Flywheel Bolts, How much clearance needed? #1391846
02/21/13 10:51 PM
02/21/13 10:51 PM
moparmedic Offline OP
I bolted up my flywheel with the bolts that came with it and torqued them. I noticed that the bolts protrude through the back of the crank a little, maybe 2 or 3 threads and come very close to the back of the block. The clearance is a little more than a sheet of paper. Is that normal? If not, is it safe to use grade 8 washers with the bolts to compensate?
1968 Coronet
1968 Charger
1966 A100 Pickup
1967 Barracuda
1970 Challenger
1972 Challenger
1973 Barracuda
2021 Ram 2500
Re: Flywheel Bolts, How much clearance needed? [Re: moparmedic] #1391847
02/21/13 11:24 PM
02/21/13 11:24 PM
Kirkland, Washington
Pacnorthcuda Offline
A sheet of paper??? I wouldn't run it! Just grind a thread or two off (carefully) clean up with a die and sleep well
Re: Flywheel Bolts, How much clearance needed? [Re: Pacnorthcuda] #1391848
02/21/13 11:37 PM
02/21/13 11:37 PM
Well now that is a good idea, why didn't I think of that? Thanks!
1968 Coronet
1968 Charger
1966 A100 Pickup
1967 Barracuda
1970 Challenger
1972 Challenger
1973 Barracuda
2021 Ram 2500
Re: Flywheel Bolts, How much clearance needed? [Re: moparmedic] #1391849
02/22/13 01:34 AM
02/22/13 01:34 AM
Did you use harden flat washers under the bolt heads? If not, why not the thin(.060 or so) harden head bolt washers will keep the heads of the bolts from eating into the flywheel
Re: Flywheel Bolts, How much clearance needed? [Re: Cab_Burge] #1391850
02/22/13 11:49 AM
02/22/13 11:49 AM
I didn't use any washers because the bolts didn't come with any. Just figured that was the way it was supposed to be.
1968 Coronet
1968 Charger
1966 A100 Pickup
1967 Barracuda
1970 Challenger
1972 Challenger
1973 Barracuda
2021 Ram 2500
Re: Flywheel Bolts, How much clearance needed? [Re: moparmedic] #1391851
02/22/13 12:03 PM
02/22/13 12:03 PM
that is correct, they are designed to be used as is & they have a machined surface on the underside of the head. trim em as is if you can get to the ends & if not remove them & trim them then reinstall/torque with loctite
Re: Flywheel Bolts, How much clearance needed? [Re: moparmedic] #1391852
02/22/13 03:29 PM
02/22/13 03:29 PM
3rd rock
K
kloyiod Offline
kloyiod  Offline
K
3rd rock
Hey moparmedic- Which bolts are we talking here? The bolts that connect the flexplate to the block, or the flex to the converter??
Re: Flywheel Bolts, How much clearance needed? [Re: kloyiod] #1391853
02/24/13 01:48 PM
02/24/13 01:48 PM
Flywheel to crank bolts. I did as suggested and used hardened washers and locktite.
1968 Coronet
1968 Charger
1966 A100 Pickup
1967 Barracuda
1970 Challenger
1972 Challenger
1973 Barracuda
2021 Ram 2500
