Re: Milodon Alum pump & cover
[Re: Bishop]
#1391458
02/21/13 05:29 PM
02/21/13 05:29 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
They dont fit an original K-member, do a google search, I posted pics on here or the Dodge Charger forum. Waste of money unless you are running a plate...Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: astjp2]
#1391460
02/21/13 06:42 PM
02/21/13 06:42 PM
Posts: 8,907 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
????? I think there would be hundreds of users who would disagree. That said, you have to use the correct plate for the application. The one on the right is for the plain ol' big blocks, the one in the middle is for a hemi and will work with stock mounts and K-member
[Re: Stanton]
#1391461
02/21/13 06:44 PM
02/21/13 06:44 PM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
[Re: Stanton]
#1391463
02/21/13 07:07 PM
02/21/13 07:07 PM
Posts: 6,780 Alabama
Mopar-Al
Alabama
This is basically the same setup only not "billet". The cover is from Muscle Motors and is probably half the price of the Milodon (does the same thing just not as pretty!)
You see the bolt on the top back? You are not showing a hemi block and mount. That rear bolt I believe I have heard something talked about on here, but I also read it was resolved.
[Re: Mopar-Al]
#1391464
02/21/13 07:48 PM
02/21/13 07:48 PM
Posts: 8,343 fredericksburg,va
cudaman1969
fredericksburg,va
I'm trying to fit mine now( cast pump and cover)won't fit with stock mount. Pump eliminates spacer plate but whole ass. sticks back to far. I WILL make it work though.
Went back and read ad(had to blow up) new cover will fit, I have the older one, my bad
[Re: 68 HEMI GTS]
#1391470
02/21/13 09:45 PM
02/21/13 09:45 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Isnt that a 440 engine mount?
No, its a small block chevy mount !!!
The post was to show the MM cover, not a hemi mount. But I can understand the confusion.
[Re: prochargedhemi]
#1391474
02/22/13 02:11 PM
02/22/13 02:11 PM
Posts: 684 St. Charles, MO.
Slingshot383
St. Charles, MO.
Milodon makes one that is even tighter to the engine than that one, almost a must in an open wheel car.
1994 Undercover Chassis 125" altered
stack injected big block, soon blown and injected
Member of The Torque and Recoil Club
[Re: Bishop]
#1391475
02/22/13 03:13 PM
02/22/13 03:13 PM
Posts: 2,933 A shed in England
Tig
A shed in England
Anyone ever use one of these Milodon Alum oil pumps or is there a better one on the Market? This will be going on a all Alum. 572 street HEMI 10.5:1 pump gas motor wit a HP performance Alum. block #23
Thanks Brian
http://chucker54.stores.yahoo.net/newbimioilpu.html
We've got one on the car right now, Couldn't tighten the mounting bolts to the stock iron torque specs without it binding. I was told 15ft lbs was OK and it seems to work on the drill. Never found out what Milodon recommended Haven't got round to running the motor yet either.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
