heater cores 65 ply
#1391612
02/21/13 09:03 PM
02/21/13 09:03 PM
Posts: 113 utah
jjl
utah
Who sells them,a friend needs to change his in a 65 belv. 1
formally orangemonster
Re: heater cores 65 ply
[Re: jjl]
#1391613
02/22/13 12:28 AM
02/22/13 12:28 AM
Posts: 4,323 NY NY
340duster340
NY NY
google it,I am sure you will find. but also try your local parts store, they probably can order it.
1966 Dart GT
...down to only 1 mopar for the first time in 15 years!
[Re: 340duster340]
#1391614
02/22/13 01:09 AM
02/22/13 01:09 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
You won't find a 62/65 heater core at any parts store.
[Re: 62maxwgn]
#1391615
02/22/13 07:53 AM
02/22/13 07:53 AM
Posts: 21,073 Niles , Ohio
therocks
Niles , Ohio
I agrre you wont find one at a parts store unless its been on the shelf for 25 years.I have a spare for my 65.One big thing to check is the valve where the hose go in.There is a O ring on it.Lots of times it leaks and you think the core is leaking.Had to change mine a few years ago.A good rad shop can rebuild yours.Rocky
Chrysler Firepower
[Re: 62maxwgn]
#1391617
02/22/13 03:46 PM
02/22/13 03:46 PM
therocks
Niles , Ohio
I forgot while the box is out make sure the valve arm is moving nice and free.They get corroded and wont switch heat setting or they will bend the cable.I lube mine regulary.Only thing is I bent the h--l out of the cable before I found it was stuck.Now I just crawl under the dash and change it by hand.Rocky
Chrysler Firepower
