What it cost me to build the first ever running 392 G3 #1392478
02/23/13 05:03 PM
02/23/13 05:03 PM
MN
hemidup Offline OP
hemidup  Offline OP
MN
I see many asking about the G3's lately and how much it cost's to build one.
Back in 05 there were only a handfull of engine builders playing around with them with no aftermarket parts available whatsoever. It was kinda like the race to space to get one up and running and I won. Maybe thats how I got nick named the Grandaddy of G3 Hemi's lol. The only thing we could do was to add stroke by offset grinding the crank shaft to a 3.80" stroke. If you worked with the 5.7 you would get 370 cubes and 392 from the 6.1.
My journey started with my 2005 4x4 Dodge Ram Rumble Bee pickup truck. She weighed in at 5275 and ran 16 flat off the showroom floor. I wanted to go faster (of course) so I added a blower and the truck went 13.80's which was good enough to put some stock Ford Lightng's on the trailer. Then I wanted to faster (of course) and decided to add more cubes to my 5.7, some head work and a factory 6.1 billet roller camshaft. I planned on stroking my 5.7 to a 6.1...Then Chuck Lofgren stepped into the picture and told me he had a spare factory 6.1 short block and camshaft he was willing to part with and I was jiffy on the spot and picked it up the next day. BTW, thanks again Chuck for the great deal.
Here's the break down of parts, most of which were one off at the time.
6.1 short block and roller billet camshaft...$2000...forged 6.1 crankshafts are $400 from the dealer, factory billet roller camshaft $85, aftermarket camshaft over $400. 6.1 blocks from INDY $1400 ??
Offset grinding and surface harden the crank... $200
Custom Ferrea valves...$800 Sent me valves with .308" valve stem dia which then I had to get custom bronze valve guides.
Custom ARP bolts and stud's...$660 But since I helped them out with their first set of proto type G3 stud's and bolts they were kind enough to ship me 2 sets for the same price. Thank you ARP.
Custom ATI damper...$600 + and even though we helped their engineer's with the G3 prototype...didn't get a break in price.
Hand ported 5.7 heads which I took off my original 5.7 motor...N/C, but had Glen Knowlton message them a bit and picked up a few more cfm...N/C and thank you Glenn Knowlton, may you RIP.
Eagle Honda rod journal rods...$400
Custom Ross piston's, pins and rings...$1200. Another disaster. I ordered a full skirt piston design, but the skirt hit the crank throw's. Order another set of longer connecting rod's figuring the skirt would clear the throw's, but I was wrong. The longer rod pushed the piston waaay out of the hole so I had to mill the top's of the pistons off which increased the compression I wanted and still had piston skirt to crank throw issues. I then had to remove material off the crank throw's and rebalance the rotating assemble.
Custom Cometic head gaskets...$200
Manley Nextek valve springs and titanium retainers...N/C thank you Manley for the valve springs and retainers in exchange for me helping you out with your G3 Hemi piston development. Othewise the Manley valve spring's go for $200 +
6.1 HV oil pump $?? can't remember the price, but I still use the 6.1 factory oil squirter's. If it wasn't for the oil squirter's I'd use a 5.7 oil pump.
Sorry for the long post and I'm sure I forgot a few things, but I'll be more than glad to answer any and all question's concerning a G3 Hemi build.
Jerry Williams.
Re: What it cost me to build the first ever running 392 G3 [Re: hemidup] #1392479
02/23/13 06:07 PM
02/23/13 06:07 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
Thanks for sharing Jerry
Here is a few examples from my 6.1/426 build in 2010/2011
899.00 new 6.1 block
8.16 new intake gaskets
103.02 timing chain
41.46 oil pan gasket windage tray
41.70 6.1 oil pump
110.28 shafts and intake rocker arms
110.28 shafts and exhaust rocker arms
258.48 hyd roller lifters
50.16 MLS mopar head gaskets
183.36 .....8 new 6.1 coil packs
189.34 3/8 manton push rods
Manley 4340 4.050 stroke
Manley H beams witha ARP 2000 bolts
Manley Pistons and rings bearings and balanced
2513.00
6.1 heads CNC ported, cut seats, back cut valves, cc chamber and mill .020 off deck to 71cc's 1.250 pac 1219 spring with moly locks reatainers seals.
1190.00
lsm cam
580.00
anyway not every nut and bolt but all the big stuff and you get the idea not much $$$$
Oh and the best part I bought every bit of this brand new from Dodge dealer
Re: What it cost me to build the first ever running 392 G3 [Re: 340RICK] #1392480
02/23/13 06:22 PM
02/23/13 06:22 PM
Guitar Jones Offline
Thank you gentleman for sharing, that is real world information that we all can use. Again thank you and if you could post some HP or at least trap speeds and weight that would also be much appreciated.
Re: What it cost me to build the first ever running 392 G3 [Re: Guitar Jones] #1392481
02/23/13 06:42 PM
02/23/13 06:42 PM
MN
hemidup Offline OP
hemidup  Offline OP
MN
My current race weight was 5184 lbs before I gained 15 lbs (lol) and added Caltrac's, so I'm over the 5200 lb mark. My truck has a best of 1.48 60', 6.87 @ 98 and 11.03 @ 118. Yeah, the numbers are all screwed up, but it is what it is running the stock PCM and using an adjustable fuel pressure regulator for tuning a/f's.
Jerry Williams.
Re: What it cost me to build the first ever running 392 G3 [Re: 340RICK] #1392482
02/23/13 08:39 PM
02/23/13 08:39 PM
MN
hemidup Offline OP
hemidup  Offline OP
MN
103.02 timing chain
41.70 6.1 oil pump
2513.00
1190.00
lsm cam
580.00
To help recoup my 392 build, I also sold my oringinal 5.7 bare block for $700 and the cast crank for $50.
Jerry Williams.
Re: What it cost me to build the first ever running 392 G3 [Re: hemidup] #1392483
02/23/13 09:04 PM
02/23/13 09:04 PM
How much boost are you running and I assume that's a centrifugal SC?
Still for 5200 pounds that's impressive.
Re: What it cost me to build the first ever running 392 G3 [Re: Guitar Jones] #1392484
02/23/13 09:10 PM
02/23/13 09:10 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I think the 6.4 is the way to go for a block but only problem is the funky front cam journal and I dont think there are any aftermarket off the shelf cams yet. http://www.mopar.com/part/RL086564AB?s=335847&i=1979588&b=dodge
Mopar to the bone!!!
Re: What it cost me to build the first ever running 392 G3 [Re: Guitar Jones] #1392485
02/23/13 09:26 PM
02/23/13 09:26 PM
MN
hemidup Offline OP
hemidup  Offline OP
MN
Couldn't tell you for sure since my current boost gauge only reads to 14.7 psi. I'm too cheap to buy a 3 bar gauge lol.
I run a small Paxton 1500 and leave the line around 9 psi.
Jerry Williams.
Re: What it cost me to build the first ever running 392 G3 [Re: hemidup] #1392486
02/23/13 10:29 PM
02/23/13 10:29 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
That really looks good in there Jerry
Re: What it cost me to build the first ever running 392 G3 [Re: hemidup] #1392487
02/24/13 11:09 AM
02/24/13 11:09 AM
gregsdart Offline
gregsdart  Offline
Jerry I am going to put a link in the other "to avoid" GIII thread to save this info. Thanks, to all that contribute!
Re: What it cost me to build the first ever running 392 G3 [Re: gregsdart] #1392488
02/24/13 11:17 AM
02/24/13 11:17 AM
gregsdart Offline
gregsdart  Offline
Jerry, does the new 6.1 block come ready to assemble, or did you have to bore/machine it at all? It may be cost effective to just buy a new 6.1 Vs prepping an original 5.7?
Re: What it cost me to build the first ever running 392 G3 [Re: gregsdart] #1392489
02/24/13 12:50 PM
02/24/13 12:50 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
I am not Jerry, but 6.1 block I bought came fully machined from dodge dealer.
Re: What it cost me to build the first ever running 392 G3 [Re: 340RICK] #1392490
02/24/13 01:30 PM
02/24/13 01:30 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Whats the weight of a complete gen3... either the
injected form or carb form
Re: What it cost me to build the first ever running 392 G3 [Re: 340RICK] #1392491
02/24/13 03:06 PM
02/24/13 03:06 PM
gregsdart Offline
gregsdart  Offline
Thanks Rick. Is the 6.1 a direct replacement for a 5.7 with different pistons, or what else changes? I have an early 5.7 now, but have a good stroker crank and rods.
Re: What it cost me to build the first ever running 392 G3 [Re: gregsdart] #1392492
02/24/13 04:07 PM
02/24/13 04:07 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Same stroke 3.58.
6.1 is forged.
Bores are different 3.92 for the 5.7 and 4.55 iirc for the 6.1. The 6.1 has floating piston pin.
Re: What it cost me to build the first ever running 392 G3 [Re: MR_P_BODY] #1392493
02/24/13 07:04 PM
02/24/13 07:04 PM
MN
hemidup Offline OP
hemidup  Offline OP
MN
Drag Pak engine weight without fluids. Now knock another 92 lbs off using an aluminum block. Giddy up
Jerry Williams.
Re: What it cost me to build the first ever running 392 G3 [Re: MattW] #1392494
02/24/13 07:25 PM
02/24/13 07:25 PM
MN
hemidup Offline OP
hemidup  Offline OP
MN
Same stroke 3.58.
6.1 is forged.
The factory 5.7 has a 3.917 bore and the 6.1 has a 4.055".
I might add that with the early blocks, the quality was exceptional..you really didn't have to do anything to them if you could live with a .002" difference in deck height and maybe touch up the cylinders with a plateau finish hone depending on ring choice. With the later blocks I would highly recommend to align hone the main bearing housing.
Jerry Williams.
Re: What it cost me to build the first ever running 392 G3 [Re: hemidup] #1392495
02/24/13 09:34 PM
02/24/13 09:34 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
What do you consider early, the 03-08 Hemis, or is it even more specific than that (02-04 for example)?
Re: What it cost me to build the first ever running 392 G3 [Re: WO23Coronet] #1392496
02/24/13 09:49 PM
02/24/13 09:49 PM
MN
hemidup Offline OP
hemidup  Offline OP
MN
The later the engine, the more core shift. History repeats itself. Still haven't seen a G3 Hemi block that needed sleeve's yet, but its only a matter of time.
Jerry Williams.
Re: What it cost me to build the first ever running 392 G3 [Re: 340RICK] #1392497
02/24/13 10:02 PM
02/24/13 10:02 PM
MN
hemidup Offline OP
hemidup  Offline OP
MN
Next time we hook up at the same track, same day, please give me a one Mississippi, two Mississippi head start and I'll race you to the 1/8. With no head start... I'm leaving on the first yellow lol.
Jerry Williams.
