Hemi expertise needed #1390196
02/19/13 05:22 AM
02/19/13 05:22 AM
near St Petersburg, FL
Lifsgrt Offline OP
Lifsgrt  Offline OP
Gents,
I'm pretty well versed on B and RB engines, but need expert advise on this parts package I'm considering buying. Am a big fan of the wedge, but have always wanted to build a Hemi. Anything bad about the block, heads, etc in this package? Don't think I'll be able to beat the deal anytime soon and would make a 1968 Dart or Barracuda into a pretty cool tribute car.
472 cubic inch HEMI Engine
Block p5007668
Aluminum heads (2) p4876857
Black valve cover set p5007796
Flywheel p4529143
Fluid damper p4452776
Cross-ram intake p5007534
Right carb p4452778
Left carb p4452779
Air cleaner kit p5007809
Intake linkage kit p4510635
Stroker 4.15 crankshaft p5007250
Intake rocker shaft (2) p5249631
Exhaust rocker shaft (2) p5249632
Set of steel crank rods p4876303
Set of aluminum crank rods(8) p5249790
Starter p5249644
Oil pump p4286590
Intake bolt kit p4529330
Exhaust rocker arm (8) p5249604
Intake rocker arm (8) p5249603
Stock piston (8) p5007076
Adjustable rocker studs kit p5007444
Aluminum rocker support kit p5249505
Windage tray p3412083
Gear drive set (2 kits ) p5249759
Alum water pump housing p4286900
Alum water pump p4529102
Gasket p5007345
Lifter set (8) p4452920
Fuel pump p4007039
Timing cover p4349816
Head stud kit p4452197
Oil pan p4529884
Fan p4120758
MSD billet Distri #8546 non-mopar
Dipstick p4349629
Thanks for your time.
B3 1969 Charger R/T SE, 440/727 with 3:91s running 11.07@120
Re: Hemi expertise needed [Re: Lifsgrt] #1390197
02/19/13 11:51 AM
02/19/13 11:51 AM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
So these are parts, not an assembly? Have any of them ever been run? If so, what do you know of it's history?
Hope it works out for you.
Master, again and still
Re: Hemi expertise needed [Re: DaveRS23] #1390198
02/19/13 12:16 PM
02/19/13 12:16 PM
Lifsgrt Offline OP
Lifsgrt  Offline OP
Hello Dave, all new parts in packages for those that will fit. Was wondering if there was a problem with the block, for instance, since there were issues with foundrys and production back then.
Re: Hemi expertise needed [Re: Lifsgrt] #1390199
02/19/13 12:39 PM
02/19/13 12:39 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
No way to know on the block by just the part number unless that is a WORLD block then it still may be hit or miss , machining was a big issue with them all .
If it's an earlier block be weary of blocks that were porous that went out the back door instead of melted down to recast ...
Re: Hemi expertise needed [Re: JohnRR] #1390200
02/19/13 01:59 PM
02/19/13 01:59 PM
Lifsgrt Offline OP
Lifsgrt  Offline OP
Seller says "This is a Mopar Performance stock replacement block for the 426 cu.in manufactured around 2000-2001" if that helps. Thanks for the replies.
Re: Hemi expertise needed [Re: Lifsgrt] #1390201
02/19/13 02:25 PM
02/19/13 02:25 PM
West Coast, CA
Troy Offline
Troy  Offline
West Coast, CA
Sounds like a fun project. That engine package is very close to what I built for my Dart. Same block, crank and heads. It makes more power than I know what to do with.
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
Re: Hemi expertise needed [Re: Troy] #1390202
02/19/13 02:26 PM
02/19/13 02:26 PM
West Coast, CA
Troy Offline
Troy  Offline
West Coast, CA
engine...
You must use the headers from TTI if your going into a A body. They fit like a glove!!
Re: Hemi expertise needed [Re: Troy] #1390203
02/19/13 02:37 PM
02/19/13 02:37 PM
Lifsgrt Offline OP
Lifsgrt  Offline OP
Thanks Troy, that's what I had in mind!
Re: Hemi expertise needed [Re: Lifsgrt] #1390204
02/20/13 08:26 AM
02/20/13 08:26 AM
pa
572charger Offline
572charger  Offline
pa
have the block sonic checked and 1st check the main caps to see if they are tight in the block we have a wedge block from that time frame that we had program make over sized main caps to fit !!!
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: Hemi expertise needed [Re: 572charger] #1390205
02/20/13 12:24 PM
02/20/13 12:24 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Jim is correct,also look at the back of the block just above the bell housing bolts for any indication of a tag being glued on.Many of the street blocks came with a tag:bore to max.4.280 or 4.375.If not as Jimmy said sonic test and do it frequently on the Major and minor thrust.Try and maintain .180 after finish bore.
Re: Hemi expertise needed [Re: B G Racing] #1390206
02/21/13 06:58 AM
02/21/13 06:58 AM
Lifsgrt Offline OP
Lifsgrt  Offline OP
Thanks guys that was the kind of info I was looking for, helps a bunch.
Re: Hemi expertise needed [Re: Lifsgrt] #1390207
03/09/13 03:44 AM
03/09/13 03:44 AM
Lifsgrt Offline OP
Lifsgrt  Offline OP
Well maybe I'll find out the hard way...bought my first hemi. We'll see. Thanks guys.
Re: Hemi expertise needed [Re: Lifsgrt] #1390208
03/09/13 11:29 AM
03/09/13 11:29 AM
Benton, IL.
Special needs idiot
Special needs idiot
Benton, IL.
Hey Jerry, how long have you been in Florida? Any chance you will stationed back up this way?
I got mine fired up this week. Sounds awesome, but I am chasing a water issue. With a little luck I will get the brakes together today and be able to take it around the block.
Re: Hemi expertise needed [Re: DaveRS23] #1390209
03/09/13 11:39 AM
03/09/13 11:39 AM
Midwest
fuseable Offline
fuseable  Offline
Midwest
Check the upper rear main seal slot that receives the upper half of the seal. I have a block of the same vintage and the upper seal is off to one side .70 + or -, I have tried 3 rear mains and I cannot get it to stop leaking,(a very small leak, that I have lived with for years)I will go with a rope seal next winter. You might check your block before assembly.
Re: Hemi expertise needed [Re: DaveRS23] #1390210
03/21/13 01:14 PM
03/21/13 01:14 PM
Lifsgrt Offline OP
Lifsgrt  Offline OP
Hey Dave, moved my stuff there last June, then went to El Paso / Ft. Bliss TX to train up for another tour in AFG. Am there now...look forward to getting home and putting some projects together! Most of my stuff is in So. IL in storage at the moment. Keep me posted on your new bullet...the flat tappet cam from Scott Brown really worked out well, thanks for the tip! Ran out of traction at 11.20s @120 though! Not too bad for a 4100lb street car! Looking forward to seeing how the Hemi does, in a '68 Barracuda built as an BO29 clone!
Re: Hemi expertise needed [Re: Lifsgrt] #1390211
03/21/13 01:15 PM
03/21/13 01:15 PM
Lifsgrt Offline OP
Lifsgrt  Offline OP
Thanks for the tips guys, I'll check on those issues when I see the engine in a few months. I appreciate the help.
Re: Hemi expertise needed [Re: Lifsgrt] #1390212
03/21/13 10:17 PM
03/21/13 10:17 PM
Benton, IL.
Special needs idiot
Special needs idiot
Benton, IL.
11.20s spinning. That's a good start. We have got to get together when you get back.
Good luck!
Re: Hemi expertise needed [Re: Lifsgrt] #1390213
03/21/13 10:31 PM
03/21/13 10:31 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
Gents,
Block p5007668
Flywheel p4529143
Right carb p4452778
Left carb p4452779
Starter p5249644
Oil pump p4286590
Gasket p5007345
Fuel pump p4007039
Oil pan p4529884
Fan p4120758
Dipstick p4349629
If those heads are the pre Edelbrock aluminum heads I would be leary. Numerous problems with seats, guilds, machining.
The old blocks are fine, but I would measure everything. You might find the bores are all over the place and the deck has too coarse a finish
Re: Hemi expertise needed [Re: Troy] #1390214
03/22/13 01:48 PM
03/22/13 01:48 PM
Harrison Township, Michigan
Hemi SS Offline
Hemi SS  Offline
Do they make the TTI headers to fit the Stage V replacement heads?
Re: Hemi expertise needed [Re: Hemi SS] #1390215
03/22/13 02:59 PM
03/22/13 02:59 PM
California
mickm Offline
mickm  Offline
California
yes, standard hemi headers. 2 1/8, and i believe the 2 1/4 are the same flange and bolt pattern.
i have the 2 1/8 on my car, and they have been on both mopar and stage V heads.
