Re: 1968 383 Roadrunner Assemblyline Exhaust Questions
[Re: Mike Mancini]
#1390111
02/19/13 06:37 PM
02/19/13 06:37 PM
I know its not a picture on the car but I heard ECS now makes exact reproduction pieces. Also Accurate Exhaust claims to be correct too. I know Gardner is expensive but don't know how correct theirs is. Maybe one of those 3 have either pics of originals on the car or off the car for comparison.
[Re: Mike Mancini]
#1390113
02/19/13 07:18 PM
02/19/13 07:18 PM
oh ok. maybe one of them has some pics which would help ya?
[Re: Mike Mancini]
#1390114
02/19/13 07:54 PM
02/19/13 07:54 PM
moparpollack
Lil Herman
Lil Herman
85086
How much of the exhaust any certain parts?
[Re: lewtot184]
#1390117
02/20/13 07:32 AM
02/20/13 07:32 AM
i remember on my '68 383 car that the exhaust pipe, 2 1/4" o.d., was welded to the muffler and the muffler was smaller than the 440 cars.
Thats weird that Chrysler would make a different muffler for a separate B engine and waste all the money for engineering something different when the over the counter replacement stuff wast he same as the 440's. Even the parts book I have lists the same muffler for the big blocks.
[Re: ]
#1390118
02/20/13 10:35 AM
02/20/13 10:35 AM
Posts: 3,916 usa
lewtot184
usa
thats what i thought until i went to change them. i did end up using a 440 muffler because it would slip over the pipe and the replacement was a butt weld. remember that 383's had smaller exhaust and tail pipes vs the 440 cars.
[Re: MO_PA]
#1390121
02/20/13 07:08 PM
02/20/13 07:08 PM
Posts: 3,916 usa
lewtot184
usa
Butt weld would never be factory!! Sometimes on those new cars we at the dealer would put a couple of small welds at joints so the pipes would not twist and or come apart. Other times we drilled a small hole and put a small screw through the joint. As I remember the mufflers were the same length on 383's and 440's.
really? i bought the car new in april of '68. played around with it for 6yrs. i think i ought to know what it was, .
[Re: 6bblgt]
#1390122
02/20/13 07:15 PM
02/20/13 07:15 PM
Posts: 3,916 usa
lewtot184
usa
In 1970 they made specific 383 mufflers for cars sold in CA.
So, a different factory exhaust/muffler for the introduction of the '68 383 Road Runner vs. 440 GTX (with H-pipe) is easily possible. When introduced, the '68 Road Runner was the only car available with the 383HP 335hp engine.
Pontiac had a mechanically operated "cut-out/straight-thru" muffler available as an OPTION in '70, I'm sure a bunch of engineering went into that for the few that were built. Monies were spent on creating the correct desired "IMAGE".
i still have the original exhaust pipes off my '69 r/t, h-pipe and tails. the exhaust pipes on my road runner were 2 1/4" o.d.. they were swagged out at the manifolds with the 2 1/2" flanges welded to them; no h-pipe. the h-pipe of my r/t is welded one piece 2 1/2" with flattened sections and would not bolt to a 383 do to width. the r/t had 2 1/4" aluminized tail pipes, my road runner didn't.
[Re: Mike Mancini]
#1390127
02/21/13 06:44 PM
02/21/13 06:44 PM
Posts: 75,094 A Banana Republic near you.
JohnRR
Does anyone have pics of original 383 mufflers?
put your money where your mouth is ... typical moparts ....
I have a serious question , where they actually but welded or did the muffler slip over the pipe and it was welded ?
[Re: Troy]
#1390129
02/21/13 07:00 PM
02/21/13 07:00 PM
JohnRR
Mike....I don't think anybody does....
There is a 27k mile original 69 RR on the 'bag I don't know it it has original exhaust on it , it looked to shiney , but it appeared to have welded mufflers and they were crushed corner like the original Hemi mufflers .
