How Fast With Stock Front Suspension?? #1390481
02/19/13 07:43 PM
02/19/13 07:43 PM
Plant city fl
70Dart499 Offline OP
Plant city fl
How fast has everyone been with stock Mopar front suspension? At what point are suspension upgrades needed?
1970 Dart Drag Car
Re: How Fast With Stock Front Suspension?? [Re: 70Dart499] #1390482
02/19/13 08:01 PM
02/19/13 08:01 PM
Finland
mafo Offline
mafo  Offline
Finland
stock except for the shocks, I even have rubber bushings
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
Re: How Fast With Stock Front Suspension?? [Re: 70Dart499] #1390483
02/19/13 08:16 PM
02/19/13 08:16 PM
Penna
70satelliteguy Offline
Penna
8.62/161 with adjustable front shocks and racing torsion bars!
Mike
Re: How Fast With Stock Front Suspension?? [Re: 70satelliteguy] #1390484
02/19/13 09:23 PM
02/19/13 09:23 PM
Tennessee
steeldust Offline
steeldust  Offline
Tennessee
I have been et 5.81 at mph 126 in a 1/8 but this year i will be going a lot faster i am going to spray a lot with stock up front all i have is comp shocks 3 way adjustable and it works just find
Re: How Fast With Stock Front Suspension?? [Re: steeldust] #1390485
02/20/13 03:20 PM
02/20/13 03:20 PM
dayton,ohio
ROSSIO Offline
ROSSIO  Offline
dayton,ohio
Went 8.95 @149 with all stock
Frt end-now I have Bobsprofab stuff on it
Now -going 8.80s@155 feels safer now
1970 DART B1MC N/A 8.86@ [Email]155 3200 lb on 275 DR 5.30 @ 130 1/8
Re: How Fast With Stock Front Suspension?? [Re: ROSSIO] #1390486
02/20/13 05:31 PM
02/20/13 05:31 PM
North Cackilacky
sdaurity Offline
sdaurity  Offline
North Cackilacky
Been 140 to the 1/8 with an all stock set up. Never ran it all the way out the back have let out early and been 158 I beleive. Only thing I never liked was when on the brakes hard it wanted to move around alot like it had drums on the front. Had it aligned by a few different folks a few different ways never made a difference.
One day I will have something cool here.
Re: How Fast With Stock Front Suspension?? [Re: sdaurity] #1390487
02/20/13 05:56 PM
02/20/13 05:56 PM
pa
572charger Offline
572charger  Offline
pa
8.90s at 156mph at 3910 lbs no problems !! get as much caster as possible ive got 2.75 degrees positve it helps at high speed !@!!!!
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: How Fast With Stock Front Suspension?? [Re: 572charger] #1390488
02/20/13 06:06 PM
02/20/13 06:06 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
I've went 9's no problem on pump gas but now changing over to coil over setup.
Mopar Performance
Re: How Fast With Stock Front Suspension?? [Re: moparniac] #1390489
02/21/13 06:17 AM
02/21/13 06:17 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
7.89/174, The shocks are old Koni replacement shocks, rubber bushings, the torsion bars are stiffer than stock.
Plynouth VIP '67 TT IC EFI
Re: How Fast With Stock Front Suspension?? [Re: 70Dart499] #1390490
02/21/13 10:01 AM
02/21/13 10:01 AM
gregsdart Offline
gregsdart  Offline
The stock components are stronger than most aftermarket upgrades. The only down sides I see are weight,clearance and adjust-ability. There is some flex/deflection (wheelstands, landing)due to the rubber parts, but rebuilt properly the stock front is going to be stable at speed. Stock parts can be reworked if there is any bump steer. Make sure you can dial in enough caster. I run a lot, about six degrees, but the car drives itself if I am in the grove. To get that much, there are parts available to help (can't recall what/where) or you can go with custom upper A arms that have a wider range of adjustment.
Re: How Fast With Stock Front Suspension?? [Re: gregsdart] #1390491
02/21/13 10:41 AM
02/21/13 10:41 AM
maryland
74yellowduster Offline
maryland
PST sells the custom upper control arms with the balljoint relocated slightly, just enough so your cam adjusters can adjust caster/camber alignment where it needs to be.
http://www.p-s-t.com/
