Green bearings vs Adjustable style. #1388913
02/17/13 03:02 AM
02/17/13 03:02 AM
Rockford,IL
71Polara383 Offline OP
Rockford,IL
What are the pros and cons of this swap? I've been getting a-lot of static that the green style bearings aren't street friendly. Is this true? Trying to order the right stuff for the 8 3/4 I'm swapping into my Cordoba. Thanks Moparts.
Re: Green bearings vs Adjustable style. [Re: 71Polara383] #1388914
02/17/13 03:17 AM
02/17/13 03:17 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
It has been reported that the green bearings will not handle the side loads that the tapered roller bearings will. While this is definitely true, I don't know how much more the rollers will h andle and whether it matters on a street car. I will continue to run the original tapered rollers.
Re: Green bearings vs Adjustable style. [Re: Jim_Lusk] #1388915
02/17/13 04:02 AM
02/17/13 04:02 AM
Florida STAYcation
BeEtLeJuIcE ! Offline
The village idiot's idiot
Florida STAYcation
x99 .... ESPECIALLY in a heavy car like a 'Doba.
Re: Green bearings vs Adjustable style. [Re: 71Polara383] #1388916
02/17/13 04:19 AM
02/17/13 04:19 AM
It probally depends on how you drive it and if it has a open, posi or spool in it I drove my Duster on the street with the green bearings from Strange Engr.(they have the locating clips on the outside of the bearings ) with a spool for 7 yrs, not a lot of street driving(less than 3000 miles on the street probally) but quite a bit of drag racing, no problems with them I would have ran the Timken tapered axle bearings if I could have but not so with the 35 spline spool and axles
Re: Green bearings vs Adjustable style. [Re: 71Polara383] #1388917
02/17/13 07:31 AM
02/17/13 07:31 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
If your present bearings show no galling or scoring clean, pack and reuse. They will last forever for you if installed and adjusted correctly. One you have done it you will likely never have to do it again with the amount of miles these cars will typically get. IMO stick with the tapered bearings. http://www.moparts.org/Tech/Archive/axle/12.html
Re: Green bearings vs Adjustable style. [Re: 71Polara383] #1388918
02/17/13 10:51 AM
02/17/13 10:51 AM
Columbus, GA
Michael Ecks Offline
Columbus, GA
If you can reuse the stock set up I say go that direction. They were a great design, which is why so many people swear by them. Especially if you can reuse the ones already in there by just repacking them.
On the other hand, if for some reason you can't use the stock tapered set up, don't worry too much about running greens. From what I understand most modern rear wheel drives use them from the factory.
I've had green bearings in my challenger for many years. I used the non-snap ring style. Same set for 18-ish years, and probably 100,000 miles of daily driving and Friday night red light to red light abuse. In my case, the housing I swapped in had been adjusted wrong and allowed the outer race to spin wearing out the seating surface in the housing end. Greens were the perfect fix. That said, I do have one side making some funny noises now, but after that many years and miles I'll happily put new greens in when I go through the rear again instead of buying another housing.
My .
X
"The happiness of your life depends upon the quality of
your thoughts" ~ Roman Emperor Marcus Aurelius
Re: Green bearings vs Adjustable style. [Re: Michael Ecks] #1388919
02/17/13 02:49 PM
02/17/13 02:49 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I have been using green bearings on the street for over 3 years in my 63. No problems at all. Ron
Re: Green bearings vs Adjustable style. [Re: 71Polara383] #1388920
02/17/13 03:30 PM
02/17/13 03:30 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
This notion that you cant run a ball type bearing on a street car is just plain STUPID! While it's true that a tapered roller bearing can handle more load the radial ball bearing design is more than capable of handling the side load of a street car.Ford has used them forever in the 9" style rear end and you don't hear about guys converting them over to tapered rollers for street use I have been working on Toyota pick-up trucks for thirty years that use the same basic design and have very few troubles with them and some of the trucks I work on are beat to death daily.
Gus
64 Plymouth Savoy
Dana 60
Re: Green bearings vs Adjustable style. [Re: 71Polara383] #1388921
02/17/13 04:20 PM
02/17/13 04:20 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Street-driven '71 Ply B-body...
Had the driver's side go bad at 20k...
I'll agree with Ehrenberg on this one...
OEM for me...
Re: Green bearings vs Adjustable style. [Re: fourgearsavoy] #1388922
02/17/13 05:05 PM
02/17/13 05:05 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
While it's true that a tapered roller bearing can handle more load the radial ball bearing design is more than capable of handling the side load of a street car. Ford has used them forever in the 9" style rear end and you don't hear about guys converting them over to tapered rollers for street use
Ford used both a ball bearing and a tapered roller bearing...I think you'll find that the tapered is more desired than the ball.
Re: Green bearings vs Adjustable style. [Re: John_Kunkel] #1388923
02/17/13 05:34 PM
02/17/13 05:34 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Because Ford 9" (Set 20) tapered wheel bearings are known to leak, most guys I deal with prefer the sealed ball design for car applications.
Re: Green bearings vs Adjustable style. [Re: 71Polara383] #1388924
02/17/13 05:36 PM
02/17/13 05:36 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Been swapping Greens in for quite a few decades on Mopars, not a single failure, or issue...but again as with anything mechanical, abuse, improper installation, etc, etc, can lead to failure
Detroit has installed Millions of Green bearings, haven't heard about any massive recalls yet?
Re: Green bearings vs Adjustable style. [Re: DAYCLONA] #1388925
02/17/13 08:52 PM
02/17/13 08:52 PM
Upper Midwest
Upper Midwest
You guys are right that the sealed ball bearing Greens are fine and will likely out last the vehicle. I say that if there is nothing wrong with the OEM bearing on the axles leave well enough alone and save the money . Clean inspect, repack, replace the inner seal, reinstall axle and adjust the endplay and have fun.
Re: Green bearings vs Adjustable style. [Re: MoparforLife] #1388926
02/17/13 10:44 PM
02/17/13 10:44 PM
Rockford,IL
Rockford,IL
This is the kit I would need then? Ebay
Re: Green bearings vs Adjustable style. [Re: 71Polara383] #1388927
02/18/13 12:04 AM
02/18/13 12:04 AM
PA
68_CONV_300 Offline
68_CONV_300  Offline
PA
yes sir ... that will do what you need
Re: Green bearings vs Adjustable style. [Re: 71Polara383] #1388928
02/18/13 11:07 AM
02/18/13 11:07 AM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
Tapered roller bearings are unbeatable when side thrust pressure is considered. All of the high speed passenger trains of the 50's and 60's traveled on tapered roller bearings made by Hyatt, SKF but primarily by Timken. The same brand mother Mopar installed.
If you only travel in a straight line, your car is a trailer queen, or if you really really need disc brakes on the rear and need more clearance, Green bearings are just fine. They are not that horrible to change out anyway.
As previously posted, if properly greased, rollers will last a very long time. The exception is if they get drenched in water due to seal failure.
Craig
Re: Green bearings vs Adjustable style. [Re: 71Polara383] #1388929
03/04/13 08:55 AM
03/04/13 08:55 AM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
When I first saw the Greens 30+ years ago, I freaked....I thought they would fail catastrophically and you'd lose a wheel. Turns out, that, while they are nowhere near as beefy and long-lasting as the OEM Timkens, they do give plenty of advance notice (noise) before they totally fail.
Still, I have personally never seen one last more than 10K or so in 'real street' use, 5K is more typical. I have changed plenty of 'em, whereas the stockers last nearly forever with good grease and reasonable endplay adjustment.
Rick
Re: Green bearings vs Adjustable style. [Re: Rick_Ehrenberg] #1388930
03/04/13 10:34 AM
03/04/13 10:34 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
First generation(RP-400)Green bearings, still sold by Mopar Performance, are problematic because the crimped on flange will not allow the bearing to wiggle around inside a housing that is not perfectly straight (none are).
In addition, the design causes the axle to be inserted DEEPER into the housing than necessary. This results in pre-loading against the differential thrust block.
Second generation (MO-400/ST-400) snap ring style Green bearings are more forgiving because they can move around inside the housing and they do not preload the differential thrust block in a stock application.
Most guys who have problems with Green bearings are running the Mopar Performance version or incorrectly made aftermarket axles, housings or poorly designed rear disc brake kits (ie. Wilwood), all of which cause pre-loading and premature bearing failure.
I have several customers running MO-400 snap-ring Green bearings in daily drivers. The design is no different than what came stock in millions of other vehicles, including '60s era Mopar 7.25" rears.
http://www.rockauto.com/catalog/moreinfo.php?pk=221853&cc=1496034
Re: Green bearings vs Adjustable style. [Re: DoctorDiff] #1388931
03/04/13 11:53 AM
03/04/13 11:53 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Agreed....I have over 40,000 miles on the set in my 70 Charger (DANA 60 SSBC rear discs)...plenty of street miles, cross country runs, and assorted Autocross/Track events...no issues, again any componet can fail if the application is improperly chosen, and/or installed improperly, or just severly beaten...I've tosted more factory tapered bearings than I can count in Dana's or 8.75's...I have to date never had a failure of a Green Bearing on my car, or customers builds...
mike
