A body rear offset ? #1393004
02/24/13 06:29 PM
02/24/13 06:29 PM
LONG ISLAND
fishy340 Offline OP
fishy340  Offline OP
LONG ISLAND
I just measured mine and the pinion is 2" offeset,does that sound correct? Just double checkin w you guys. Thanks AndyB
Re: A body rear offset ? [Re: fishy340] #1393005
02/24/13 07:15 PM
02/24/13 07:15 PM
That sounds close, how much offset is the trans tunnel Where did you take your measurements from?
Re: A body rear offset ? [Re: Cab_Burge] #1393006
02/24/13 11:05 PM
02/24/13 11:05 PM
LONG ISLAND
fishy340 Offline OP
fishy340  Offline OP
LONG ISLAND
Well im seeing 1 3/16" as being the offset in moparts tech and google.When we measured, it looked like 2"....so that almost 3/4" off and i wanna be sure.
Re: A body rear offset ? [Re: fishy340] #1393007
02/24/13 11:21 PM
02/24/13 11:21 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
On an 8.75 the axles should be same length
D60 driver side should be 1 3/8" longer than pass side for proper offset.
The offset I always set up is about 1 3/16, IIRC
Re: A body rear offset ? [Re: RobX4406] #1393008
02/25/13 12:38 PM
02/25/13 12:38 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
Stole this pic from a tti fitment thread
