Milodon Alum pump & cover #1391457
02/21/13 04:45 PM
02/21/13 04:45 PM
Cincinnati OH
Bishop Offline OP
Bishop  Offline OP
Cincinnati OH
Anyone ever use one of these Milodon Alum oil pumps or is there a better one on the Market? This will be going on a all Alum. 572 street HEMI 10.5:1 pump gas motor wit a HP performance Alum. block #23
Thanks Brian
http://chucker54.stores.yahoo.net/newbimioilpu.html
Re: Milodon Alum pump & cover [Re: Bishop] #1391458
02/21/13 05:29 PM
02/21/13 05:29 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
They dont fit an original K-member, do a google search, I posted pics on here or the Dodge Charger forum. Waste of money unless you are running a plate...Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Milodon Alum pump & cover [Re: Bishop] #1391459
02/21/13 05:33 PM
02/21/13 05:33 PM
yarnell,az
mopacltd Offline
mopacltd  Offline
yarnell,az
Been using Milodon for over 40 years now. Didn't have a plate on my Hemi A/SM cuda back in the '70's and everything fit just fine.
Re: Milodon Alum pump & cover [Re: astjp2] #1391460
02/21/13 06:42 PM
02/21/13 06:42 PM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
????? I think there would be hundreds of users who would disagree. That said, you have to use the correct plate for the application. The one on the right is for the plain ol' big blocks, the one in the middle is for a hemi and will work with stock mounts and K-member
Re: Milodon Alum pump & cover [Re: Stanton] #1391461
02/21/13 06:44 PM
02/21/13 06:44 PM
an8sec70cuda Offline
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Milodon Alum pump & cover [Re: an8sec70cuda] #1391462
02/21/13 06:50 PM
02/21/13 06:50 PM
Ontario, Canada
Don't question me!
Don't question me!
Ontario, Canada
This is basically the same setup only not "billet". The cover is from Muscle Motors and is probably half the price of the Milodon (does the same thing just not as pretty!)
Re: Milodon Alum pump & cover [Re: Stanton] #1391463
02/21/13 07:07 PM
02/21/13 07:07 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
You see the bolt on the top back? You are not showing a hemi block and mount. That rear bolt I believe I have heard something talked about on here, but I also read it was resolved.
Re: Milodon Alum pump & cover [Re: Mopar-Al] #1391464
02/21/13 07:48 PM
02/21/13 07:48 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I'm trying to fit mine now( cast pump and cover)won't fit with stock mount. Pump eliminates spacer plate but whole ass. sticks back to far. I WILL make it work though.
Went back and read ad(had to blow up) new cover will fit, I have the older one, my bad
Re: Milodon Alum pump & cover [Re: Stanton] #1391465
02/21/13 08:38 PM
02/21/13 08:38 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Isnt that a 440 engine mount?
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Milodon Alum pump & cover [Re: mopacltd] #1391466
02/21/13 08:39 PM
02/21/13 08:39 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
R us using the center cover in the picture above on a Hemi block and K-member?
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Milodon Alum pump & cover [Re: astjp2] #1391467
02/21/13 08:40 PM
02/21/13 08:40 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I bought both of those covers last summer and BOTH had interference with the left motor mount or K-member.
Look at post # 12 to see what I had to do to run external oiling with a stock K-member and mounts
http://www.protouringmopar.com/showthread.php?850-Milodon-BB-external-oiling-system-anyone-use-them
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Milodon Alum pump & cover [Re: astjp2] #1391468
02/21/13 08:44 PM
02/21/13 08:44 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Look at this post to show the MILODON cover on a STOCK hemi mount system.
https://board.moparts.org/ubbthreads/show...amp;Search=true
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Milodon Alum pump & cover [Re: astjp2] #1391469
02/21/13 08:45 PM
02/21/13 08:45 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
this is the milodon pump to use with a stock k frame. also uses a stock cover. used it on a few motors including my hemi, works real well.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: Milodon Alum pump & cover [Re: 68 HEMI GTS] #1391470
02/21/13 09:45 PM
02/21/13 09:45 PM
Ontario, Canada
Don't question me!
Don't question me!
Ontario, Canada
No, its a small block chevy mount !!!
The post was to show the MM cover, not a hemi mount. But I can understand the confusion.
Re: Milodon Alum pump & cover [Re: Stanton] #1391471
02/21/13 10:41 PM
02/21/13 10:41 PM
San Jose Ca.
boatracer572 Online content
boatracer572  Online Content
San Jose Ca.
These are nice also....... http://hemimilitia.com/pge2.html
Re: Milodon Alum pump & cover [Re: boatracer572] #1391472
02/21/13 11:49 PM
02/21/13 11:49 PM
ky
68roadrunner Offline
ky
i am sure they are nice, who has used one?
Re: Milodon Alum pump & cover [Re: 68roadrunner] #1391473
02/22/13 08:31 AM
02/22/13 08:31 AM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
stock motor mounts with milodon cast cover and melling HV pump. you have to get a little creative with the mount and clearancing. and you also need to install the mount and oil pump together.
Re: Milodon Alum pump & cover [Re: prochargedhemi] #1391474
02/22/13 02:11 PM
02/22/13 02:11 PM
St. Charles, MO.
Slingshot383 Offline
St. Charles, MO.
Milodon makes one that is even tighter to the engine than that one, almost a must in an open wheel car.
1994 Undercover Chassis 125" altered stack injected big block, soon blown and injected Member of The Torque and Recoil Club
Re: Milodon Alum pump & cover [Re: Bishop] #1391475
02/22/13 03:13 PM
02/22/13 03:13 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Thanks Brian
We've got one on the car right now, Couldn't tighten the mounting bolts to the stock iron torque specs without it binding.
I was told 15ft lbs was OK and it seems to work on the drill.
Never found out what Milodon recommended
Haven't got round to running the motor yet either.
Re: Milodon Alum pump & cover [Re: Tig] #1391476
02/23/13 02:08 PM
02/23/13 02:08 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Thanks Brian
What mounts are you using? Which block? Which K-member? The OP was asking about a Hemi block and K-member with the new cover and others post pics of their 440 setup or of some other cover. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
