Page 6 of 7 1 2 3 4 5 6 7
Re: Calling Junky [Re: 1968RR] #1388087
03/14/13 07:47 PM
03/14/13 07:47 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
1968RR, thanks for your input. A voice of sanity.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: ZDDP oil analysis results [Re: 67Satty] #1388088
08/07/13 01:41 PM
08/07/13 01:41 PM
Wisconsin
Aero426 Offline
Aero426  Offline
Wisconsin
The Mobil 1 15W-50 (top of page 2) looks very good. 1300 ppm Zn and 1200 ppm of P.
Mobil 1 Product Guide
Re: ZDDP oil analysis results [Re: 1968RR] #1388089
08/07/13 05:06 PM
08/07/13 05:06 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
The American Society for Testing and Materials (ASTM) sets the industry standardized test methods for determining among other things additive elements, wear metals, and contaminates in lubricating oils. In this case, the ASTM D5185 otherwise known as Inductively Coupled Plasma Atomic Emission Spectrometry (ICP-AES) is where zinc and phosphorous content is commonly tested and reported by the industry.
To read the ASTM test methodology for (ICP-AES), click on the ASTM D5185 link – HERE
Re: ZDDP oil analysis results [Re: 1968RR] #1388090
08/07/13 05:22 PM
08/07/13 05:22 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
Brad Penn: 1600-1700 ppm
Brad Penn utilizes the ASTM qualified lab, Southwest Research Institute (SwRI), for additive element testing and reporting. There again, SwRI uses the industry standardized test method, ASTM D5185 (ICP), to determine zinc content of lubricant oils.
As such, Penn Grade 1 oils have between 1540-to-1565 ppm zinc content.
For more, click on Brad Penn’s link - HERE
For more on Southwest Research Institute (SwRI), click on the link - HERE
Re: ZDDP oil analysis results [Re: 1968RR] #1388091
08/07/13 05:36 PM
08/07/13 05:36 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
Rotella T: 1200-1300 ppm
The independent watchdog group, Petroleum Quality Institute of America (PQIA), provides information to consumers regarding lubricant quality. As such, PQIA purchases various lubricants at random and sends blind samples to Southwest Research Institute (SwRI) for testing, there again, utilizing the industry standardized test method, ASTM D5185 (ICP).
Here is what PQIA recently reported for Shell Rotella T Triple Protection, SAE 15W-40, API CJ-4/SM.
Phosphorus 965ppm
Zinc 1098ppm
For more, click on this link - HERE
Re: ZDDP oil analysis results [Re: 1968RR] #1388092
08/07/13 05:44 PM
08/07/13 05:44 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
Royal Purple: 800-900ppm
Here is what Petroleum Quality Institute of America (PQIA) recently reported for:
Royal Purple Synthetic Oil 5W-30 API SN ILSAC GF-5.
Phosphorus 706ppm
Zinc 837ppm
- AND -
Royal Purple, API SL, SAE 10W-30.
Phosphorus 808ppm
Zinc 876ppm
Re: ZDDP oil analysis results [Re: Pacnorthcuda] #1388093
08/07/13 06:06 PM
08/07/13 06:06 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
Junky, you raise good points, but keep in mind...DELO oils were not engineered for our flat tapped gasoline V8s. Ive spoken directly with several Chevron engineers (I've purchased over a million gallons of DELO 15w40 over the years) who tell me the zinc in their oil is for the punishment that the small end of the rod endures during the uber high compression of a diesel. The detergent is there to keep soot in suspension.
Gasoline engines have different requirements. Yes, DELO oils ARE good, but for our use, I believe there are better answers.
BTW, did you know Chevron DELO is a synthetic blend (at least technically--thank you Castrol)? It just hasn't been marketed that way. It's about to though---DELO XLE ( as opposed to LE) is just about to hit the streets.
Here is what Petroleum Quality Institute of America (PQIA) recently reported for: Chevron Delo® 400LE SAE 15W-40, API CJ-4/CI-4 Plus/SM.
Phosphorus 1312ppm
Zinc 1490ppm
What Chevron engineers? Who did you talk to?
This is what Chevron says right in their Product Data Sheet:
APPLICATIONS
Delo 400 LE SAE 15W-40 is a mixed fleet motor oil
recommended for naturally aspirated and turbocharged
four-stroke diesel engines and four-stroke gasoline
engines
in which the API CJ-4 service category and
SAE 15W-40 viscosity grade are recommended. It is
formulated for engines operating under severe service
and a wide range of climatic conditions.
- AND -
Delo 400 LE SAE 15W-40 is approved for: API Service Categories CJ-4, CI-4 PLUS, CI-4,
CH-4, SM, SL
Seriously folks, Chevron Delo 400 LE is enginered for "mixed fleet" diesel and gasoline applications, see also API (SM) and (SL). Let's let the diesel detergent myths stop here. It's a Heavy Duty Engine Oil (HDEO) for heavy duty applications.
For more, Chevron DELO 400 LE SAE 15W-40 Product Data Sheet at this link - HERE
Re: ZDDP oil analysis results [Re: dogdays] #1388094
08/07/13 10:02 PM
08/07/13 10:02 PM
Uranus
strokerchall Offline
Uranus
Joe Gibbs is another company that says the ultra-high detergent levels in Diesel oils harm the effectiveness of the ZDDP.
R.
i was told this by a guy at NAPA when I bought JOE GIBBS ,my first choice was VR-1 racing oil but he talkled me out of it after i asked if i could ad zinc
Re: ZDDP oil analysis results [Re: strokerchall] #1388095
08/07/13 10:14 PM
08/07/13 10:14 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
The new bottles of VR1 state not for extended use in vehicles with cat converter
Re: ZDDP oil analysis results [Re: CompSyn] #1388096
08/07/13 10:25 PM
08/07/13 10:25 PM
Kirkland, Washington
Pacnorthcuda Offline
Phosphorus 1312ppm
Zinc 1490ppm
APPLICATIONS
engines
- AND -
CH-4, SM, SL
Comp: you DO know that DELO stands for "diesel engine lubricating oil" right?
Well now you do. I said they ARE good oils, just very high in detergent for our applications. There are better choices.....ummmm I think you of all would agree with that.
Re: ZDDP oil analysis results [Re: Pacnorthcuda] #1388097
08/07/13 11:22 PM
08/07/13 11:22 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
And now YOU know Chevron actually recommends DELO for API (SM) and (SL) rated gasoline engines. So now you can stop spreading the tripe that it's not well suited for gasoline engines when it's engineered to work equally as well in both diesel and gasoline applications.
Old design carbureted V8s aren't the cleanest running engines as where more robust detergents can actually be a plus. But you're right, DELO is not my first choice in engine oil.
Re: ZDDP oil analysis results [Re: CompSyn] #1388098
08/07/13 11:33 PM
08/07/13 11:33 PM
[quotes. So now you can stop spreading the tripe that it's not well suited for gasoline engines when it's engineered to work equally as well in both diesel and gasoline applications.
That is flat out wrong. DELO was NOT "engineered to work equally as we'll in both diesel and gasoline applications" it was engineered for diesel applications period. As stated, I've purchased over a million gallons over the last 12 years. PM me for more info. Chevron realized a lucrative secondary market after its introduction and the marketers took over. "Tripe". Give me a freekin break!
Re: ZDDP oil analysis results [Re: Pacnorthcuda] #1388099
08/08/13 12:28 AM
08/08/13 12:28 AM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
Pac, lots of people use mixed-fleet Heavy Duty Engine Oil (HDEO) in their gasoline powered applications and report stellar Used Oil Analysis reports. Irregardless of what DELO "WAS" twelve years ago, today it's a mixed fleet HDEO and Chevron's Product Data Sheet reflects this. You've decided it's not the first choice for your Muscle Car, that's fine, but HDEO remains a safe, affordable and readily available option for many. Sorry I struck a nerve my friend.
Re: ZDDP oil analysis results [Re: CompSyn] #1388100
08/08/13 12:33 AM
08/08/13 12:33 AM
fair enough Comp. as a trivial Chevron factoid...when you make it to retirement, they call it "reaching the end of the pipe"
Re: ZDDP oil analysis results [Re: Pacnorthcuda] #1388101
08/08/13 06:49 AM
08/08/13 06:49 AM
SE PA
Yellow Fever Offline
SE PA
I bought the 10 pack of the ZDDPLUS off Ebay and I found this:
http://www.zddplus.com/imgs/ZDDPlusTestResults2.pdf
I'll use that and keep using Rotella.
Re: ZDDP oil analysis results [Re: Yellow Fever] #1388102
08/08/13 09:13 AM
08/08/13 09:13 AM
DuPont, Washington
DZJim Offline
DZJim  Offline
DuPont, Washington
Looks like the "test report" has been "embellished" a little. Chemist would not take it upon himself to comment upon "...optimum range for high-performance flat tappet engines..." Whole thing strikes me as ad hype...
Re: ZDDP oil analysis results [Re: Yellow Fever] #1388103
08/08/13 11:14 AM
08/08/13 11:14 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
At what point are you going to sludge up the motor? When I pulled the pan off my 32K mile Duster it had grey tetraethyl lead in the pan, and nasty Pennzoil goo. I think it was Pennzoil, that was the sticker on the door.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: ZDDP oil analysis results [Re: strokerchall] #1388104
08/08/13 11:34 AM
08/08/13 11:34 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
R.
I'm "assuming" Joe Gibb would rather have you buy his oil and I'll bet the guy at NAPA is related to GG,if he said it,it has to be correct !!
I'll stick to my Brad Penn!
Re: ZDDP oil analysis results [Re: CompSyn] #1388105
08/08/13 01:15 PM
08/08/13 01:15 PM
San Angelo, Texas, U.S.A.
1968RR Offline OP
1968RR  Offline OP
SWRI does good research and is a reputable institute, but ICP-AES simply isn't as accurate as NAA (it's only the "industry standard" because NAA typically requires access to a nuclear reactor). You will literally not find a single paper in a peer-reviewed scientific journal that claims that ICP-AES is a more sensitive method of trace element analysis than NAA.
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
Re: ZDDP oil analysis results [Re: 1968RR] #1388106
08/08/13 01:54 PM
08/08/13 01:54 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
And how minute would be the difference and would it really matter ?
