Chrysler Sebring LXI #1392990
02/24/13 05:57 PM
02/24/13 05:57 PM
St Leonarc Md
stormer41 Offline OP
St Leonarc Md
Wondering if anyone can help me.
My wife has a Sebring that started having problems today.
She took it to Autozone and had them hook it up the computer.
she had 2 codes P03040 which says Cam shaft sensor defective
and P13191-timing belt or chain stretched or jumped
Defective CMP sensor.
Tried to find the cam shaft sensor online. Could not find one, so I called Autozone and the guy tells me that her car does not have a cam shaft sensor. This is uncharted territory for me. Like to have the advice of the more knowledgeable brethren before I go and throw a lot of money on this car. Any advice would be helpful.
Proud owner of a 1991 Dodge Ramcharger LE 2wd.
Re: Chrysler Sebring LXI [Re: stormer41] #1392991
02/24/13 06:07 PM
02/24/13 06:07 PM
missouri, USA
moparmojo Offline
moparmojo  Offline
missouri, USA
Best to get to a dealer to determine. Autozone is good for basic stuff but I would have a qualified professional look it over.
Re: Chrysler Sebring LXI [Re: stormer41] #1392992
02/24/13 06:08 PM
02/24/13 06:08 PM
Virginia
HemiStan Offline
HemiStan  Offline
Virginia
About a year ago, my 2001 Sebring LXI started running erratic. It also had a code for camshaft position sensor.
I bought one from Advance Auto ($25?) and installed it myself. I bit hard to reach and about an hour to do.
Stan
Re: Chrysler Sebring LXI [Re: stormer41] #1392993
02/24/13 06:11 PM
02/24/13 06:11 PM
Fitchburg,Massachusetts
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
How many miles and has the timing belt been changed?
Re: Chrysler Sebring LXI [Re: MPerry] #1392994
02/24/13 06:12 PM
02/24/13 06:12 PM
Virginia
HemiStan Offline
HemiStan  Offline
Virginia
What year Sebring and what engine?
Re: Chrysler Sebring LXI [Re: MPerry] #1392995
02/24/13 06:57 PM
02/24/13 06:57 PM
St Leonarc Md
St Leonarc Md
163000 and as far as I know the timing belt has not been changed
Re: Chrysler Sebring LXI [Re: HemiStan] #1392996
02/24/13 06:58 PM
02/24/13 06:58 PM
St Leonarc Md
St Leonarc Md
2000 2.7 v6
Re: Chrysler Sebring LXI [Re: stormer41] #1392997
02/24/13 07:06 PM
02/24/13 07:06 PM
St.Louis,Mo.
70RR383 Offline
70RR383  Offline
St.Louis,Mo.
Google is your friend
Re: Chrysler Sebring LXI [Re: stormer41] #1392998
02/24/13 07:15 PM
02/24/13 07:15 PM
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
2.7 should be a chain. Better get it checked they have been known to have issues.
Re: Chrysler Sebring LXI [Re: MPerry] #1392999
02/24/13 07:49 PM
02/24/13 07:49 PM
Virginia
HemiStan Offline
HemiStan  Offline
Virginia
Re: Chrysler Sebring LXI [Re: HemiStan] #1393000
02/24/13 09:20 PM
02/24/13 09:20 PM
ST clair shores MI
moretoys Offline
moretoys  Offline
ST clair shores MI
Yes it has a cam sensor. Have you had some engine noise?? I'm guessing you have an extended crank before it starts??does it run ok after started??If you just have a long crank,cam sensor might fix it.if it runs funny,low power,timing chain probably jumped a tooth,especially if there was/is engine noise. chain jump= lot's of money to fix.parts and time.multiple chains,guides,tensioners,water pump. alittle more info on what's it doing would help.
