Page 1 of 5 1 2 3 4 5
904 trans died behind 390 stroker ** UPDATE ** #139046
10/20/08 02:03 PM
10/20/08 02:03 PM
Tampa, FL
tpabayflyer Offline OP
Tampa, FL
I had a fresh 904(999) lockup trans built for my 390. Lasted less than 500 miles and lost all forward gears and reverse as well. I noticed some rough full throttle 1-2 upshifts lately and have another thread on that subject.
I don't know the status of the 999 trans and I am not sure what would cause it to lose all fwd gears and reverse as well. Should I do an autopsy and take it from their or should i just plan on an upgrade to the 727??? I did install a transgo shift kit in the valve body and I was wondering if I found an A-727 lockup trans would this valve body work or should I just go with a non-lockup and re-do another valve body??
This trans did not have the low band apply as it would freewheel in 1st gear when coasting. I did do some burnouts in 1st gear so I wonder if i did some damage????
FWIW, trans looks fine with no leaks and driveshaft is intact as well as the 8 3/4 rear......... TBF
Re: 904 trans died behind 390 stroker, time for 727???? [Re: tpabayflyer] #139047
10/20/08 03:11 PM
10/20/08 03:11 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
You didn't answer on the other post but do you have a kickdown linkage hooked up?
Re: 904 trans died behind 390 stroker, time for 727???? [Re: tpabayflyer] #139048
10/20/08 03:24 PM
10/20/08 03:24 PM
Dissect it & find out what happened. I knew of a 66 A body that was in the 10's(strip only) with a not too special 904. Stay with it, a 904 can handle it.
Re: 904 trans died behind 390 stroker, time for 727???? [Re: stumpy] #139049
10/20/08 03:37 PM
10/20/08 03:37 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
a broken input or output shaft would cause no movement so would a stripped converter or broken pump gears so no way to know with out tearing it down.As someone thats been in the buisness over 20 years I would forget about the whole lockup deal.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: 904 trans died behind 390 stroker, time for 727???? [Re: RapidRobert] #139050
10/20/08 03:38 PM
10/20/08 03:38 PM
scratchnfotraction Offline
727 non lock up
takes more hp to turn it,but holds up better than a 904 tranny
I am in the same boat with ya right now,my 904 is going south real fast,been babying it latly since it started slipping,I tightend the kick down band and it stoped slipping but the adjuster is in all the way in with just enuff threds to hold the lock nut on
I am going with a 76 loadflight 727 with a short shaft bolt on yoke from a truck,and will build a drive shaft with a slip yoke
well thats after a rebuild cause the sprag is gone in it,took about 8 N drops to kill it after 7-8 yrs of hard driving it
best 50$ tranny I ever got from the clearwater u-pull it
gonna try and save the 904 as a spare maybe if it dont die before I gets the 727 done
good luck with it
Re: 904 trans died behind 390 stroker, time for 727???? [Re: scratchnfotraction] #139051
10/20/08 03:55 PM
10/20/08 03:55 PM
Tampa, FL
Tampa, FL
Thanks guys.. yes I do have the kickdown linkage installed properly... I have done some research and I wonder if the front pump has failed??? I guess the pump gears failing would have the same effect??? \
Obviously the trans will be coming out and I wonder if I should get a 727 to build??? I do like the 2.74 low gear of the 999 and I did spend over $300 for a 2,600stall lockup converter. I would also need to have the driveshaft shortened and get another converter but I would like to get a 3,000 stall to optimize my combo. I could actually use the lockup converter for my future grand cherokee 390 project so its not a big deal. I did spend a few hundred on the rebuild kit so i would like to use what I have if possible....... Is there a way I could check to see if the pump is working??? with the engine running and trans in neutral would fluid be flowing??? I have a trans cooler up front and could check that pretty easily??? I wish I could find a $50 JY tranny that would work!!! TBF
Re: 904 trans died behind 390 stroker, time for 727???? [Re: tpabayflyer] #139052
10/20/08 05:04 PM
10/20/08 05:04 PM
pittsburgh,Pa.
mikepar Offline
mikepar  Offline
pittsburgh,Pa.
Dawg
To check the front pump action note the fluid level on the dip stick WITH the engine off.
Start it up and check the level again running,
the level will be lower on the stick which means the pump is werkin
Re: 904 trans died behind 390 stroker, time for 727???? [Re: mikepar] #139053
10/20/08 05:28 PM
10/20/08 05:28 PM
wisconsin
1BAD68 Offline
1BAD68  Offline
wisconsin
I would stick with the 904, I have one behind my 390 and have beat the snot out of it this summer with about 3300 miles. It was stock but I added a Transgo shift kit and it made the 1st to 2nd shifts so hard I actually thought I would snap a u-joint eventually but never did.
Mine started to not downshift automatically when stopping so my plan is to have it rebuilt this winter and continue to torture it. The 904 is pretty stout and should be able to handle all that a 390 stroker can dish out.
Re: 904 trans died behind 390 stroker, time for 727???? [Re: 1BAD68] #139054
10/20/08 07:35 PM
10/20/08 07:35 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
stick with the 904.
A bad front pump can still pump enough to raise and lower the tranny fluid level, that is not a good way to test it. If you think you want to test it first it is real simple to hook up a preasure gauge to the line preasure port and see if you have line preasure. I wouldn't bother though, it has to come out any how.
Re: 904 trans died behind 390 stroker, time for 727???? [Re: HotRodDave] #139055
10/20/08 07:56 PM
10/20/08 07:56 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Neck snapping shifts is usually a sign of overlap, not a good shift.
Re: 904 trans died behind 390 stroker, time for 727???? [Re: slantzilla] #139056
10/20/08 11:22 PM
10/20/08 11:22 PM
Tampa, FL
Tampa, FL
My 1-2 shift was brutal after I adjusted the front band properly...... I'll start taking this out tomorrow and report back.... TBF
Re: 904 trans died behind 390 stroker, time for 727???? [Re: tpabayflyer] #139057
10/20/08 11:24 PM
10/20/08 11:24 PM
Tampa, FL
Tampa, FL
If the front pump failed would it be a relatively easy fix to get at the pump from the front of the trans or does everthing need to come out??? TBF
Re: 904 trans died behind 390 stroker, time for 727???? [Re: tpabayflyer] #139058
10/20/08 11:40 PM
10/20/08 11:40 PM
If the front pump failed would it be a relatively easy fix to get at the pump from the front of the trans YES or does everthing need to come out??? TBF NO
Re: 904 trans died behind 390 stroker, time for 727???? [Re: tpabayflyer] #139059
10/21/08 09:10 AM
10/21/08 09:10 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
if the pump failed it usually breaks the tangs off the rotor and/or breaks the snout of the convertor , metal particles go everywhere ...
Re: 904 trans died behind 390 stroker, time for 727???? [Re: JohnRR] #139060
10/21/08 09:57 AM
10/21/08 09:57 AM
Tampa, FL
Tampa, FL
Great.... well I'll find out later when I drop the trans..... Now back to the original question, Does anybody know what would cause the loss of all forward gears as well as reverse??? Is the front pump a likely guess? TBF
Re: 904 trans died behind 390 stroker, time for 727???? [Re: tpabayflyer] #139061
10/21/08 10:02 AM
10/21/08 10:02 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I think what caused it was a 904 behind that motor. for you to have lost all forward motion either you have no fluid flow of a shaft broke .
Pull a line off the trans cooler , direct it int oa bucket and start it up with the car in neutral , if you get no flow then its the pump , if you get fluid you broke a shaft .
Either way I would be putting a 727 behind that , 904's to handle torquey motors need $$$ parts .
Re: 904 trans died behind 390 stroker, time for 727???? [Re: JohnRR] #139062
10/21/08 11:10 AM
10/21/08 11:10 AM
MNobody Offline
MNobody  Offline
That sound's like good advice to me from what i have read from several other post's.
Re: 904 trans died behind 390 stroker, time for 727???? [Re: MNobody] #139063
10/21/08 03:50 PM
10/21/08 03:50 PM
Tampa, FL
Tampa, FL
Quick update, pump is working as a shower of trans fluid shot out the hose when I fired it up for 2 seconds...... I guess now the input shaft or the converter snout is stripped..... I am leaning towards the converter threads being stripped as it is a lockup style converter and I wonder how strong they are??? Car is jacked up now and trans should be out soon....... If I replace the converter is the same thing going to happen again???????
Maybe the 727 might be the best way to go TBF
Re: 904 trans died behind 390 stroker, time for 727???? [Re: tpabayflyer] #139064
10/21/08 05:58 PM
10/21/08 05:58 PM
Locomotion Offline
Locomotion  Offline
Whether or not the lock-up converter had anything to do with the failure, it was never intended to be used in performance applications. Valve bodies are different too and the parts don't interchange, but I don't know what the differences are. With the right parts, a lock-up trans can be converterted to a non-lock-up and, of course, the low gear sets do interchange. A regular 904 trans, built properly, will work fine. But a regular 727 is stronger and will likely last longer simply because of the bigger, stronger parts used. The key words are "regular" and "non lock-up". I have a few years on the 904 in my car built by JW but may swap it out for freshening this off-season to be safe. Nothing special or trick, just their reverse manual valve body, a low gear set and whatever HD bands and clutches they use. I also use Amsoil Supershift synthetic fluid.
I have heard that OEM bands may not hold up to hard shifts because of the material. Same reasoning if using a 5.0 lever. There are a couple different performance bands too. Between "blue" and "red", I believe the red are best. I just never got into transmissions and let JW take care of that.
I don't think a freewheeling low gear is a good idea on the street either.
Re: 904 trans died behind 390 stroker, time for 727???? [Re: tpabayflyer] #139065
10/21/08 07:32 PM
10/21/08 07:32 PM
TBF
Continue with the autopsy, inquiring minds want to know
