Page 1 of 4 1 2 3 4
Are all US carbs junk? #1388195
02/16/13 01:01 AM
02/16/13 01:01 AM
Orange County, CA
Mike H Offline OP
Mike H  Offline OP
Orange County, CA
Hope I didn't offend anyone with the subject, but I am annoyed as heck about the fact my prissy Holley-carbed 383 seems to require a White House summons to start sometimes.
Here's the deal. I have a freshly rebuilt stock 335hp 383. My engine guy thinks Holleys are the only carb on the planet, so its overcarbed with a 750, contoured bowls, etc. etc. Let me state up front I know zero about carbs.
The problem: If I start my prissy Challenger every week, it runs just fine. Two weeks, and it pouts and whines, blows some white smoke, but I can usually get it started. Longer than two weeks, and it pulls out its SEIU union placard and goes on a total walkout.
I hate this carb, and the tow truck it was hauled in on. My mechanic says gas is no good, and this is California gas on top of that, blah blah blah. I know about the gas. He says I just need to run it every week. Problem: I leave for 2-3 months every summer, and upon my return my simpering, pimply-faced cretin Holley isn't about to give me the time of day.
I would buy the argument about the gas, except for one minor problem; I have an 86 Toyota 22r pickup, carburated. When I return from my summer hiatus, my Toyota is as happy to see me as my Jack Russell- it fires right up like I never left. Same gas, from the same station that I gas up my spoiled-rotten Chally at. It would be nice, since I have upward of nine million dollars in this resto, to have the car show SOME gratitude and start for me.
So, obviously the Toyota carb, being only 27 years old, is engineering light-years ahead of even a new Holley. Don't mean to offend again, but that's what my anectdotal experience tells me.
If I could figure out a way to put that little Toyota carb on my 383, I would, except there are dozens of wires, lines and tubes coming off of it. I wouldn't care if my 0-60 times were 30 seconds, at least it might start.
PLease don't regale me with stories about how you let your car sit for six months, and it fires right up. Might push me into doing something nasty to my dog-breath Holley.
Re: Are all US carbs junk? [Re: Mike H] #1388196
02/16/13 01:06 AM
02/16/13 01:06 AM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
stabil
Re: Are all US carbs junk? [Re: Mike H] #1388197
02/16/13 01:08 AM
02/16/13 01:08 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Maybe that yota carb doesn't have the rubber sealing materials in it that your holley does.
I never had issues with holleys sitting for long periods of time until the fuel formulations changed, especially with ethanol blends.
Now, holley carbs perform seppuku after sitting for a week or two without running... thanks to the crummy fuel.
Re: Are all US carbs junk? [Re: RobX4406] #1388198
02/16/13 01:10 AM
02/16/13 01:10 AM
Orange County, CA
Mike H Offline OP
Mike H  Offline OP
Orange County, CA
Seppuku?
Re: Are all US carbs junk? [Re: 05dakota] #1388199
02/16/13 01:12 AM
02/16/13 01:12 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
stabil
For three weeks???
I have an OEM AVS on my 340. If I were to go ut right now and try to start it, it would crank and crank and crank because the float bowls are empty. It doesn't matter whether the last time I fired it up it got warm or not. Pour some fuel down the throats, it runs great (well, it might stumble while the fuel pump catches up). The fuel in that car is at least five years old (probably older).
I have heard that Holleys were less prone to the fuel evaporating so it might be leaking down the intake. Let it sit for three weeks and pull the carb for a look... (smell the oil, too)
Re: Are all US carbs junk? [Re: Mike H] #1388200
02/16/13 01:12 AM
02/16/13 01:12 AM
RobX4406 Offline
RobX4406  Offline
Re: Are all US carbs junk? [Re: Jim_Lusk] #1388201
02/16/13 01:17 AM
02/16/13 01:17 AM
Orange County, CA
Mike H Offline OP
Mike H  Offline OP
Orange County, CA
Jim, I have the original AFB that was on the car, a #4367 I think. Its been rebuilt and I thought of putting it on but it sounds like it would make no difference. I don't care about performance, unless starting is considered performing. Any other carbs that might be better?
Re: Are all US carbs junk? [Re: RobX4406] #1388202
02/16/13 01:18 AM
02/16/13 01:18 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
put an electric fuel pump on it
Re: Are all US carbs junk? [Re: CSK] #1388203
02/16/13 01:23 AM
02/16/13 01:23 AM
Orange County, CA
Mike H Offline OP
Mike H  Offline OP
Orange County, CA
csk, why would I need to use an electric fuel pump? They didn't come with them. My Toyota doesn't have one. Is the problem that the gas evaporates out of the Holley but the Toyota carb is more precisely built and seals to the atmosphere?
Re: Are all US carbs junk? [Re: Mike H] #1388204
02/16/13 01:24 AM
02/16/13 01:24 AM
USA
JoesMopar Offline
JoesMopar  Offline
USA
Here's your problem.
Re: Are all US carbs junk? [Re: Mike H] #1388205
02/16/13 01:29 AM
02/16/13 01:29 AM
Loves Park, IL
HotRodRailroader Offline
Loves Park, IL
Well you could do a few things here. It sounds to me the bowls are dry. Check your fuel pump itself. could be back flowing when it sits. Try to purchase fuel with no ethanol. My RR I use 110 octane no ethanol not cheap either. My Holley 850 starts like a champ even after it sat for 2 months just fired it up yesterday. If that fuel is not available you can always put in an electric fuel pump. Also add the new green seals,valves and gaskets for internals in the carb. Its good for ethanol. That way when it sits the rubber is not destroyed in the carb and just let the fuel pump for a few seconds before starting and you should be on your way.
Re: Are all US carbs junk? [Re: HotRodRailroader] #1388206
02/16/13 01:33 AM
02/16/13 01:33 AM
Orange County, CA
Mike H Offline OP
Mike H  Offline OP
Orange County, CA
HotRodRailroader, I haven't heard of the green gaskets. Think they make them for the original Carter carb? Are these gaskets in a normal carb rebuild kit?
Re: Are all US carbs junk? [Re: Mike H] #1388207
02/16/13 01:40 AM
02/16/13 01:40 AM
USA
hudsonhornet7x Offline
USA
Maybe your Challenger is just pissy because it has to share a garage with a toyota .
Re: Are all US carbs junk? [Re: hudsonhornet7x] #1388208
02/16/13 01:41 AM
02/16/13 01:41 AM
USA
JoesMopar Offline
JoesMopar  Offline
USA
Re: Are all US carbs junk? [Re: JoesMopar] #1388209
02/16/13 01:44 AM
02/16/13 01:44 AM
Orange County, CA
Mike H Offline OP
Mike H  Offline OP
Orange County, CA
Actually, the brat Chally has the garage to itself. My poor Toyota sits outside all year. Alone.
Re: Are all US carbs junk? [Re: Mike H] #1388210
02/16/13 01:49 AM
02/16/13 01:49 AM
Seattle, WA
rss Offline
rss  Offline
Seattle, WA
4367 is an original Holley for a 70 383 HP with manual trans. AFB is a Carter.
Re: Are all US carbs junk? [Re: Mike H] #1388211
02/16/13 01:53 AM
02/16/13 01:53 AM
IL . usa
cjs69mope Offline
cjs69mope  Offline
IL . usa
I bet your one of those guys that can't start a weed whacker ether.
I watch my some of my neighbors pull their pull starts until there heads pop off they don't understand how a choke or a engine works. I just laugh. I start my 20 yr old lawn mower on 1 pull.My 500 inch Wedge with no choke Demon 850 in dead of winter anytime I want no problem.
Read more about Chokes and Carbs then take what u learn and use it.
Loose the Mechanic he can't fix the operator.
1969 Dodge Charger 1969 Dodge Superbee
Re: Are all US carbs junk? [Re: cjs69mope] #1388212
02/16/13 02:00 AM
02/16/13 02:00 AM
Orange County, CA
Mike H Offline OP
Mike H  Offline OP
Orange County, CA
So, explain to me Mr. csr carb man, why my Toyota starts and my sacred Holley won't. All I want to know.
Re: Are all US carbs junk? [Re: Mike H] #1388213
02/16/13 02:08 AM
02/16/13 02:08 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Like I said above the Holley is probably empty of fuel and the Toyota carb is not. There could be several reasons for this, but most likely the Holley is leaking the fuel out. There are some things that need to be confirmed, but the simple solution is an electric pump. Modern fuels are more prone to evaporation so today's gas will make the problem worse.
Re: Are all US carbs junk? [Re: Mike H] #1388214
02/16/13 02:08 AM
02/16/13 02:08 AM
Seattle, WA
rss Offline
rss  Offline
Seattle, WA
I don't know Toyotas, but I have a hard time believing that an 86 Toyota wouldn't have an electric fuel pump. Are you certain about that?
Given the increased volatility of today's gas, an electric pump could certainly be the difference between why the truck starts and the Challenger doesn't.
Page 1 of 4 1 2 3 4
