Re: Green with envy!
[Re: astjp2]
#1389547
11/25/14 02:11 PM
11/25/14 02:11 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
So I am looking at starting to work on the car again, I need to get a new liner for the gas tank to trunk floor, should I get a felt one or rubber? They are both available for about the same money. What about replacement trim, I am finding that I can get some pieces for $100 from some suppliers and others its $200, same with marker lights, some are cheap, others are ridiculously expensive....Thanks Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: astjp2]
#1389549
11/26/14 07:28 PM
11/26/14 07:28 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
I used the rubber, never tried the felt. If you want some more input, I would start a new thread with gas tank pad in the subject line Dave
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: DPelletier]
#1389550
12/12/14 08:11 AM
12/12/14 08:11 AM
astjp2
Utah and Alaska
Well so far I ordered the tank pad from DTM, I just got my Bergman 1.15 torsion bars and spring hanger shims, Classic Ind. ordered my US Radiators 4 core triple pass copper/brass radiator, gas cap and filler neck is on the way. I may get a few things done this year. Hopefully I will be able to start the engine and listen to it go rumpty rumpty....
[Re: DPelletier]
#1389552
12/12/14 05:25 PM
12/12/14 05:25 PM
astjp2
Utah and Alaska
I am going to also replace the tublar upper control arms I bought, they are adjustable from RMS, but I don't like the fact they don't touch the bump stops. So I may do the Firm Feel ones or the ones from Ride tech, probably go with the firm feel ones, I cant afford the Hotchkis stuff and I despise heim joints. After working on helicopters for years, I wont put a heim joint on anything that goes on the highway. Tim
[Re: astjp2]
#1389553
12/15/14 10:35 PM
12/15/14 10:35 PM
astjp2
Utah and Alaska
So I got my fuel filler neck in from Vans auto, gas cap came in from BEA, radiator cam in from US radiators purchased through Classic Ind. I sent the radiator in and found that the core support brace was not installed right by the welder and now I have to cut it out and get a new one installed that will clear the radiator...crap, more work to fit something that should have in the first place....Gas Cap looks beautiful though....Tim
