Page 1 of 7 1 2 3 4 5 6 7
ZDDP oil analysis results #1387987
02/15/13 08:39 PM
02/15/13 08:39 PM
San Angelo, Texas, U.S.A.
1968RR Offline OP
1968RR  Offline OP
We recently analyzed nine motor oils using neutron activation analysis (NAA) to determine ZDDP content. Typically, ZDDP content is determined using a method called inductively coupled plasma atomic emission spectroscopy, which usually results in much higher uncertainties than NAA (our uncertainties were all below 2%). We may publish the data in an academic journal after some more tests are run (using different methods), so I'm not going to post the exact concentrations just yet. However, the oils are listed here in order from highest to lowest concentrations and a range of ppm is given. All oils tested were 10W30, except for the Comp Cams additive, which didn't specify a weight. Here are the results:
Comp Cams additive: 9500-9600 ppm
Brad Penn: 1600-1700 ppm
Valvoline VR1: 1200-1300 ppm
Rotella T: 1200-1300 ppm
Red Line: 1100-1200 ppm
Royal Purple: 800-900 ppm
Lucas: 800-900 ppm
Valvoline: 700-800 ppm
SuperTech (Walmart): 600-700 ppm
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
Re: ZDDP oil analysis results [Re: 1968RR] #1387988
02/15/13 08:46 PM
02/15/13 08:46 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
Nice, thanks! Brad Penn is what we use on the old Mopars.
Re: ZDDP oil analysis results [Re: dustergirl340] #1387989
02/15/13 08:53 PM
02/15/13 08:53 PM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
I use VR1 10-30. Nice to see those numbers. Thanks!
Re: ZDDP oil analysis results [Re: T2R9] #1387990
02/15/13 09:23 PM
02/15/13 09:23 PM
the house on the left.
cogen80 Offline
cogen80  Offline
Lucas: 800-900 ppm
ok, so whats the number thats sufficient for old flat tappet motors? or is it just more the merrier? i mean if 600ppm is plenty of protection it would be kinda silly to spend more money on some of the fancier oils..
Re: ZDDP oil analysis results [Re: cogen80] #1387991
02/15/13 09:45 PM
02/15/13 09:45 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Around 1000 PPM is good, little more/less is ok.
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: ZDDP oil analysis results [Re: 1968RR] #1387992
02/15/13 09:53 PM
02/15/13 09:53 PM
State, country, etc.
gss Offline
gss  Offline
I had heard that the new Rotella T has a lower content ZDDP. Those numbers look like what the older stuff had. Do you know how recently the Rotella was purchased?
Re: ZDDP oil analysis results [Re: astjp2] #1387993
02/15/13 09:55 PM
02/15/13 09:55 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Which Rotella T? Synthetic or Dino oil?
Re: ZDDP oil analysis results [Re: WO23Coronet] #1387994
02/15/13 10:35 PM
02/15/13 10:35 PM
Wisconsin
Aero426 Offline
Aero426  Offline
Wisconsin
Was the VR1 tested the silver bottle (conventional) or the black bottle (synthetic)?
The silver bottle has a street detergent additive package.
Re: ZDDP oil analysis results [Re: gss] #1387995
02/15/13 10:37 PM
02/15/13 10:37 PM
Wisconsin
Aero426 Offline
Aero426  Offline
Wisconsin
The older Rotella is CI. The later with the reduced ZDDP is CJ.
Re: ZDDP oil analysis results [Re: Aero426] #1387996
02/15/13 10:43 PM
02/15/13 10:43 PM
1968RR Offline OP
1968RR  Offline OP
I bought the Rotella T that we tested two months ago. It was conventional (non-synthetic) oil. The VR1 that was tested was the type in the silver bottle.
As far as how much ZDDP is needed for flat tappet cams - I don't know. But I've heard that 1200-1500 ppm is optimal. I have also read on some message boards that too much ZDDP can actually increase wear, BUT have never seen any data or cited references to back that up. I do know that it is the phosphorus, not the zinc, in ZDDP that provides the anti-wear protection.
Re: ZDDP oil analysis results [Re: Aero426] #1387997
02/15/13 10:44 PM
02/15/13 10:44 PM
Orleans, Ontario
moparcanuk Offline
moparcanuk  Offline
Orleans, Ontario
Thanks for sharing this.
Re: ZDDP oil analysis results [Re: Aero426] #1387998
02/15/13 10:53 PM
02/15/13 10:53 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
So, the jug of Valvoline Premium Blue heavy duty diesel engine oil 15-40 I have says on the lable;
exceeds
API SERVICES CJ-4, CI-4 PLUS, CI-4 CH-4, CG-4, CF-4, CF/SM.
So, just what is what? It has both ci and cj, not to mention ch, cg, cf and cf/sm. What does all that mean?
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: ZDDP oil analysis results [Re: amxautox] #1387999
02/15/13 10:56 PM
02/15/13 10:56 PM
amxautox Offline
amxautox  Offline
A quote that was stated in another thread back on 3-13-2007;
if its SM rated it doesnt belong in our cars.
Nope. CJ4, CI4, CH4/SL, and DI4 Plus
Tom
author unknown
Re: ZDDP oil analysis results [Re: 1968RR] #1388000
02/15/13 11:01 PM
02/15/13 11:01 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
It would be interesting to know the API SERVICE classification of the actual oil you tested for each brand, that's pretty important to compare it would seem?
Re: ZDDP oil analysis results [Re: amxautox] #1388001
02/15/13 11:05 PM
02/15/13 11:05 PM
Wisconsin
Aero426 Offline
Aero426  Offline
Wisconsin
exceeds
It supercedes thoses other API ratings. But it does not mean it is suitable for use in a flat tappet engine. If it has CJ or "low emissions" on the bottle, it is the new emissions friendly diesel oil, which means it has the reduced additive package. Diesel oils typically had boosted Zinc levels, but they also have a high detergent package that in essence tries to clean off the anti-wear coating. Many here will tell you the use of Rotella or other diesel oils is fine. I would consider a CJ oil to be borderline. I'm not using them. Use with a roller cam or overhead cam would be OK.
For passenger car rated oils, avoid anything with SM or SN rating UNLESS it specifically calls out protection like the silver bottle of VR-1 does.
Re: ZDDP oil analysis results [Re: Aero426] #1388002
02/15/13 11:15 PM
02/15/13 11:15 PM
amxautox Offline
amxautox  Offline
exceeds
If it has CJ or "low emissions" on the bottle, it is the new emissions friendly diesel oil, which means it has the reduced additive package. Diesel oils typically had boosted Zinc levels, but they also have a high detergent package that in essence tries to clean off the anti-wear coating. I would consider a CJ oil to be borderline. I'm not using them.
My silver/grey bottle of full synthetic Valvoline doesn't say anything special about 'protection'.
It says on the label;
exceeds
API SERVICES SL/SJ, CF/CD, ILSAC GF-3
Tom
author unknown
Re: ZDDP oil analysis results [Re: amxautox] #1388003
02/15/13 11:20 PM
02/15/13 11:20 PM
Wisconsin
Aero426 Offline
Aero426  Offline
Wisconsin
My silver bottle of full synthetic Valvoline doesn't say anything special about 'protection'.
exceeds
Your bottle is not VR-1. It is regular Valvoline synthetic. The SL rated oil is the last API rated oil before they went to SM which dramatically reduced the ZDDP levels. This reduction has been occuring over time. Your SL oil is ok for a street engine. If you bought the same bottle today, it would likely be SM or SN rated which would not be OK.
Re: ZDDP oil analysis results [Re: Aero426] #1388004
02/15/13 11:24 PM
02/15/13 11:24 PM
Wisconsin
Aero426 Offline
Aero426  Offline
Wisconsin
There is a ton of good information at this FAQ link. I have heard this man speak and he knows his she-ite.
Oil Frequently Asked Questions
Re: ZDDP oil analysis results [Re: 1968RR] #1388005
02/15/13 11:44 PM
02/15/13 11:44 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Thanks for your efforts and the results, AWESOME
Re: ZDDP oil analysis results [Re: Challenger 1] #1388006
02/16/13 12:02 AM
02/16/13 12:02 AM
1968RR Offline OP
1968RR  Offline OP
Yes and no. Some brands (like Brad Penn, for example) don't have any API classification on the bottle. Others, like SuperTech and Valvoline, do. We just tried to choose commonly used motor oils and a few specialty oils. Oils that are rated API SN aren't supposed to have more than 800 ppm ZDDP (for environmental reasons and because they can harm catalytic converters), but some of them tested did.
