440 Streetmaster Intake. How does it compare? #1388261
02/16/13 03:04 AM
02/16/13 03:04 AM
Granite Bay CA
Kern Dog Offline OP
Striving for excellence
Kern Dog  Offline OP
Granite Bay CA
In another thread, I asked about swapping intakes in the Power Wagon to gain some more power. I got the truck with a 440, 4 speed 4wd and 4.10 gears. The engine has an SP2P intake, ThermoQuad carb, stock exhaust manifolds and a 2 1/4" exhaust system. The engine has about 100,000 miles on it and runs smoothe with no smoke.
The truck falls on its face above 3000-3500 rpms. I'm certain that this SP2P is to blame, and I have 2 intakes on the shelf here that I can try. I asked previously about the "Performer" that I have, but I recently acquired a "Streetmaster 440" intake as well. The Performer is a dual plane while the SM is a single. My thoughts are that the dual plane would be a better choice because they are designed for low to mid range operation. Opinions?
I have a pair of 1 3/4" headers that I may use on the truck too.
Re: 440 Streetmaster Intake. How does it compare? [Re: Kern Dog] #1388262
02/16/13 03:35 AM
02/16/13 03:35 AM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
Fb ....works FINE on that MH in the avatar pic ! .... but when I go with a muchO shorter gear(from a 4.56 to a 3.73) ...I will use the SP2P .....
Re: 440 Streetmaster Intake. How does it compare? [Re: Kern Dog] #1388263
02/16/13 04:14 AM
02/16/13 04:14 AM
dogdays Offline
dogdays  Offline
Performer all the way. Streetmaster was a half-baked idea that came out of the same mental malfunction as the sp2p. Sort of a mash-up that instead of combining the best of two ideas combined the worst of the two.
R.
Re: 440 Streetmaster Intake. How does it compare? [Re: dogdays] #1388264
02/16/13 08:25 AM
02/16/13 08:25 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Its about 1 step better than a small block SP2P intake and thats not saying much. Its best used as "Wall Art" or for aluminimum scrap..
I am truckless..
Re: 440 Streetmaster Intake. How does it compare? [Re: dogdays] #1388265
02/16/13 01:51 PM
02/16/13 01:51 PM
Nova Scotia Canada B2Y 1E4
SANDYinNS Canada Offline
R.
Sandy in Nova Scotia formerly drdodge340
68 coronet wagon, 68 formula s 340 fb barracuda-69 super bee-72 aussie charger-72 aussie vh dodge ute
-76 feather duster-76 duster-77 street van
- 98 ram 1500 SS/T-99 ram 1500-13 ram red express truck- 2015 hellcat challenger
Re: 440 Streetmaster Intake. How does it compare? [Re: Kern Dog] #1388266
02/16/13 02:39 PM
02/16/13 02:39 PM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
I guess that I have come across some "free" stuff that was certainly worth what I paid for it! The body lift kit, the SP2P and now this intake!
Re: 440 Streetmaster Intake. How does it compare? [Re: Kern Dog] #1388267
02/16/13 09:11 PM
02/16/13 09:11 PM
scratchnfotraction Offline
IMHO,you will not know of any results if you do not try it.
I do stuff all the time. results vary.
everyone told me the small port LD4B would not work out good on a 360headed 318. it was night and day over the performer. as a matter of fact,it works better on my 360 headed 318 than it does on the #302 headed 318 with the same roller cam back to back.
would it do that on a 360?? maybe not. but I would try it before knocking it. I only knock what did not work for me. like the sp2p, I have never ran a street master.
I put a holley street dom low rise open plane on a stock 2-v cam 318/small heads and it was a screamer with a q-jet in an A-body.
put it on my 360 with 292/292 lunati bracket cam and it works great but you can tell it is holding it back. but thats a 3/4 ton 8 lug 4.10 gear long bed truck.
swap my weiand action plus on the 440 for a RPM intake with a 600 eddy carb. 3.91sg
just put the q-jet/3.23 gear on it and picked it up from a flat 10 mpg to 13 mpg and still has some
I have a weiand 360* intake that is open plane with a divider down the middle and it is low rise with almost no runners for a squarebore carb. if nothing else a good weekend T&T to know if it works or is truly shelf art for the shed.
same with the wieand single carb tunnel ram i picked up. either it works or it is nice shelf art for the shed.
if you are not into 'testing' it,then you still cant beat free. dont you have a mancave or shed to put it in?
I have a stock intake that will most likly out do either of the ones you have if you want it. scratch up a thermobog or a qaudrajunk for it.
you are more than welcome to try the offy intake or the t-ram if you want to.
if not I will take both off of your hands to go on the shelf in my shed with the rest of my art work holding my carbs up off the shelf.
you could have already swaped it and know if it was an improvment or not.
I will wager it is a little better than the sp2p but you should be looking for a street dom or RPM intake. IMHO.
and a big plus is you have no TV linkage to fuss with.
Re: 440 Streetmaster Intake. How does it compare? [Re: scratchnfotraction] #1388268
02/17/13 02:42 AM
02/17/13 02:42 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
I like the ThermoQuads for the economy, so I'll stick with the spreadbore design. The standard Edelbrock Performer has this so I'll likely use it. The truck has inop A/C. Later when I install the intake, I'm going to ditch the A/C pump and change over to the non- A/C pulley arrangement. I got this truck to replace a '74 2wd Camper 9000 that has all the parts that I need.
Ultimately, the goal is to make this truck into a red/black Macho Power wagon clone.
I am quite interested in making these parts either swap meet sales or wall art for the garage. I remember going to Auto Speed Shops and seeing parts hanging on the wall, thinking of how cool that used to be.
Re: 440 Streetmaster Intake. How does it compare? [Re: dogdays] #1388269
02/17/13 03:50 AM
02/17/13 03:50 AM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
R.
Double D .....what have you been ? ....
The SP2P did EGGzackLEE what is was designed for ...improve MPG ...and it DID-DO just that. The StreetMaster was a blend of mpg and street performance.
Re: 440 Streetmaster Intake. How does it compare? [Re: dOrk !] #1388270
02/19/13 02:51 AM
02/19/13 02:51 AM
dogdays Offline
dogdays  Offline
My first intake was a new Weiand 7504 for my '68 chevelle 350. The carb on top of it was a Holley 6619. Remember those? Turn the screw IN to richen the idle.
Somewhere I have my copies of the Hot Rods and PHRs from those horrible days of gasoline shortages and homemade V4s.
So I remember the SP2P when it was new and the Streetmaster which was a single plane that they tried to get to run like a dual-plane by choking down the plenum and downsizing the runners.
A 205hp Corvette was a big thing.
It is a sign of the times that Edelbrock dropped those and went back to a classic two-plane design which they called the Performer.
You can get a duck to walk on soft snow by fitting snowshoes, but it won't work very well. you can get one of those misfits to work if you are satisfied with a 165 hp 440.
R.
Re: 440 Streetmaster Intake. How does it compare? [Re: dogdays] #1388271
02/19/13 03:16 AM
02/19/13 03:16 AM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
Double D .... the Streetmaster was no "duck" ... I have used that on my MH(413) recently with very good results. ALSO talked to a guy who is running a BBC boat ... tried the SM .. loved it.
Eddy went to the "Performer" TO SELL more intakes .... that intake is not much better than a decent OEM iron one. Now the Prpm is a diff story.
165 HP 440 ? ... my 413 will DO THAT on the front TWO BARRELS of my ThermoQuad .... now maybe with YOUR TUNEUP 165 is all you can get....
Re: 440 Streetmaster Intake. How does it compare? [Re: dOrk !] #1388272
02/19/13 10:24 PM
02/19/13 10:24 PM
dogdays Offline
dogdays  Offline
It's clear that we don't agree on this. My reference to 165 hp 440s was to the SP2P.
Sounds like what you REALLY need is an S.P.2.P-2V . Ever seen one of those?
R.
Re: 440 Streetmaster Intake. How does it compare? [Re: dogdays] #1388273
02/19/13 11:24 PM
02/19/13 11:24 PM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
THAT is clear
All I am relaying is my personal experience ..... MOST EVERYTHING talked-about-here is HP .... NEITHER of these intakes are that but they are good(in my experience) for better throttle response and mpg. Again .... I am running the SM on that MH .... things are fine with the 4.56 gear .. but when I go to the 3.73 ...I will be putting on the SP2P..... since RPMing the motor will be lessened by that swap.
The 2V SP2P ? ...I have seen that for the SBC and HEARD that there was one for the SBM and Ford .... but that is it. I would NOT want one of those for the BBM .... because any 2 bbl carbs I know of are not-the-plan for any decent MPG..... PLUS you need 4 bbls at times with towing.
And AGAIN .... don't junk any of these intakes for scrap-aluminum ...sell them to ME
Re: 440 Streetmaster Intake. How does it compare? [Re: dOrk !] #1388274
02/20/13 01:36 AM
02/20/13 01:36 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
I'll have both the StreetMaster and SP2P ready soon. What is a fuel miser-minded guy willing to pay for the pair....?
Re: 440 Streetmaster Intake. How does it compare? [Re: Kern Dog] #1388275
02/20/13 01:38 AM
02/20/13 01:38 AM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
How about 4 boxes of FRESH FrankenBERRI cereal ?
Re: 440 Streetmaster Intake. How does it compare? [Re: dOrk !] #1388276
02/20/13 01:41 AM
02/20/13 01:41 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
Uhhhh.....
Swap meet it is.
Re: 440 Streetmaster Intake. How does it compare? [Re: Kern Dog] #1388277
02/20/13 03:12 AM
02/20/13 03:12 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Hey Doc.. Looks like you screwed the pooch on that one..
I am truckless..
Re: 440 Streetmaster Intake. How does it compare? [Re: 340SHORTY] #1388278
02/20/13 03:15 AM
02/20/13 03:15 AM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
Nah SHORTstuff .... I still have a few IN STOCK
Fberri .. that offer was a ... give me a counter ...
Re: 440 Streetmaster Intake. How does it compare? [Re: 340SHORTY] #1388279
02/20/13 10:44 AM
02/20/13 10:44 AM
some members do not get 'good guy alerts'
Re: 440 Streetmaster Intake. How does it compare? [Re: scratchnfotraction] #2908888
04/10/21 11:56 PM
04/10/21 11:56 PM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
I sea you lurking .. mgoBuckeyes !
