2006 Ram Deisel stock injectors, good or bad?
#1392663
02/24/13 01:00 AM
02/24/13 01:00 AM
Posts: 43,252 Bend,OR USA
Cab_Burge
I had a local guy tell me that he had heard and seen the stock injectors(2004 and later) go bad after 80,000 miles or more. My truck is a 2006 Ram 3500 with 96,000 miles on it and the mileage is down from where it has been in the past, he says the injectors will start leaking and over flow into a bypass tube I have seen stains in my driveway under my truck that I don't know where they come from, I assumed that they where oil stains coming out of the little breather pipe in the front of the motor
Re: 2006 Ram Deisel stock injectors, good or bad?
[Re: Cab_Burge]
#1392664
02/24/13 11:15 AM
02/24/13 11:15 AM
Posts: 8,030 Tulsa OK
Bad340fish
Tulsa OK
When I was in the market for a used truck recently I really wanted a cummins truck. I found one I liked and had it checked out by a reputable shop and customer of ours at work. He did what he called an injector balance test and said it needed the injectors replaced. This truck had 100ishK miles if I remember right. He told me don't be surprised, most of them need injectors at this mileage unless they have been maintained perfect or have a better fuel filtration setup on them.
For this shop to replace the injectors and provide warranty he wanted about $4000 IIRC. That included cleaning the entire fuel system tank and everything. Aftermarket fuel pump and filtration setup, and new injectors. It sounds insane but this guys shop only works on Cummins, Powerstroke, and duramax trucks. He has a line out the door and its all three brands filling his shop and parking lot.
If you get on the truck hard and then let off does it keep going for longer than normal? This truck would take a bit to really slow down if you were wide open then shut it down. Supposedly the bad injectors leak fuel until the rail pressure comes down and that causes the throttle to "hang" if you will. Thats how I understood it.
I drove a few trucks and they all showed the "signs" he wanred me of and that I had read on the internet(had to be true right lol). The common rail trucks will hang the throttle real bad when leaky injectors leak while the high rail pressure comes down after WOT.
I bailed out and went gas motor, the diesel was a want way more than a need so I went with a hemi truck. I second guessed my decision yesterday as I was changing 16 spark plugs on my new to me truck lol.
68 Barracuda Formula S 340
[Re: Cab_Burge]
#1392665
02/24/13 11:36 AM
02/24/13 11:36 AM
Posts: 147 Kansas
cascius
Kansas
This is a lot more common with the 2003-early 2004 trucks, but it does happen quite frequently with the later trucks as well. The main problem with the early trucks was the material the needle inside the injector. After time exposed to the high pressure fuel it would erode away and not seat properly. This would cause numerous issues including runoff as described in the other post. The shop I used to work at had lots of issues with these, and on average they came in right around 100K. Some of the earlier trucks had an extended warranty from the factory so these issues were covered and would be replaced from the dealer. This was a mistake on Bosch's part. It's the same problem that the 01-04 Duramax's suffered from and GM actually stepped up and extended their warranty to 7 year, 170K in order to take care of their customers.
Any year common rail is a target for this problem. On average, the injectors can be found from a reputable source (Not the dealership) for around $300-350 a piece. I would think someone who has never done a set before, with a little guidance could easily do this in an afternoon. After working on nothing but Cummins trucks for about 3 years I can do a set in about an hour. They are not complicated by any means, just tedious work that needs a little attention to detail.
As far as any stains you are seeing, unless there is an external leak which you would smell or see, it is not fuel. When they injectors go bad and the return rates are high, the fuel is returned to the fuel tank. Good filtration is the key to making them live.
On your mileage concern, there are a lot of variables there that could come in to play. I would check absolutely everything before I worried about putting a set of injectors in it.
[Re: cascius]
#1392666
02/24/13 12:23 PM
02/24/13 12:23 PM
Posts: 43,605 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
As most on here know I blew-up two Cummins trucks, a 2004 with the 305 555 and an 05 with the 325 600. Both were injector issues. The 04 had an injector go wide open and hydraulic the engine throwing a rod. Right before it happened it was blowing white smoke and fuel was actually leaking out of the intake gaskets! The 05 an injector went dead while I was pulling an 18K load up a mountain in Arizona. That one burned a hole clean through a piston. I had just got through replacing four of the six injectors in the 04, shoulda done them all. Four 4 injectors and cleaning the system it was $3200 at a shop in Vegas. The main issue is cleanliness. The 05 truck had 205K miles on it and as far as I could tell only had the fuel filter changed maybe twice. After replacing the engine in the 04 I have changed the fuel filter after every other oil change and put injector cleaner in a full tank of fuel every third fill-up. I plan on keeping this one for life.
JB Rhinehart, Realist
A-Body's RULE!
[Re: Rhinodart]
#1392667
02/24/13 07:09 PM
02/24/13 07:09 PM
Cab_Burge
Thanks to all of you for the help my trucks is not showing the slow tol et off symptoms, yet I'll go test it the next time I drive it and see As far as the fuel mileage I towed my 24 Ft Pace enclosed trailer 1300 miles one way to Tuscon,AZ with my old Duster in it at more than the posted speed limit most of the way The wind was blowing, it was cold and the heated seat where on most of the way, it averaged 10.78 MPG going down and I haven't figure out the return milage yet I have been negligent in changing the fuel filter, I've changed it twice so far I do buy most of the deisel fuel at a local station that pumps a bunch of fuel everyday, two big tankers a day usually, so hopefully that helps. It will get change more often now Thanks again to all Cab
[Re: Cab_Burge]
#1392668
02/24/13 08:11 PM
02/24/13 08:11 PM
Posts: 522 Lenox Iowa
MMiller
Lenox Iowa
I advise changing the fuel filter every oil change or at the least every other oil fitler change. Yes it adds to the price of service, but if it can extend the life of the injectors its worth it. I also do not buy filter from the parts stores, there are places to buy filters from in bulk for a lot less money then buying them when necessary from the parts store. A fuel additive like Howes Lubricant or Power Service, or purchasing a Biodiesel(preferably Soydiesel) will help lubricate and extend the life of the injectors that have very tight tolerances inside them.
Old Caterpillar Equipment used to say "Buy Clean fuel, Keep it clean" on the fill cap. Its more of a necessity then it ever was back then.
Michael
93 W250 CTD getrag, Bosch 185 injectors, AFE air filter. Trailer puller, daily driver, 90 W250 CTD 727 with smokin 5" stacks. Off road truck
75 Dodge W200 440 4spd 4x4 locked front and rear, twin disc clutch, E85. Pulling truck
[Re: J_BODY]
#1392672
02/25/13 12:25 AM
02/25/13 12:25 AM
Posts: 18,426 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
There's a 15K service interval for a reason. Cummins/Fleetguard/Mopar filters all the way!
Exactly. No need to change fuel filters at every oil change. My fuel pressure gauge would tell me if my filtering is being restricted.
[Re: 71yelladustr]
#1392675
02/26/13 03:08 PM
02/26/13 03:08 PM
Cab_Burge
I drove my truck last night and it seems to not stop accelerating immediatly when I let off, maybe keeps going for a 1/4 to 1/2 second Is this a sign of bad injectors or just me being hyper sensitive BTW, do these trucks have electric or manual throttles actuators?
[Re: Cab_Burge]
#1392676
02/26/13 04:13 PM
02/26/13 04:13 PM
Posts: 1,035 Missouri U.S.A.
71yelladustr
Missouri U.S.A.
The throttle is drive by wire. Not mechanical. You may be jumping the gun about thinking your injectors are shot. I wouldn't be too worried as long as you dont have any issues with it starting, missing, odd fuel related knocking noises from the engine, or white smoke coming from the exhaust. There is no set mileage that the injectors give up. There are different parts of the injector to fail also. The nozzles can crack, The nozzles can get stopped up with crud in the fuel, the solenoid can fail, etc.... That being said, The injectors will not last forever. It all depends on fuel quality, how its driven, and modifications to the fuel system as to how long they last. The best thing you can do for you injectors is to keep CLEAN fuel in your tank, Use a GOOD fuel filter, and do not idle the truck excessively.
392 gen III hemi on E-85 727 trans Dana 60 10.02@134
[Re: copchaser]
#1392678
02/27/13 03:21 PM
02/27/13 03:21 PM
Triple Threat
Renton Washington
My dads early 04, 305/555 is now experiencing a hot start issue. As in, it wont restart hot. When it is cold it seems to crank longer than necessary, but always fires up. We replaced the FAC already on the injection pump.
Starting to think its the injectors, truck has 90K miles and had the pump update done by the dealer, under warranty.
Any thoughts? I have browsed a number of forums and no one seems to have a good answer.
[Re: Triple Threat]
#1392680
02/27/13 04:30 PM
02/27/13 04:30 PM
Posts: 147 Kansas
cascius
Kansas
One thing you might check is the nuts that hold the crossover tubes in the head. If they are not torqued properly they can cause a pressure leak and cause the symptoms you are describing.
