Eating My Lunch!!!
#138963
10/20/08 07:25 AM
10/20/08 07:25 AM
Posts: 128 usa
mrmopardan
usa
440 6 PACK.. When the engine is warm it is extreamly hard to restart. Runs perfect once started. It will only start if the accelerator is pushed completely to the floor but it does not seem like it is flooded. Fuel is below all sight plugs & the shooter is working good. Choke is disconnected. It just started this nonsense after I fixed a vacuum leak caused by a mis- ajusted rear carb linkage in the rear carb. As always I turn to you guys for your knowledge. Thanks, danny
68 GTX Full street trim, solid lifter cammed. Best 11.34 @ 121 mph. 1.72 60 ft. (yeah I know.. my 60 ft. sucks)
Re: Eating My Lunch!!!
[Re: doctor_mopar]
#138965
10/20/08 07:58 AM
10/20/08 07:58 AM
Posts: 128 usa
mrmopardan
usa
George is that you..? Give me a hint!! Yeah. Just when I think I know everything about the 6 pack something simple gets over looked & I'm a novice once again. Choke looks fine!! I'll keep poking till I find the problem. Any other takers out there? So easy a Caveman could do it.. yeah my a$$>
[Re: mrmopardan]
#138966
10/20/08 08:07 AM
10/20/08 08:07 AM
Posts: 845 Kansas
64Belvedere
super street
super street
Kansas
I know next to nothing about six-pack induction, but could the fuel be percolating after you shut the engine off? I don't know if those manifolds had a crossover or not.
[image][/image]
[Re: mrmopardan]
#138967
10/20/08 08:12 AM
10/20/08 08:12 AM
Posts: 1,043 Slidell, La.
doctor_mopar
Slidell, La.
This is Ron Howard. You have a PM
------------------------ It doesn't matter what you do.........As long as you look good doing it !
[Re: mrmopardan]
#138969
10/20/08 08:22 AM
10/20/08 08:22 AM
doctor_mopar
Slidell, La.
Maybe you're looking in the wrong place. Could it be some coincidence that a little more air helps it start. Maybe week ignition. Did you knock a wire loose at the ballast resistor ? See if you are getting a hot spark.
