Re: Gen III Hemi to a 727...Adapter?
[Re: 340RICK]
#1388534
02/17/13 07:27 PM
02/17/13 07:27 PM
Posts: 306 Mesa, AZ
cagebob1
Mesa, AZ
I bought my flex plate from Mancini
It was a direct fit no spacer. 6.1 hemi to 727
Thanks..That's the kind of answer I was looking for
Now..on to the next question: since I plan on running a mid-plate, can I run .090" steel without any converter mods? or should I run a 3/16 aluminum plate and have the converter built accordingly?
[Re: cagebob1]
#1388535
02/17/13 08:02 PM
02/17/13 08:02 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Since your playing with a 727 I have no problems running a .090 mid plate with the normal conv nose.. if you go above .090 (like .125 I would suggest that you have the nose lengthened).... unless for some odd reason they have the flex farther into the back of the G3 block... but the trans is still in the same place as my R3 so you should be fine
[Re: cagebob1]
#1388537
02/17/13 10:04 PM
02/17/13 10:04 PM
Posts: 729 Lebanon,IN
mr2performance
Lebanon,IN
If you run the mopar flexplate without a midplate with a normal small block converter, the converter will almost touch the flexplate when its all the way engaged. If you run it that way, good luck. Cut the lugs down .070 (I believe it was me who told you that) and it'll be perfect or run a .090 midplate and you'll be fine. Mike
MR2PERFORMANCE RACE CARS
765 483 9371
[Re: sixpackgut]
#1388539
02/17/13 10:27 PM
02/17/13 10:27 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
on another note, I bought my flex plate from Mancini for like $69, when a friend of mine ordered his, Mancini talked him into a flex plate that cost twice as much, why? I don't know. maybe the offset on the cheap one I got isn't right requiring a spacer
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#1388540
02/17/13 10:27 PM
02/17/13 10:27 PM
mr2performance
Lebanon,IN
All you had to do was call Mike
765 483 9371
