Difficult to find U-Joint.............. #1387952
02/15/13 03:38 PM
02/15/13 03:38 PM
New Port Richey, Florida
Wolfe440 Offline OP
Wolfe440  Offline OP
Replacing the U joints on a factory 69 440 M code Barracuda. The U-joint at the rear axle end of the drive shaft is an odd one, I have not been able to find one after a long search.
The X dimensions from end of cap to end of cap are 3 5/8 X 3 1/8. The 3 5/8 dimension has caps with a diameter of 1 1/8 and the 3 1/8 dimension has caps with a diameter of 1 1/16.
Anyone know of a source that may carry one of these?
Thanks,
Wolfe
Re: Difficult to find U-Joint.............. [Re: Wolfe440] #1387953
02/15/13 03:59 PM
02/15/13 03:59 PM
Texas
Daty Rogers Offline
World's Greatest Husband. I love you Robyn
Daty Rogers  Offline
Texas
Sounds like a combo u-joint, available anywhere.
-Daty
Re: Difficult to find U-Joint.............. [Re: Daty Rogers] #1387954
02/15/13 04:03 PM
02/15/13 04:03 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
http://www.moparts.org/Tech/Archive/shaft/4.html
from the tech archives
Lar, the 13.. joints you asked about are Spicer brand or "styles" of Ujoints, their specs are:
1310, End of Cap to End of Cap 3.219", cap dia 1.063"
1330, End of Cap to End of Cap 3.625", cap dia 1.063"
1350, End of Cap to End of Cap 3.625", cap dia 1.188"
The Mopar/Detroit joint specs are:
7260, Clip to Clip 2.125" or 3.125" EoC to EoC, Cap dia 1.078"
7290, Clip to clip 2.625" or 3.625 EoC to EoC, Cap dia 1.125"
Here is a pic of the 1330-1350 Conversion joint I am currently using for my Dshaft to rear end connection. There is a big difference between the size and strength between the caps of this joint.
Hope this helps.
Troy
Re: Difficult to find U-Joint.............. [Re: stumpy] #1387955
02/15/13 05:00 PM
02/15/13 05:00 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
IIRC the NAPA # is a 527..
I am truckless..
Re: Difficult to find U-Joint.............. [Re: 340SHORTY] #1387956
02/15/13 05:20 PM
02/15/13 05:20 PM
Wolfe440 Offline OP
Wolfe440  Offline OP
