Removing the oil filler plug in MT valve covers??? #1393172
02/24/13 11:26 PM
02/24/13 11:26 PM
Blairsden, CA
Triggerfish Offline OP
Blairsden, CA
Just picked up a set of Mickey Thompson vintage valve covers (no logo) & need to remove the plug where the oil filler cap goes.
Do I just punch it out with a hammer or drill it out? Inside looks
like there's two slots that a screw driver will fit it. I tried punching them, but no luck. These covers are pretty much the same as the mopar performance covers. Here's a pic of the outside & I'll post a pic of the inside in a few.
Re: Removing the oil filler plug in MT valve covers??? [Re: Triggerfish] #1393173
02/25/13 12:04 AM
02/25/13 12:04 AM
St. Charles, MO
wingman Online happy
Uncreative Title
wingman  Online Happy
Uncreative Title
St. Charles, MO
Drill it out. It can be puched out, but you will not like the rough, irregular hole it leaves.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: Removing the oil filler plug in MT valve covers??? [Re: Triggerfish] #1393174
02/25/13 12:05 AM
02/25/13 12:05 AM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
I would use a step dril until you get to the size you need.
Re: Removing the oil filler plug in MT valve covers??? [Re: Triggerfish] #1393175
02/25/13 12:13 AM
02/25/13 12:13 AM
Columbus, GA
Michael Ecks Offline
Columbus, GA
Triggerfish, those are the coolest looking valve covers ever! I've seen similar ones with no logo, but never with the fins running all the way across them.
Not to hijack your thread, but do you happen to know if yours have the long rectangular recessed area inside where "holley - mickey thompson" is usually stamped or cast in?
I ask because I have a set exactly like these on ebay in the garage back home. Ebay Holley M/T valve covers (not my auction - just for reference) And I was wondering if there was enough material left to machine off all the fins, M/T letters, and the long raised rectangular pad on the outside and just make them smooth. I was thinking about going with fabricated sheet metal ones on my motor but I don't like the unfinished welds on all of them. Though they might look cool and different with smoothed tops and the blockier look to them.
Did find this on a brand X forum for you. Looks like actually knocking out the "knock out plugs" is frowned upon. I was going to guess if they were vintage they might be more prone to cracking from an impact than new ones also.
M/T valve cover topic on nastyz28.com
Ummm... ahem, wouldn't want to trade would you? Awesome find on those.
"The happiness of your life depends upon the quality of
your thoughts" ~ Roman Emperor Marcus Aurelius
Re: Removing the oil filler plug in MT valve covers??? [Re: Michael Ecks] #1393176
02/25/13 12:51 AM
02/25/13 12:51 AM
Blairsden, CA
Blairsden, CA
These have no logo or stampings on the outside, only the fins. On the inside, there's a long rectangle with DODGE 3390384 & under that
it says MICKEY THOMPSON made in japan.
I had a pristine set of polished Cal Custom finned covers with no logos & the fins wrapped around the ends, too. Almost the same as these. I wanted the stock look of my orig covers, but after 3 R&R's to stop them from leaking, I'm using these since these won't warp.
I don't think my Power Wagon's 383 is custom enough for your fabricated ones, so I'll stick with these. It'll be a lot of machining if you want to remove the fins.
Re: Removing the oil filler plug in MT valve covers??? [Re: moparpollack] #1393177
02/25/13 01:00 AM
02/25/13 01:00 AM
Blairsden, CA
Blairsden, CA
I'll try to find one. I shoulda drilled em before I just painted them.
Here's a pic of the inside.
Re: Removing the oil filler plug in MT valve covers??? [Re: Triggerfish] #1393178
02/25/13 01:07 AM
02/25/13 01:07 AM
Columbus, GA
Columbus, GA
Hunh... From that inside pic it doesn't look like the rectangle on the inside of yours is recessed at all. From memory the ones I have, and it looks like the ones I linked to on ebay, that rectangle on the inside is recessed a good 3mm or so. Guess I'll have to do some measuring on the material thickness when I get home before I start grinding on them.
I could almost live with the M/T lettering, but the long flat rectangle on the outside looks hideous to me. Who would ever engrave something on their valve cover assuming that is its purpose???
There is a set of Cal's up on ebay now too, offys too, and I had long ago the imitation ones with the blank rectangle in the middle of the fins, all have the rounded edges with fins going down the sides like the current MP ones. I like these way better.
Re: Removing the oil filler plug in MT valve covers??? [Re: Triggerfish] #1393179
02/25/13 01:08 AM
02/25/13 01:08 AM
Russ H. Offline
Russ H.  Offline
A hole saw equal to that inside diameter should work nicely.
Re: Removing the oil filler plug in MT valve covers??? [Re: Michael Ecks] #1393180
02/25/13 01:09 AM
02/25/13 01:09 AM
Blairsden, CA
Blairsden, CA
I like the fins on the end's too, but found these yesterday on C-list & had to get them. Here's a pic of the inside stampings.
Re: Removing the oil filler plug in MT valve covers??? [Re: Triggerfish] #1393181
02/25/13 01:10 AM
02/25/13 01:10 AM
Blairsden, CA
Blairsden, CA
another outside pic
Re: Removing the oil filler plug in MT valve covers??? [Re: Triggerfish] #1393182
02/25/13 01:11 AM
02/25/13 01:11 AM
Blairsden, CA
Blairsden, CA
Here's what they're going in..
Re: Removing the oil filler plug in MT valve covers??? [Re: Triggerfish] #1393183
02/25/13 01:38 AM
02/25/13 01:38 AM
Cab_Burge Online work
Cab_Burge  Online Work
Try using a sharp edge and score around the knockout several times until it penitrates a little and then gently try knocking them out Actually knock them into the covers, not out You can smooth them up with a die grinder and a carbide aluminum bit
Re: Removing the oil filler plug in MT valve covers??? [Re: Michael Ecks] #1393184
02/25/13 01:41 AM
02/25/13 01:41 AM
Blairsden, CA
Blairsden, CA
Michael, I just noticed the link you provided & glad I clicked on it.
I'll have a friend drill it out at his shop. Much appreciated.
Re: Removing the oil filler plug in MT valve covers??? [Re: Cab_Burge] #1393185
02/25/13 01:16 PM
02/25/13 01:16 PM
Blairsden, CA
Blairsden, CA
Thanks Cab. I'll do that with a razor knife & my dremmel. I noticed when I whacked the inside edge with a screwdriver, I could see it almost poked thru, so looks to be thinner metal on the plug.
Re: Removing the oil filler plug in MT valve covers??? [Re: Cab_Burge] #1393186
02/26/13 11:48 AM
02/26/13 11:48 AM
Blairsden, CA
Blairsden, CA
Cab, thanks for the advice. I drilled a large hole in the center & took a few files to it. With a little elbow grease, I hade it perfectly round & smooth in about 10 minutes. Its an easy fix for anyone who wants to open the holes in their MP covers.
Re: Removing the oil filler plug in MT valve covers??? [Re: Triggerfish] #1393187
02/27/13 12:04 AM
02/27/13 12:04 AM
Columbus, GA
Columbus, GA
Came out good. Glad you didn't whack it with a hammer and a punch! I'll remember all of this when I pull mine out of storage soon.
Re: Removing the oil filler plug in MT valve covers??? [Re: Michael Ecks] #1393188
02/27/13 02:24 AM
02/27/13 02:24 AM
Blairsden, CA
Blairsden, CA
A quality file goes thru the aluminum pretty fast & the curved surface of the file matched the curve of the hole pretty well.
Only bummer (& glad I didn't trade you), is the covers had cracks
around the lower corner mounting holes. I thought the lower corners
were epoxied on the inside to maybe help keep oil from pooling there, but it was to seal the cracks. I installed em anyway, but may have to tig weld them if they start leaking.
Re: Removing the oil filler plug in MT valve covers??? [Re: Triggerfish] #1393189
02/27/13 02:51 PM
02/27/13 02:51 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Is there a baffel screwed inside the valve cover for your PCV valve?
Re: Removing the oil filler plug in MT valve covers??? [Re: Triggerfish] #1393190
02/27/13 03:24 PM
02/27/13 03:24 PM
Columbus, GA
Columbus, GA
Hopefully the epoxy already there will stop any leaks. As for a trade, I realized halfway through the making of this thread that you have BB covers and I was looking at SB ones. I did see a set of BB covers with fins all the way across like yours on Ebay. But I don't think they were ever made that way (the M/T style at least) for small blocks, so I am still looking at maybe having the fins and M/T lettering machined off mine to make them smooth, kinda like viper valve covers.
I think yours came out great, will post some pics of mine someday when I manage to get them out of storage and start working on them.
Re: Removing the oil filler plug in MT valve covers??? [Re: Michael Ecks] #1393191
02/28/13 02:14 AM
02/28/13 02:14 AM
South Coast of Oregon
dweller Offline
dweller  Offline
Source for grommets for this style valve cover?
