1971 Hemi B body choke cable hole #1389016
02/17/13 01:55 PM
02/17/13 01:55 PM
Phila Pa
scatpacktom Offline OP
Phila Pa
The U code car in my signature is about to get a Hemi. I am pretty sure the choke cable comes through the firewall right next to the Ramcharger hoses just to the right of them.(if you are looking at it)
Anybody have a real good photo? Also I assume it is a 3/4 inch hole? The end of the cable is pretty bulky so I know it isn't a small hole. Any pics of the way it is routed under the dash?
Re: 1971 Hemi B body choke cable hole [Re: scatpacktom] #1389017
05/02/13 08:45 AM
05/02/13 08:45 AM
Phila Pa
Phila Pa
Ok, I've got everything worked out accept the size of the hole the cable goes through in the firewall? I think it could be 3/4 but I would like to be sure.
Anybody?
Re: 1971 Hemi B body choke cable hole [Re: scatpacktom] #1389018
05/02/13 07:06 PM
05/02/13 07:06 PM
New York
E
EL5 71 Offline
EL5 71  Offline
E
New York
Interestingly, I have a 71 Charger R/T, U code, Ramcharger Hood car with both holes factory drilled. 3/4 inch for each hole. Factory paint around edges of both holes. Still can't figure out why the one to the right of the Ramcharger hose hole was drilled on a non-Hemi car. August 1970 built car so who knows, maybe it was an error. I know that probably doesn't help you much but I have seen a few 71 Hemi Chargers during restoration and I noted that the choke cable hole was larger than the Ramcharger hose hole. I also noticed that a couple of the cars have the different sized holes factory drilled in opposite locations.
Re: 1971 Hemi B body choke cable hole [Re: scatpacktom] #1389019
05/02/13 10:49 PM
05/02/13 10:49 PM
N.E.Ohio
P
pacifica Offline
pacifica  Offline
P
N.E.Ohio
There are lots of pics at this site.
Don't know if this pic helps, but maybe?
linky linky to 71' Hemi
Re: 1971 Hemi B body choke cable hole [Re: scatpacktom] #1389020
05/02/13 11:47 PM
05/02/13 11:47 PM
El Cerrito, by San Francisco
last426 Offline
last426  Offline
Here is the hole. Kim
Re: 1971 Hemi B body choke cable hole [Re: scatpacktom] #1389021
05/03/13 12:26 AM
05/03/13 12:26 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
I used a unibit and slowly opened up the hole till the rubber grommet fit just right. Yes that dimple is where it goes.
Re: 1971 Hemi B body choke cable hole [Re: 71birdJ68] #1389022
05/03/13 01:29 PM
05/03/13 01:29 PM
Phila Pa
Phila Pa
I don't have the cable in hand yet and the 440 is coming out this weekend. I'd like to punch the hole while I can stand in there.
Thanks for the replies
Re: 1971 Hemi B body choke cable hole [Re: scatpacktom] #1389023
05/04/13 10:19 PM
05/04/13 10:19 PM
N.E.Ohio
P
pacifica Offline
pacifica  Offline
P
N.E.Ohio
Is the Bee going into retirement or are mid elevens too slow?
Re: 1971 Hemi B body choke cable hole [Re: pacifica] #1389024
05/05/13 12:15 AM
05/05/13 12:15 AM
Phila Pa
Phila Pa
Variety is the spice of life
