Original 340-6 valve covers #1388542
02/16/13 05:15 PM
02/16/13 05:15 PM
Ont, Canada
moparo Offline OP
moparo  Offline OP
Ont, Canada
Can some post a picture please of an original valve cover for these cars.
performancecarrestorations.com
Re: Original 340-6 valve covers [Re: moparo] #1388543
02/17/13 12:37 AM
02/17/13 12:37 AM
West Coast, CA
Troy Offline
Troy  Offline
West Coast, CA
Here you go..
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
Re: Original 340-6 valve covers [Re: Troy] #1388544
02/17/13 12:37 AM
02/17/13 12:37 AM
West Coast, CA
Troy Offline
Troy  Offline
West Coast, CA
#2
Re: Original 340-6 valve covers [Re: Troy] #1388545
02/17/13 12:41 AM
02/17/13 12:41 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
While I'll agree that there were two different rear upright wire loom bracket locations on 70-71 340 valve covers, they were not different for the application (340+6 vs 340+4) it was completely random as to which came on either engine.
Re: Original 340-6 valve covers [Re: Troy] #1388546
02/17/13 09:56 PM
02/17/13 09:56 PM
Ont, Canada
moparo Offline OP
moparo  Offline OP
Ont, Canada
Thanks Troy good comparison
Re: Original 340-6 valve covers [Re: moparo] #1388547
02/17/13 10:30 PM
02/17/13 10:30 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I have no doubt that Troys examples came off of the respective cars he mentioned, however, keep the comments I posted in mind when making the call on what is correct or not, niether style was exclusive to 340+4 or 340+6 engines.
Here is one I removed from a May 1971 built 340 A-body (notice the original blue paint?)
Re: Original 340-6 valve covers [Re: ScottSmith_Harms] #1388548
02/17/13 10:35 PM
02/17/13 10:35 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
These are marked "Supposedly" in this pic because they came on cars that had the opposite application, the forward postioned version was on an original AAR 340+6, and the rearward position example was on a 1970 340 Duster. both were unmolested original paint examples before I personally removed them.
Re: Original 340-6 valve covers [Re: ScottSmith_Harms] #1388549
02/17/13 10:40 PM
02/17/13 10:40 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Here's another weird one. Ever see a 70-71 340 (original orange engine) with a 3 wire tab valve cover instead of the large wire loom center tab? Here's one off of a 1970 340+4, original orange paint. In April/May of 1971 all 340+4 barrels went to this style when they started painting the engines blue.
Re: Original 340-6 valve covers [Re: ScottSmith_Harms] #1388550
09/06/13 10:04 AM
09/06/13 10:04 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Re: Original 340-6 valve covers [Re: ScottSmith_Harms] #1388551
09/06/13 10:33 AM
09/06/13 10:33 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Scott,you can't see them but this 71 also has the three tab's.
Re: Original 340-6 valve covers [Re: 62maxwgn] #1388552
09/06/13 10:36 AM
09/06/13 10:36 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
One of the 71 Canadian 340 Swingers.
Re: Original 340-6 valve covers [Re: 62maxwgn] #1388553
09/06/13 10:39 AM
09/06/13 10:39 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
What is the SPD of the Dart?
Re: Original 340-6 valve covers [Re: ScottSmith_Harms] #1388554
09/06/13 11:13 AM
09/06/13 11:13 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
828
Re: Original 340-6 valve covers [Re: 62maxwgn] #1388555
09/06/13 12:05 PM
09/06/13 12:05 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
That's early, any chance the covers were swapped? Do you have a pic of the block stamping under the drivers side head?
Re: Original 340-6 valve covers [Re: ScottSmith_Harms] #1388556
09/09/13 03:11 PM
09/09/13 03:11 PM
Ontario, Canada
mccannix Online content
mccannix  Online Content
Ontario, Canada
Trying to figure this..
The top valve cover is an original paint turquoise passenger side one with large wire loom.
The bottom is the later original paint orange passenger side with the loom.
Since the turquoise one does not have provision for oil fill and the orange one does, the turquoise early year engine fills oil on the drivers side instead of passenger side
Re: Original 340-6 valve covers [Re: mccannix] #1388557
09/09/13 03:12 PM
09/09/13 03:12 PM
Ontario, Canada
Ontario, Canada
original turquoise paint...
Re: Original 340-6 valve covers [Re: mccannix] #1388558
09/09/13 03:36 PM
09/09/13 03:36 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Turquoise = 69 340 pass side valve cover
Re: Original 340-6 valve covers [Re: ScottSmith_Harms] #1388559
09/09/13 05:02 PM
09/09/13 05:02 PM
Ontario, Canada
Ontario, Canada
understood that, should have stated that I was trying to figure out why Chrysler created so many different 340 valve covers and switched oil fill sides.
Just using passenger side for example there are no less than 3 different ones 68-71:
1968 passenger side was red with small tabs, no large wire loom, plug wire grommets on top, opposite side oil fill. 69 is turquoise with small tabs and large loom, opposite side oil fill. 70 and some 71's orange, with small tabs and large wire loom, oil filled side. Later 71's blue with small tabs minus the large loom and I have seen several passenger orange like last one Scott posted less the loom, both oil filled side.
I think 73's are different again with the longer small tabs.
Re: Original 340-6 valve covers [Re: mccannix] #1388560
09/09/13 08:13 PM
09/09/13 08:13 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Changing emissions regulations and engine venting were the main reasons. The looms changed to help protect engine harnesses and plug wires from the various exhaust, intake manifold, and heat cross over choke designs.
Re: Original 340-6 valve covers [Re: ScottSmith_Harms] #1388561
09/10/13 12:30 AM
09/10/13 12:30 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Terry, here's an original pair of 69 340 valve covers, original turquoise paint with some orange over spray from them being used to cover an engine that was being painted orange.
