Should I cut my header flanges for better seal? #1391132
02/20/13 11:07 PM
02/20/13 11:07 PM
Tampa
DusterDave Offline OP
Tampa
I'm building a set of headers, and thought I read somewhere that its a good idea to remove these sections of the header flanges (marked in green), because there will be less chance of warping, and therefore, less chance for leaks. Is this true? BTW, these flanges are 3/8" thick.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: Should I cut my header flanges for better seal? [Re: DusterDave] #1391133
02/20/13 11:09 PM
02/20/13 11:09 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
I'd just buy a set of remflex gaskets and be done with worrying about any leaks PERIOD...
Re: Should I cut my header flanges for better seal? [Re: DJVCuda] #1391134
02/20/13 11:33 PM
02/20/13 11:33 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I cut those sections out for a few reasons:
Reduced warpage
Improved spark plug access
Less heat around the wire/boots
Better appearance
Less unnecessary weight
Never had a leak since I started doing that decades ago.
Re: Should I cut my header flanges for better seal? [Re: topside] #1391135
02/20/13 11:51 PM
02/20/13 11:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Reduced warpage
Better appearance
Yep... .... I always cut them... the expansion
rate is different from the outer cyl to the center...
cut them and get that chunk out of the way... and
be much happier all the way around
EDIT
Also ... make one of the holes larger than the bolt
so it has room to slide.. otherwise something has
to buckle (on EACH pipe or SET of pipes)
Re: Should I cut my header flanges for better seal? [Re: topside] #1391136
02/21/13 12:02 AM
02/21/13 12:02 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Reduced warpage
Better appearance
Me three.
Re: Should I cut my header flanges for better seal? [Re: DusterDave] #1391137
02/21/13 12:18 AM
02/21/13 12:18 AM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Weld an on edge gusset bridge, on the top face of both center tube flanges, to help with edge pull down. Next best thing to the third bolt, that isn't there. Oh yea. Cut the connecting material out.
Re: Should I cut my header flanges for better seal? [Re: Leigh] #1391138
02/21/13 01:06 AM
02/21/13 01:06 AM
Tampa
Tampa
Thanks, guys! I will cut away, and oval/oversize one hole on each flange.
Re: Should I cut my header flanges for better seal? [Re: DusterDave] #1391139
02/21/13 11:45 AM
02/21/13 11:45 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
as Mike says...and many other manufactures...yes cut them but maybe not as much of a chunk..
I have Doug's headers..here's what they do and they too have thick flanges..
Re: Should I cut my header flanges for better seal? [Re: DusterDave] #1391140
02/21/13 01:20 PM
02/21/13 01:20 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
I cut them and make holes one or two drill sizes larger
no gaskets just ultra high silicone
home of the
Sox and Martin Hemi Duster
Re: Should I cut my header flanges for better seal? [Re: DusterDave] #1391141
02/21/13 08:04 PM
02/21/13 08:04 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Yep cut them, but I wouldnt cut them until your headers are all welded up. You probably know that already.
Re: Should I cut my header flanges for better seal? [Re: HEMIFRED] #1391142
02/21/13 09:40 PM
02/21/13 09:40 PM
nc
E
earthmover Offline
earthmover  Offline
E
nc
my buddy thinks I am crazy when I tell him that... that's all I have ever used on my small block, and never a leak
Re: Should I cut my header flanges for better seal? [Re: earthmover] #1391143
02/21/13 10:11 PM
02/21/13 10:11 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
The Loctite 59675 is a Superflex® RTV high temperature red silicone adhesive sealant.
Loctite 59675 Features:
Resists aging, weather, and thermal cycling without shrinking, cracking, or hardening
Applications: automotive gasketing, industrial furnaces, boilers, ducting
Temperature range: -75°F to 600°F (-59°C to 316°C)
Container: 300 ml cartridge
Consistancy: paste
Gap fill: to 0.25"
Color: red
home of the
