Minimum tire to quarter panel clearance? #138899
10/19/08 09:21 PM
10/19/08 09:21 PM
Phoenix, AZ
Belvedere1 Offline OP
Phoenix, AZ
For a street car, just need to know the safest minimum clearance between the "lip" and in the outer wheel house area on a 67 Plymouth.
Re: Minimum tire to quarter panel clearance? [Re: Belvedere1] #138900
10/20/08 12:13 AM
10/20/08 12:13 AM
Santa Cruz, California
Lefty Offline
Lefty  Offline
I would not run any closer than 1/2"
Re: Minimum tire to quarter panel clearance? [Re: Lefty] #138901
10/20/08 04:10 PM
10/20/08 04:10 PM
Phoenix, AZ
Phoenix, AZ
thanks Lefty,
Do recall the section width on the tires you are running?
Re: Minimum tire to quarter panel clearance? [Re: Lefty] #138902
10/20/08 04:10 PM
10/20/08 04:10 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I've run as close as 1/4" for years with no ill effects. Actually the inner side of the quarter panel is almost always closer than the lip.
Doug
Re: Minimum tire to quarter panel clearance? [Re: dvw] #138903
10/20/08 06:07 PM
10/20/08 06:07 PM
Phoenix, AZ
Phoenix, AZ
are you refering to a 66-67 B body?
Re: Minimum tire to quarter panel clearance? [Re: Belvedere1] #138904
10/20/08 06:35 PM
10/20/08 06:35 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Check it with a straight edge. You will find most wheel wells like that. My 64 Belvedere is that way
I haven't had a 66 or 67 Plymouth since 72. It did have americans on it and the tire was close to the lip. What you may have to watch for is like my Challenger. The lip is the closest spot. But only the very rear of the lip where it turns down towards the bottom of the quarter panel. The rest isn't a factor. You are blessed with the smallest rear wheel weels of any B-Body. Good luck.
Doug
Re: Minimum tire to quarter panel clearance? [Re: dvw] #138905
10/20/08 06:43 PM
10/20/08 06:43 PM
Phoenix, AZ
Phoenix, AZ
More like cursed!
The quarters were replaced at one time and I had to trim the lip down to roughly 3/8" to get the clearance that I have now which is very little at a 1/4" on the left side. The right side quarter has enough clearance for me to consider it safe but the right side is the problem at this point. Even up in the wheel house there is still only about a 1/4" clearance to the sidewall. Of course I am trying to squeeze an 8" wheel with a 265/60 McCreary DOT in there, thus my problem.
Re: Minimum tire to quarter panel clearance? [Re: Belvedere1] #138906
10/20/08 06:54 PM
10/20/08 06:54 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
265 will be very snug and if it works you will need a 5 1/2" backspace on that 8" wheel.. Lefty sent me some pics showing that the outside fender well curves in as it goes up creating the tightest area in the fender well..
On my 67 coronet I am going to use 245-60-15 on 8" wheels with a 5 1/4 backspace on the back.
Re: Minimum tire to quarter panel clearance? [Re: minivan] #138907
10/20/08 07:01 PM
10/20/08 07:01 PM
Phoenix, AZ
Phoenix, AZ
That much backspace would put this tire/wheel combo into the leaf spring. As it is now I have 3/4-7/8" clearance from the sidewall to the spring. I think the Dodges are contoured a little different than the Plymouth with the Plymouths having a tad more room. The section width of this tire shows 10.6" with an 8" wheel.
Re: Minimum tire to quarter panel clearance? [Re: Belvedere1] #138908
10/20/08 08:03 PM
10/20/08 08:03 PM
NH
Fastback67 Offline
Fastback67  Offline
NH
My 67 Charger is wearing BFG 295/50/15's in the rear mounted on 10" rims with a 5" backspace. The tire is 13" wide and 27" tall. The wheel well is 14" deep. No problems ever...
Re: Minimum tire to quarter panel clearance? [Re: Fastback67] #138909
10/20/08 11:16 PM
10/20/08 11:16 PM
Phoenix, AZ
Phoenix, AZ
After some further measurement I have 9/32" clearance from the lip to the sidewall. The section width of the tire measures 11 1/2". I still cant understand how there is that much variation from one side to the other. I looked at loosening the U-bolts to try and center the rearend housing better, but there is no room for movement where the guide pin on the spring pack goes into the mount.
Fastback,
Are your springs and wheel tubs stock?
Re: Minimum tire to quarter panel clearance? [Re: Belvedere1] #138910
10/21/08 12:13 PM
10/21/08 12:13 PM
Lefty Offline
Lefty  Offline
Nitto 555 255/45/18" - 10.16"
http://www.nittotire.com/#index%2Etire%2Ent555%2Esizes
Re: Minimum tire to quarter panel clearance? [Re: Lefty] #138911
10/21/08 05:49 PM
10/21/08 05:49 PM
Fort Morgan
1OFNONE Offline
Has been a member for quite a few years, so relax.
1OFNONE  Offline
Fort Morgan
I had the same issue with my Coronet. I trimmed the outside lip a quarter inch. The drivers was closer than the passenger side till I put solid front bushings in the leafs. hen that squared it up. That was with a 29x9 M&H slick on a 15x8 Cragar with 4.25 back space.
[image][/image]
So the bartender says to the horse " Gee, Why the long face?"
Re: Minimum tire to quarter panel clearance? [Re: 1OFNONE] #138912
10/21/08 09:43 PM
10/21/08 09:43 PM
Phoenix, AZ
Phoenix, AZ
I guess I am not seeing how the solid bushings would change things in making the tire fit in there better, I could see controlling the body roll a little though.
What was the section width on those M & H's?
