have factory plastic plugs in them so I don't have huge concerns about the internals (but I'll check!) Keeping it within budget is looking very do-able - thanks again!!
Re: NOS 318: What to do? [Re: waguy] #1393566
02/26/13 02:02 PM
02/26/13 02:02 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
How about keeping it the way it is, or sell it to someone doing a military vehicle, and by a juck yard motor. Remember they are in that condition only once.
Re: NOS 318: What to do? [Re: 71birdJ68] #1393567
02/26/13 04:05 PM
02/26/13 04:05 PM
Maryland
wally426ci Offline
wally426ci  Offline
Maryland
Maybe spray some penetrant into the plug holes and turn it over by hand a little at a time for a few days. Prime the oil pump really well before hand as well?
Re: NOS 318: What to do? [Re: wally426ci] #1393568
02/26/13 06:33 PM
02/26/13 06:33 PM
Seattle, WA
W
waguy Offline OP
waguy  Offline OP
W
Seattle, WA
She's still pretty well lubed (go figure?) I noticed that there is an International Harvester emblem cast into the block near the timing chain and at the rear. Did they contract with Chrysler for some casting duty?
Re: NOS 318: What to do? [Re: wally426ci] #1393569
02/26/13 06:35 PM
02/26/13 06:35 PM
dogdays Offline
dogdays  Offline
For things to do:
1.IF YOU DO NOTHING ELSE, recurve the distributor. The stock curve is slow and a simple recurve will really wake the engine up with no other changes.
2. If you have a little more money, add a 4-barrel carb and intake. IT DOESN'T MATTER WHICH ONE! Anything is better than the stock 2-barrel. 273, 318, 340, 360? OK. Q-jet, Holley, AFB, AVS? OKAY!
3. If you have even a little bit more money, swap in a 360 2-barrel camshaft. It's brilliant, you use the stock timing chain, gears, valvesprings, pushrods, etc etc etc. Or any other cam with around 0.400" lift and around 190 - 204 degrees duration. That 318 cam is the wimpiest camshaft known to man. Yet, the 360 cam will work with all the other stock parts and give you a little bump. And the stock springs and low-lift cam will make break-in less risky.
4. To top it off, hook the stock exhaust manifolds up to duals. Again, IT DOESN'T MATTER WHIC! anything around 1 7/8 or larger will help uncork the exhaust.
I used to keep the stock single exhaust crossover, then TEE in to it somewhere under the driver's feet to run the second pipe back. Presto! Changeo! you have duals with an H-pipe!
Now, to accomplish all of this you need to grit your teeth, put in earplugs and put earmuffs on top of them, because it is ohsoeasy to tell someone else how to spend their cash. But my plan will work.
R.
Re: NOS 318: What to do? [Re: dogdays] #1393570
02/26/13 10:00 PM
02/26/13 10:00 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
I'd invest in a good double roller, seeing as it still has the alum-plastic deal...
Re: NOS 318: What to do? [Re: buildanother] #1393571
02/26/13 11:12 PM
02/26/13 11:12 PM
Harrisburg Pa. 17112
moparmikethree Offline
I once saw alot of Ford 302 crate motors at the federal surplus.
How much did that 318 cost?
Re: NOS 318: What to do? [Re: moparmikethree] #1393572
02/26/13 11:36 PM
02/26/13 11:36 PM
west palm beach, florida
modelmakerinc Offline
cant tell from the pics but if it is/was a truck motor then you will need to swap the oil pan and pickup for a car style.
Trucks are rear sump, cars are center sump
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: NOS 318: What to do? [Re: buildanother] #1393573
02/26/13 11:39 PM
02/26/13 11:39 PM
Seattle, WA
W
waguy Offline OP
waguy  Offline OP
W
Seattle, WA
I am quickly zeroing in on some great options! Turning the motor over by hand made the rocker arms move the valves so slightly that you have to wonder? The double roller chain is sitting on my shelf.
Dodgdays, I have a guy with a distributor machine re-curving one for me as I write this.
Re: NOS 318: What to do? [Re: waguy] #1393574
02/26/13 11:45 PM
02/26/13 11:45 PM
Columbus, GA
Columbus, GA
If it has never been started it probably has no oil in the hydraulic lifters at all making them very soft.
In addition to my recommendations, I will second buildanother's suggestion about a new timing set. Unless it is some kind of heavy duty engine it probably does have the cam sprocket with nylon teeth. Even just sitting, that nylon has probably gotten brittle after all these years.
