Hemi rocker stands #1389554
02/18/13 01:25 AM
02/18/13 01:25 AM
gulfport, ms, west mi
rowin4 Offline OP
rowin4  Offline OP
Who's the guy/business that sells the Hemi rocker stands that the top half is split so the shafts can be installed without pushing them through the holes?
Re: Hemi rocker stands [Re: rowin4] #1389555
02/18/13 01:35 AM
02/18/13 01:35 AM
RAS made some of them so you could change the center of the shafts to get the ratio on the rocker correct but I don't think they got beyond the research and development stage
Re: Hemi rocker stands [Re: Cab_Burge] #1389556
02/18/13 01:37 AM
02/18/13 01:37 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Dvorak,dont waste your money. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Hemi rocker stands [Re: astjp2] #1389557
02/18/13 11:24 AM
02/18/13 11:24 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Indy sells a set like this also but the the way they split them makes it so one can correct geometry the correct way .
They aren't cheap though.
