A-body 4 speed questions #139029
10/20/08 01:15 PM
10/20/08 01:15 PM
PNW
Danan Offline OP
Danan  Offline OP
PNW
Hello,
Do all 4spd pedal assemblies interchange between years (i.e 68 fit a 71 and vice versa)? Is there a difference between auto and 4spd trans crossmembers? I'm a B/E body guy, so I'm not up to speed on the interchange..
Thanks!
Re: A-body 4 speed questions [Re: Danan] #139030
10/20/08 04:21 PM
10/20/08 04:21 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
pedals are the same , maybe a slight visuual difference but they fit and work the same .
same crossmember for either trans
Re: A-body 4 speed questions [Re: Danan] #139031
10/20/08 04:24 PM
10/20/08 04:24 PM
US of A
A38s! Offline
A38s!  Offline
US of A
I believe the pedals mount up the same, 67-76. These are 68:
WANTED: Your 71-78 Late B-body sedan parts! Police or Civilian.
Re: A-body 4 speed questions [Re: A38s!] #139032
10/21/08 12:28 AM
10/21/08 12:28 AM
PNW
Danan Offline OP
Danan  Offline OP
PNW
Thanks, guys. Chief, do you have a pic of the other side of the pedals? Is there a square flange that is parallel to the ground when the pedals are installed? Thanks again,
Danan
Re: A-body 4 speed questions [Re: Danan] #139033
10/21/08 11:36 AM
10/21/08 11:36 AM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
1970 and up pedals will have the neutral safety switch on the clutch pedal
Re: A-body 4 speed questions [Re: Danan] #139034
10/21/08 11:59 AM
10/21/08 11:59 AM
US of A
A38s! Offline
A38s!  Offline
US of A
I think you're talking about the third column mounting point/bracket, as pic'd.
