What bolt for a Fluidampr
#1392882
02/24/13 02:58 PM
02/24/13 02:58 PM
Posts: 4,288 Danville, NH
Mopar_Mike
Danville, NH
I am using a fluidampr damper and the factory crank bolt is too short. Do just get a longer one? I did not see any being sold with the damper. Thanks.
RS23L7 4-Speed
Re: What bolt for a Fluidampr
[Re: AndyF]
#1392885
02/24/13 04:57 PM
02/24/13 04:57 PM
Mopar_Mike
Danville, NH
I have the factory 1.25" bolt which is too short. The damper is on as far as I can get it (tapping it on). From what I see out there, the 2.25" seems like the one to get..?
RS23L7 4-Speed
[Re: Mopar_Mike]
#1392886
02/24/13 07:41 PM
02/24/13 07:41 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
Did you heatup the damper in boiling water befor installing it? I have used a longer bolt to get it started then switch them to finish,torque.your hub may be to tight on the crank also and you may need it sized.Have you ever used this damper?
[Re: rickraw]
#1392888
02/24/13 08:03 PM
02/24/13 08:03 PM
Mopar_Mike
Danville, NH
The damper is used, it came off a 440 and I am using it on my eagle crank.
RS23L7 4-Speed
