sould i see oil rings? #1389014
02/17/13 01:45 PM
02/17/13 01:45 PM
okla.
sam64 Offline OP
sam64  Offline OP
okla.
i just got my 499 low deck and when i went to put the oil pan on i noticed that i can see the bottom oil ring at the wrist pins.is this normal,they are mahle pistons.thanks,sam.
Re: sould i see oil rings? [Re: sam64] #1389015
02/17/13 02:34 PM
02/17/13 02:34 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
Prolly normal, the oil ring is machined through the wrist pin since the pistons are quite short in that combo
