Re: 15 + volts at the battery??
[Re: Crocker]
#139261
10/20/08 08:11 PM
10/20/08 08:11 PM
RapidRobert
Was the auto electric shop guy wrong about the alternator? Can it cause a overcharge problem on it's own? What other possibilities? Thanks Glenn
1st Q no 2nd Q no. try a jumper wire from the VR body to good ground and do you have another known good(fully charged) battery you could drop in. EDIT if not either then time to grab the VOM & start checking voltage drops while you are running at a fast idle MORE EDIT you picked up a NEW vr
[Re: RapidRobert]
#139262
10/20/08 08:48 PM
10/20/08 08:48 PM
Actually "Rapid" that may not be correct.
WHAT YEAR is the regulator/ alternator?
If you have the later (70 and later) regulator, IT COULD BE the alternator causing the problem, IE one end of the field could be shorted to ground, or the regulator side brush could have become shorted to ground
If you have the 69 and earlier, it's either the regulator, or a poor ground between the regulator and body OR
poor supply voltage to the regulator (ignition terminal)
FIRST QUESTION: WHAT YEAR is the regulator??? 69/earlier, or '70/ later?
You guys don't want to do this, but---you've replaced the regulator, so it's probably OK
Take a meter----
With the car running at high idle--simulating "low/med cruise"
stab one meter probe DIRECTLY onto the regulator body. Stab the other probe DIRECTLY onto the battery neg. post.
With the car running as above, You want THE LOWEST possible reading, NOT MORE than .5 (1/2) volt, and the less the better. Higher shows poor ground between the regulator/ body/ engine/ battery.
SAME THING with the ignition feed to the regulator.
Stab one probe DIRECTLY onto the batt. pos. post. Stab the other to the ign1 feed to the regulator/ ballast. AGAIN you want the LOWEST possible reading, a few tenths or less NOT MORE that 1/2 (.5) volt at the very most. More than this shows a drop somewhere--corroded wiring, connections, bad bulkhead connector, bad connections at the ign switch, or a bad switch itself. Could be bad connections through the bulkhead going to the ammeter, loose connections to the ammeter itself, or even a bad "permanent" splice in the harness itself--I found this on at least three cars "back in the day"
[Re: Crocker]
#139264
10/21/08 12:37 PM
10/21/08 12:37 PM
It's the 72 and up (or square back )alternator. The volt regulator is one I picked up from Napa yesterday for $14. I am assuming it's the 70 and later one. Both screws holding the Volt regulator to the firewall were stripped in the holes. I will work on the ground this evening. If it's not that maybe a new alternator Glenn
We still don't know what you are working on. What year is the car? If the regulator has push on plug, it's the 70/later electronic. If you have one screw connection, you have the older 69/earlier system.
THE ONLY WAY a 70/ later two terminal alternator could cause this problem is if there's a short in one brush or the rotor. The way to check this is to simply pull the field connections off, one at a time. If either one or both STOPS the charge, then it is OK--that shows that the control is at the regulator.
If you have the 69/earlier system, one field terminal will be grounded. That is, the correct early alternator only has one field wire.
Throwing parts at it rarely solves these problems.
#139265
10/21/08 01:23 PM
10/21/08 01:23 PM
if the field wire going to the VR (not the system voltage wire) is shorted to ground between the alt and the VR, OR if the VR itself is sending that wire to ground (because of low system voltage or because its faulty), the alt will over charge.
so, if its a 70 or later, theres 2 field wires. one is blue and the other green. the blue is the 12v system voltage. the other is the regulated return that gets regualted to ground in the voltage regulator. At low system voltage, the VR grounds the green wire. at high system voltage, it opens it up (or high resistance).
Get your voltmeter out with the black lead on BATTERY Ground. Meaure the Battery Voltage AT THE BATTERY. Should be 12.5-13.0 or so volts. If its lower than that, charge the battery before you start
What is the battery voltage at the battery?
Then, put the Red voltmeter lead on the blue field wire. It SHOULD read the same as the battery. If its lower, the VR thinks the battery is low and full field the Alt using that green field wire.
What is the voltage at the blue field wire (wrt battery ground)?
If it reads 12.5-13v, the VR should be opening up that other field wire and the alt output should go down. If the alt is charging like crazy, pull the green field wire off the alt- The alt output SHOULD go down. If it does, Its the VR (or that wire is shorted to ground). If it doesnt go down, its the alt
If it reads lower than 12.5V, the VR will try to full field the ALT to increase the output.
make sure the VR case is at ground. use the OHMMETER on the meter to check it wrt to battery negative (-). A bad ground on the VR makes the VR think the system voltage is lower than it really is and will try and up the field voltage but because there is additional resistance between the VR and real ground, it cant full feild the alt so the alt wont charge correctly.
you need a good ground at the VR case
[Re: Crocker]
#139268
10/22/08 07:01 AM
10/22/08 07:01 AM
ok, its starting to come back to me.... if you have a voltage drop at the ballast, you probably have a voltage drop at the VR as well. the most likely culprit is the bulkhead connector. as tese cars age, the connectors get oxidized and/or corroded and that cause resitance which will drop the voltage as the resistance increases. as the system voltage drops, the VR thinks you need a charge, so it tells the alt to kick it up a notch. check the voltage at the battery. and then, Check the voltage at the Fuse block under the dask on the BAT spade terminal. then check it at the blue wire at the VR. When you check it at the VR, check it with the blck meter lead on the battery - terminal and then try it with the black lead on the case of the VR (that will tell you if the VR is grounded well enough)
[Re: Crocker]
#139270
10/22/08 07:32 AM
10/22/08 07:32 AM
[Re: Crocker]
#139272
10/22/08 12:09 PM
10/22/08 12:09 PM
try those same reading with the ballast resistor disconnected (that same blue wire will feed the ballast and the coil)
[Re: Crocker]
#139275
10/22/08 08:35 PM
10/22/08 08:35 PM
so that tells me you probably have some resistance in your wiring between the battery and the VR. most likely at the bulkhead connector.
the reason I can say this is because when you have the coil connected (when the ballast is hooked up), the coil loads the system and draws current. The resistance in the wiring causes a voltage drop. thats why when you disconnect the coil, the voltage at the VR reads the same as the battery (the meter does not draw current- it is high impedance and looks invisible to the system).
basically, the bad connections you have act like a resistor and is dropping your system voltage.
when the car is running (ballast and VR hooked up) what is the voltage at the Blue wire at the VR?
also, the .5 difference in voltage tells me your battery probably needs a charge. it shouldnt drop half a volt with no load other than the harness hooked up. Use a charger and slow charge your battery. it may be bad. can you have it tested?
[Re: Crocker]
#139276
10/22/08 08:39 PM
10/22/08 08:39 PM
RapidRobert
Glen you need to have the eng running at a fast idle to check for voltage drops. With no current flowing high resistances(if present) do not restrict anything.
[Re: RapidRobert]
#139277
10/22/08 08:52 PM
10/22/08 08:52 PM
the reason I had him disconnect the coil at the ballast and check the voltage at the VR, was to see if maybe there was something ELSE drawing current and dragging down the voltage.
Since the voltage came back up with the coil disconnected, I kinda halffast checked for other drains on the system
[Re: Crocker]
#139279
10/23/08 06:53 AM
10/23/08 06:53 AM
the first place i'd start is with a new battery. if its fried, it will throw everything off. internal resistances will create voltage drops that will be telling your charging system to charge.
