Lock up to non-lockup conversion?
#1390721
02/20/13 10:00 AM
02/20/13 10:00 AM
Posts: 2,403 WASHINGTON, PA
11secaarcuda
WASHINGTON, PA
Can a lockup transmission (727,904, 500, 518) be converted to a non lockup? What would need changed?
67 Dart GT 340 4 speed 70 AAR Cuda 408 6 barrel 96 Indy Ram original owner 2011 Hemi Durango
Re: Lock up to non-lockup conversion?
[Re: Greg Ducato]
#1390724
02/20/13 11:12 AM
02/20/13 11:12 AM
Posts: 75,027 U.S.S.A.
JohnRR
U.S.S.A.
You can leave all the trans components intact, block the stroke of the lockup valve and remove the clutch from the converter. This may be an easier solution in some instances.
That certainly would be easier , especially if you were buying an aftermarket convertor .
[Re: JohnRR]
#1390725
02/20/13 06:19 PM
02/20/13 06:19 PM
Posts: 25,827 Rio Linda, CA
John_Kunkel
Rio Linda, CA
If the goal is to simply eliminate the lockup in a 727 or 904, blocking the lockup valve is the simplest solution. For the 500 and 518 just don't hook up the wire.
If one wants to use an aftermarket non-lockup converter it will have a different input shaft spline so the non-lockup parts will have to be swapped in.
