Re: Coolant Recovery Tank Questions
[Re: B1arno]
#1392544
02/23/13 09:35 PM
02/23/13 09:35 PM
Posts: 21,847 Kirkland, Washington
Pacnorthcuda
That makes sense. It could also keep the rad from sucking the coolant back because the cap would keep air from entering the tank, thus creating a vacuum on the tank side.
Correct
[Re: moparx]
#1392549
02/25/13 11:35 PM
02/25/13 11:35 PM
Pacnorthcuda
since the factory setup places the can at, or slightly below the upper radiator tank level, and the siphon tube is below the fluid level of the upper tank[or core], i would guess it doesn't matter much ![](/ubbthreads/images/graemlins/shruggy.gif)
Siphon has very little to do with coolant recovery. It's pressure in the rad when it pukes, and it's vacuum in the rad when it cools.
[Re: Pacnorthcuda]
#1392550
02/25/13 11:48 PM
02/25/13 11:48 PM
Posts: 19,641 north of coder
moparx
siphon tube is just a name for the tube in the tank. ![](/ubbthreads/images/graemlins/beer.gif)
