Re: tire pressure gauge
[Re: WHITEDART]
#1392862
02/24/13 02:28 PM
02/24/13 02:28 PM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
I use the big Moroso one, 89552. I also have a big face Intercomp and yet a third Intercomp for front tires. They all work great but two different front wheels on the cars and needed a second gauge to get into the front wheels on the small tire car.
[Re: MRMOPAR622]
#1392864
02/24/13 03:37 PM
02/24/13 03:37 PM
Triple Threat
Renton Washington
Not if you go digital. Mine the Moroso 89576 0-100 psi, reads to the tenth of a pound and is LED backlit for easy use at night.
[Re: MRMOPAR622]
#1392865
02/24/13 03:37 PM
02/24/13 03:37 PM
dartman366
Mt. Vernon, Ohio
Like Al said you just about have to have 2 gauges one for the front one for the rear.I like to use a rear gauge that only registers 15 lbs so I can fine tune the rear pressure in 1/8-1/4 lbs as for the fronts one lbs readings are close enough.Just good quality gauges,all you need to know is what pressure your tires work best set at by the gauge you are using,I like to always use the same gauge.I stay away from the lastest trick of the week gauges!
I use a cheepo rebco for the rears it appears to be accurate compared to others but once you get one then stick with the same one, but I know if I lose/misplace mine then my buddies moroso reads the same as mine.
