1970 Charger Filler Tube Vent Line #1390001
02/18/13 10:46 PM
02/18/13 10:46 PM
Michigan,Macomb County
RTChargerman Offline OP
Hello,I am working on a 1970 440 RT CHARGER, Can anyone give some information on the filler tube vent line, WHERE DOSE IT GO ???? The car was apart when I bought it,and I can't find any info on it in my restore books THANKS Jim
Re: 1970 Charger Filler Tube Vent Line [Re: RTChargerman] #1390002
02/19/13 12:15 AM
02/19/13 12:15 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
i can tell you the 68 goes in the frame & vents
Re: 1970 Charger Filler Tube Vent Line [Re: RTChargerman] #1390003
02/19/13 12:47 AM
02/19/13 12:47 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
On my 70 Charger the vent tube clipped on the main filler tube, then ran into a small trunk floor grommet, into the frame, then attached to a rubber vent line that went on a single vent nipple on the tank sending unit, the upper part of the vent tube followed upward to the filler cap, then promptly took a 90 degree turn with a short rubber connector into the main filler tube, just below the flip cap, under the rear qtr
mike
Re: 1970 Charger Filler Tube Vent Line [Re: CSK] #1390004
02/19/13 02:16 AM
02/19/13 02:16 AM
Thanks for the help !!!
Re: 1970 Charger Filler Tube Vent Line [Re: DAYCLONA] #1390005
02/19/13 02:19 AM
02/19/13 02:19 AM
Thanks for the help,the picture shows it all !!!!
