Do you have a leather interior ??? I always clean up and use a protectant in my interiors before storage...I guess the bucket would work for the whole garage if it's fairly air tight...I dont have the luxury of a heated storage area so once the temp gets below the operating range of the dehumidifier I install the damprid in the vehicles....I use the hanging moisture absorber that comes in an inclosed,disposable packet...It has two chambers with a plastic hanger on top...The top has the crystalized chemicals that draws the moisture in and then it settles into the bottom pouch...The crystals dissolve as the water is collected....There's only enough crystals to dissolve and fill the pouch...It can't overflow,leak, or get on anything and the plastic pouch is tough...Once the pouch is full I've beat it around to see if it would break easily and I could'nt do it !!! I poke a hole in the bottom to drain it before disposal{you don't need to} and even that's tough to do....I've been using those packets for years and have'nt had any issues....Now to be fair I have'nt tried it with a leather interior but I'm thinking they are just CYA on that issue..{I wonder if desicant type products do that to leather ???
}...On that note are'nt leather conditioning products usually an oil base ???
Anyhow...I 've seen the buckets{of damprid} but to be honest I have'nt tried it..I'm sure those buckets will also have a premeasured amount so it won't overflow which leads to the next issue.....Something to watch for....One of my buddies bought a different brand of the bucket type desicant and the darn thing filled up and overflowed...
Back on the packet type...One thing I've noticed{on a finished car with weather seals} is when I first hang it from the interior's rear view mirror, will absorb moisture and then the air will stabilize....It won't collect any more moisture unless the car is opened up....I know a bunch of guys in this area that are using these packets and they're doing the job with no ugly side affects...I'm sure we'd like to hear from anyone that has a product that worked for them....Anyone ????? Here's the damprid site for those who are interested...
Damprid
